HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
03-19-2017, 16:36 | #1 (permalink) | ||
Moderator Join Date: Oct 2011 Location: U.A.E
Member: 1676524 Status: Offline Sonork: 100.1608473 Thanks Meter: 2,713 | HTC Error Solution for RUUmode/Fastboot Error Handling Strategies for RUUmode/Fastboot IF IT SAYS "FAILED" do NOT immediately reboot the Devices If you reboot with a FAIL your device could brick! If no flash is being accepted you have to find out what is causing the malfunction before rebooting your phone. Keep it alive while trying to figure out the error. It might be your cable, your USB ports (don’t use hubs! Always direct-mainboard connections), it might be USB 3.0 which is not good yet, it might be bad configuration of your ADB and Fastboot... The least dangerous FAILED messages are listed below and are safe to reboot (below this section you find CRITICAL errors, please observe): Safe to reboot / Flash didn't happen Errors (if you encounter one of them, you can just reboot. Nothing changed): - 10 RU_MODELID_FAIL (MID in android-info.txt does not match phone’s MID)In fact, if it aborts before the "(bootloader) start image[hboot] unzipping & flushing..." line it actually didn't write anything and you can probably just reboot. If you see it flashing stuff though (the stages after that line) and then it stops with a FAILED, chances are a little higher that something is now broken. In that case do NOT reboot but do as i said above. NOT safe to reboot / Flash (partly) happened Errors (if you encounter one of them, DON’T reboot):
The Following 7 Users Say Thank You to ...:::SHAMIM:::... For This Useful Post: |
11-05-2019, 16:58 | #4 (permalink) |
Junior Member Join Date: Nov 2019 Location: delhi
Member: 2935038 Status: Offline Thanks Meter: 0 | hello guys, I've always been using cyanigebnid11 on my HTC One M8 since the day I got it. But recently I wasn't fully satisfied with it so I wanted to flash a new ROM and simultaneously upgrade to Lollipop. I really didn't want to use HTC Sense so I figured that SkyDragon Google Play Edition would be a good option. I read through the whole post and flashed Philz Touch 6.25.5 since it was the recommended recovery. The first boot took pretty long but seemed fine. But during the setup I realized the Wi-Fi is not working. Since I read in the F.A.Q. of SkyDragon that that's a common issue I guessed it wouldn't be much trouble. Now, sadly, I did not make a backup of my completely stock HTC One M8 so I couldn't just update to the latest OTA. So I tried to S-off it but the compatibility-tests of SunShine said the ROM has to be closer to stock. Then I flashed the stock ROM from here and ran SunShine again, this time with positive results. But when it had to restart the phone during the process of S-off'ing it got stuck in a bootloop. Wiping cache and dalvik did nothing, only completely flashing a ROM again did. Now everytime I flash a ROM the initial boot works but from then I can't just reboot because I always get stuck in a bootloop. So, I got SkyDragon and it seems to be working just fine, except for the Wi-Fi, the bootloops and I still don't have S-off. I guess that fixing the bootloop might be the first step so I can S-off and manually flash the latest GPE L firmware. thanks and regards |
03-10-2020, 14:36 | #6 (permalink) |
Junior Member Join Date: Feb 2020 Location: ALASKA
Member: 2947391 Status: Offline Thanks Meter: 0 | I have a phone I got directly from HTC that I never messed with specifically so I could use Google pay, and I'm still getting that error. ***** because my banking app made it easy to add my main card right around the same time this issue started. |
