Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > HTC > HTC Android based
HTC Android based General HTC Android phones discussion, firmwares, solution, root, help
Old 01-25-2013, 18:18   #1 (permalink)
nasirahmed's Avatar
Member: 57760
Sonork: 100.1579298
Thanks Meter: 3,482
[Guide] How to Upgrade Your HTC Android Phone with a microSD card
1. Extract rom.zip from an RUU
A. Run the RUU. For example, you want to update your Desire HD with RUU_Ace_Sense30_S_HTC_WWE_3.12.405.1_Radio_12.65.6 0.29_26.14.04.28_M_release_225512_signed.exe. Run this file and wait till extract (you'll see a bar going from left to right) and after that leave it as it is (don't click next or don't close the program)
B. Go to your PC temp folder. For win7 its C:\Users\<user name>\AppData\Local\Temp and for winXP its C:\Documents and Settings\<user name>\Local Settings\Temp and look for the last created folder. Open that.
C.
You'll get a rom.zip file there. Copy it to desktop or other suitable place. Now you can close the RUU program.
2. Rename the rom.zip file
A. You can't directly update the rom.zip file. You've to rename it according to your phone model number. Look for the model number in the serial sticker under battery. For Desire HD its PD98100, for Wildfire S its PG76100 etc. Take first four letter from this model number and then add IMG. So, for example for Desire HD rom.zip should be renamed as PD98IMG.zip and for Wildfire S it should be remaned as PG76IMG.zip
B. Now put this renamed file to a microSD card.
3. Update the ROM
A. Insert the card to microSD slot of the phone.
B. Power on the phone in HBOOT mode with microSD inserted. For most HTC android phones you have to press VolDown then Power to go to HBOOT mode. Wait for a while, phone will read the zip file and will ask you for update confirmaton. Read the screen instruction and press required button.
C. Update will start. Be patient and wait till being finished.
!!! CONGRATULATIONS !!! YOU'VE UPGRADED YOUR PHONE !!!
Common Errors:
* CID Incorrect : means you are trying wrong region ROM. Use correct region ROM or use Gold Card or make your phone superCID first.
* MODEL Incorrect : you're using other phone's ROM. you can't do it.
* Main Version Low : means phone's HBOOT version is higher than the ROM in your SD card. Use same or higher HBOOT rom's or S-OFF you phone.
The Following 45 Users Say Thank You to nasirahmed For This Useful Post:
Old 01-25-2013, 21:07   #2 (permalink)
nasirahmed's Avatar
Member: 57760
Sonork: 100.1579298
Thanks Meter: 3,482
Here is a comprehensive list of HTC Models and the names rom.zip should rename to
HTC Amage 4G PH85IMG.zip
HTC Aria(Liberty) LIBEIMG.zip
HTC ChaCha PH06IMG.zip
HTC Desire PB99IMG.zip
HTC Desire HD(Ace) PD98IMG.zip
HTC Desire S(Saga) PG88IMG.zip
HTC Desire V PL11IMG.zip
HTC Desire Z(Vision) PC10IMG.zip
HTC Dream(G1) DREAIMG.zip
HTC Droid2 Verizon(VivoW) PG32IMG.zip
HTC Droid DNA PL83IMG.zip
HTC Droid Eris PB00IMG.zip
HTC Espresso PB65IMG.zip / ESPRIMG.zip
HTC Evo 3D PG86IMG.zip
HTC Evo 4G PC36IMG.zip
HTC Evo Shift 4G PG06IMG.zip
HTC EvoView 4G PG41IMG.zip
HTC Explorer PJ03IMG.zip
HTC Flyer PG41IMG.zip
HTC myTouch 4G(Glacier) PD15IMG.zip
HTC Hero HEROIMG.zip
HTC Incredible HD(Mecha) PG05IMG.zip
HTC Incredible S(Vivo) PG32IMG.zip
HTC Inspire 4G PD98IMG.zip
HTC Jewel PJ75IMG.zip
HTC JetStream PG09IMG.zip
HTC Legend LEGEIMG.zip
HTC Magic(Sapphire) SAPPIMG.zip
HTC Merge(Lexicon) PD42IMG.zip
HTC Mini PB92IMG.zip
HTC One S PJ40IMG.zip
HTC One X PJ83IMG.zip
HTC One V PK76IMG.zip
HTC Paradise PC49IMG.zip
HTC Passion(Google Nexus One) PASSIMG.zip / PB99IMG.zip
HTC Radar PI06IMG.zip
HTC Rezound PH98IMG.zip
HTC Rhyme PI46IMG.zip
HTC Salsa PH11IMG.zip
HTC Sensation PG58IMG.zip
HTC SensationXL PI39IMG.zip
HTC Surround PD26IMG.zip
HTC Tatoo(Click) CLICIMG.zip
HTC Vivid 4G PH39IMG.zip
HTC Wildfire PC49IMG.zip
HTC Wildfire ADR6225 PD06IMG.zip
HTC Wildfire S PG76IMG.zip
The Following 8 Users Say Thank You to nasirahmed For This Useful Post:
Old 01-27-2013, 19:48   #3 (permalink)
riajul1988's Avatar
Member: 1511441
Sonork: 100.1604057
Thanks Meter: 1,150
Windows7 Ultimate
C:\Users\user\AppData\Local\Temp
The Following User Says Thank You to riajul1988 For This Useful Post:
Old 01-27-2013, 21:01   #4 (permalink)
Cheater -Don't Deal with him-
::gsmcoder::'s Avatar
Member: 172434
Sonork: 100.161280
Thanks Meter: 573
on windows 7 you can simply click start, run, type in the space %temp% and u will be in the right folder. observer the folder with long name like abcdbsgndghaaabdnaadb
set sort by date modfifed.
The Following User Says Thank You to ::gsmcoder:: For This Useful Post:
Old 01-28-2013, 13:47   #5 (permalink)
.:SUBRATA:.'s Avatar
Member: 319447
Thanks Meter: 4,942
@ ::gsmcoder::
This applies for XP too
Old 01-30-2013, 07:04   #6 (permalink)
INTERNATIONAL's Avatar
Member: 726409
Thanks Meter: 38
nasir sir where the all htc rom download plzzzzzzzzzz post link plzzzzzzzzzzzzzzzz sir
Old 01-30-2013, 07:32   #7 (permalink)
Member: 1175334
Sonork: cowboy
Thanks Meter: 22
you can download or HTC android ROMS here is the link...
Shipped ROMs
The Following 2 Users Say Thank You to cowboy_bebop For This Useful Post:
Old 01-31-2013, 17:14   #8 (permalink)
Member: 1519042
Thanks Meter: 35
thank you man for all this..
but i have htc explorer..when i have to restore with RUU.. I got an error 131
whats that mean
thaks
The Following User Says Thank You to zahaf27 For This Useful Post:
Old 01-31-2013, 17:23   #9 (permalink)
nasirahmed's Avatar
Member: 57760
Sonork: 100.1579298
Thanks Meter: 3,482
whats that mean
thaks
Please check here
http://forum.gsmhosting.com/vbb/f485...6/#post9154661
The Following User Says Thank You to nasirahmed For This Useful Post:
Old 02-02-2013, 22:38   #10 (permalink)
Member: 1525085
Sonork: basel
Thanks Meter: 2
Will this work on My ROOTED HTC cha cha with rom on it ?
thanx
The Following User Says Thank You to brotl For This Useful Post:
Old 02-03-2013, 14:03   #11 (permalink)
nasirahmed's Avatar
Member: 57760
Sonork: 100.1579298
Thanks Meter: 3,482
yes, it will work .
Old 02-03-2013, 15:19   #12 (permalink)
Member: 1032614
Thanks Meter: 46
Originally Posted by nasirahmed View Post
/// reserved ///
some roms can not be extracted. how is it possible to extract those roms? and where to download latest roms except (shipped-rom.com).
thanks for your nice tutorial
Old 02-03-2013, 18:07   #13 (permalink)
nasirahmed's Avatar
Member: 57760
Sonork: 100.1579298
Thanks Meter: 3,482
Can you please mention which rom you can't extract?
and
You can also directly update executing the RUU's directly
http://forum.gsmhosting.com/vbb/f485...e-ruu-1604796/
Old 02-03-2013, 22:32   #14 (permalink)
Member: 1525085
Sonork: basel
Thanks Meter: 2
the model number of My cha cha is it the SN ?
Does the extracted rom.zip makes my cha cha unrooted and the boot-loader lucked ?
thanx in advance .
Old 02-03-2013, 22:39   #15 (permalink)
Member: 1525085
Sonork: basel
Thanks Meter: 2
the model number of My cha cha is it the SN ? My SN :HT22NV400901
because I put the four digit of my SN but it didn't work ,So I tried PH06IMG.ZIP
the boot-loader recognized it
thanx in advance .
Page generated in 0.42291 seconds with 7 queries
