HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
05-04-2009, 08:40 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Rawalpindi, Pakistan
Member: 421117 Status: Offline Sonork: +92 346 5544377 (PHONE) Thanks Meter: 2,522 | G1 Google Phone: Hard Reset 1.HTC G1 Android Phone, 2.nm8drm, 3.G1 Google Phone here is step by step guide how to reset. if your T-Mobile G1 Google smartphone is not responding or is frozen, you may have to opt for a hard reset. Here’s how: 1. Turn the G1 off. If it’s frozen on, take the battery out and put it back in the unit. 2. Hold the Home and Power keys down at same time for about 25 seconds. You will see a yellow triangle screen with exclamation point in the middle. Now to wipe the device clean: 3. Press Alt+L. 4. Press Alt+W for a factory reset. 5. Press the Home and Back keys again for about 25 seconds. The device should then reset again and the hard reset is complete. Last edited by Umair Rashid; 05-04-2009 at 08:49. |
The Following 14 Users Say Thank You to Umair Rashid For This Useful Post: |
05-06-2009, 11:01 | #6 (permalink) | |
Member: 421117 Status: Offline Sonork: +92 346 5544377 (PHONE) Thanks Meter: 2,522 | Quote: for ur kind information i wrote alternative names so that search becomes easy . i know u copy from here http://www.technipages.com/t-mobile-...ard-reset.html for that use common sense. search . | |
05-06-2009, 13:31 | #7 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: Bangladesh Age: 42
Member: 319447 Status: Offline Thanks Meter: 4,949 | Quote:
Either from that URL or from my thread | |
05-07-2009, 08:08 | #8 (permalink) | |
i gave u original link it means surely i copied from original one .and not from urs... secondly my attached pic is different then urs it also proves i didn't copy ur's already copied link. no fight !!! regards !! | |
The Following User Says Thank You to Umair Rashid For This Useful Post: |
02-16-2010, 13:37 | #12 (permalink) |
Freak Poster Join Date: Oct 2006 Location: UK
Member: 362955 Status: Offline Thanks Meter: 61 | Hi dear, I got HTC G1 whcih was water damage. After cleaning when its turn on it shows straight away triangle with exclamation point. I have done soft and hard reset but all in vein. Any suggestion will be appreciated. Thanks in advance. Regards, Pofessional |
How to Hard reset HTC drea110 G1 | ebu mohammed-emin | HTC & Smartphones ( WM Without Touch) | 11 | 10-27-2015 18:05 |
Hard Reset G1 Google Phone | .:SUBRATA:. | HTC Android based | 33 | 08-08-2013 22:31 |
**** how to active googel g1 after unlock or hard reset **** | abcrino50 | HTC & PDA WM( With Touchscreen) | 1 | 07-18-2009 16:47 |
G1 Google Phone hard reset new | gsmshapon | Universal GSM Software | 0 | 05-20-2009 08:12 |
g1 google keypad ribbon need | ahmertelecom | Wanted Products | 0 | 04-10-2009 10:17 |
