HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
12-25-2015, 08:49 | #1 (permalink) |
Insane Poster Join Date: Nov 2008
Member: 895815 Status: Offline Thanks Meter: 10 | Htc 826w ruu need [Link inside] INFO Model : A52_DTUL IMEI : 357290062678830 Build : CID : HTC__038 HBoot : 3.19.0.0000 MID : 0PHC10000 Security : ON Region : ASIA_INDIA |
12-25-2015, 09:21 | #2 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Left out from our gsm field Age: 29
Member: 2386560 Status: Offline Sonork: NOW I DON'T USE IT Thanks Meter: 561 | plez upload get var info command for main-ver: code fastboot getvar all Last edited by vickyjadhav6161; 12-25-2015 at 09:26. |
10-07-2017, 15:01 | #7 (permalink) |
Junior Member Join Date: Mar 2017 Location: London, UK
Member: 2692434 Status: Offline Thanks Meter: 25 | E:\HTC\Android>fastboot devices CC53XYG07909 fastboot E:\HTC\Android>fastboot getvar all (bootloader) version: 0.5 (bootloader) version-bootloader: 3.19.0.0000 (bootloader) version-baseband: 1.0.U20402.1@50316 (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 1.17.708.13 (bootloader) version-misc: PVT SHIP S-OFF (bootloader) serialno: CC53XYG07909 (bootloader) imei: 356195061814289 (bootloader) imei2: 356195061814297 (bootloader) meid: 00000000000000 (bootloader) product: a52_dtul (bootloader) platform: hTCBmsm8939 (bootloader) modelid: 0PHC10000 (bootloader) cidnum: 11111111 (bootloader) battery-status: good (bootloader) battery-voltage: 0mV (bootloader) partition-layout: Generic (bootloader) security: off (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: 156cfeff (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 (bootloader) mfg-name: 1001 all: Done! finished. total time: 0.062s Need this firmware |
10-08-2017, 06:57 | #8 (permalink) | |
Moderator Join Date: Oct 2011 Location: U.A.E
Member: 1676524 Status: Offline Sonork: 100.1608473 Thanks Meter: 2,713 | Quote:
__________________ __________________ Rules are for the obedience of fools and the guidance of wise men. Best Regards, Shamim Last edited by ...:::SHAMIM:::...; 10-08-2017 at 07:02. | |
06-19-2019, 15:16 | #12 (permalink) |
No Life Poster Join Date: Oct 2017 Location: on google.com
Member: 2771307 Status: Offline Thanks Meter: 772 | Here you got instruction how use files like this with picture step by step. How to change firmware and repair HTC phone by SD card tutorial by HardReset.info Team or use RUU mode here is a tutorial: How to flash, repair HTC phone by Ruu mode tutorial by HardReset.info Team |
06-20-2019, 05:07 | #13 (permalink) | |
No Life Poster Join Date: Jun 2008 Location: World
Member: 792851 Status: Offline Thanks Meter: 136 | Quote:
i m having this error while flashing Code: Microsoft Windows [Version 10.0.17134.829] (c) 2018 Microsoft Corporation. All rights reserved. C:\Program Files\Minimal ADB and Fastboot>fastboot getvar all (bootloader) version: 0.5 (bootloader) version-bootloader: 3.19.0.0000 (bootloader) version-baseband: 1.0.U20402.1@50316 (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 1.15.707.6 (bootloader) version-misc: PVT SHIP S-OFF (bootloader) serialno: CC55GYG03779 (bootloader) imei: 356197060915067 (bootloader) imei2: 356197060915075 (bootloader) meid: 00000000000000 (bootloader) product: a52_dtul (bootloader) platform: hTCBmsm8939 (bootloader) modelid: 0PHC10000 (bootloader) cidnum: 11111111 (bootloader) battery-status: good (bootloader) battery-voltage: 0mV (bootloader) partition-layout: Generic (bootloader) security: off (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: 449df917 (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 (bootloader) mfg-name: 1001 all: Done! finished. total time: 0.060s C:\Program Files\Minimal ADB and Fastboot>fastboot oem rebootRUU ... (bootloader) Start Verify: 0 OKAY [ 0.022s] finished. total time: 0.024s C:\Program Files\Minimal ADB and Fastboot>fastboot flash zip 0PHCIMG.zip target reported max download size of 16777216 bytes Invalid sparse file format at header magic error: write_sparse_skip_chunk: don't care size 1796927069 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1780153949 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1763380829 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1746607709 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1729834589 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1713061469 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1696288349 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1679515229 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1662742109 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1645968989 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1629195869 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1612422749 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1595649629 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1578876509 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1562103389 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1545330269 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1528557149 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1511784029 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1495010909 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1478237789 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1461464669 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1444691549 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1427918429 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1411145309 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1394372189 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1377599069 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1360825949 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1344052829 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1327279709 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1310506589 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1293733469 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1276960349 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1260187229 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1243414109 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1226640989 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1209867869 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1193094749 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1176321629 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1159548509 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1142775389 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1126002269 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1109229149 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1092456029 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1075682909 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1058909789 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1042136669 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1025363549 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1008590429 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 991817309 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 975044189 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 958271069 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 941497949 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 924724829 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 907951709 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 891178589 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 874405469 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 857632349 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 840859229 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 824086109 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 807312989 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 790539869 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 773766749 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 756993629 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 740220509 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 723447389 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 706674269 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 689901149 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 673128029 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 656354909 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 639581789 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 622808669 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 606035549 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 589262429 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 572489309 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 555716189 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 538943069 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 522169949 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 505396829 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 488623709 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 471850589 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 455077469 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 438304349 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 421531229 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 404758109 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 387984989 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 371211869 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 354438749 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 337665629 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 320892509 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 304119389 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 287346269 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 270573149 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 253800029 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 237026909 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 220253789 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 203480669 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 186707549 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 169934429 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 153161309 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 136244829 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 119471709 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 102698589 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 85925469 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 69086813 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 52313693 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 35540573 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 18767453 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1748573 is not a multiple of the block size 4096 sending sparse 'zip' 1/109 (16076 KB)... error: write_sparse_skip_chunk: don't care size 1796927069 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 1796927069 is not a multiple of the block size 4096 OKAY [ 1.775s] writing 'zip' 1/109... (bootloader) zip header checking... (bootloader) shift signature_size for header checking... FAILED (remote: 32 header error) finished. total time: 1.891s C:\Program Files\Minimal ADB and Fastboot> 0PHCIMG_A52_DTUL_L50_DESIRE_SENSE60_hTC_Asia_WWE_1 .17.707.8_Radio_1.0.U20402.1@50818_08.00_018_F_rel ease_449348_signed_2_4_ what to do? | |
06-25-2019, 23:27 | #15 (permalink) |
Member: 792851 Status: Offline Thanks Meter: 136 | here already post above Microsoft Windows [Version 10.0.17134.829] (c) 2018 Microsoft Corporation. All rights reserved. C:\Program Files\Minimal ADB and Fastboot>fastboot getvar all (bootloader) version: 0.5 (bootloader) version-bootloader: 3.19.0.0000 (bootloader) version-baseband: 1.0.U20402.1@50316 (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 1.15.707.6 (bootloader) version-misc: PVT SHIP S-OFF (bootloader) serialno: CC55GYG03779 (bootloader) imei: 356197060915067 (bootloader) imei2: 356197060915075 (bootloader) meid: 00000000000000 (bootloader) product: a52_dtul (bootloader) platform: hTCBmsm8939 (bootloader) modelid: 0PHC10000 (bootloader) cidnum: 11111111 (bootloader) battery-status: good (bootloader) battery-voltage: 0mV (bootloader) partition-layout: Generic (bootloader) security: off (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: 449df917 (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 (bootloader) mfg-name: 1001 all: Done! finished. total time: 0.060s |
