Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > HTC > HTC Android based
HTC Android based General HTC Android phones discussion, firmwares, solution, root, help
Old 02-03-2013, 22:50   #16 (permalink)
Member: 1525085
Sonork: basel
Thanks Meter: 2
my SN is HT22NV400901 . I tried to rename the extracted rom To HT22IMG.ZIP but the boot-loader didn't recognized it . So I tride PH06IMG.ZIP It did recognized it and asked me if I whant to upgrade ,Is this right ?
Old 02-04-2013, 07:14   #17 (permalink)
nasirahmed's Avatar
Member: 57760
Sonork: 100.1579298
Thanks Meter: 3,510
Originally Posted by brotl View Post
the model number of My cha cha is it the SN ? My SN :HT22NV400901
because I put the four digit of my SN but it didn't work ,So I tried PH06IMG.ZIP
the boot-loader recognized it
Does the extracted rom.zip makes my cha cha unrooted and the boot-loader lucked ?
thanx in advance .
I never said about serial number. You should take first four letter from model number. HTC Chacha rom.zip should be renamed as PH06IMG.zip
I'll try to post a full list of names what should be rom.zip renamed to.
The Following User Says Thank You to nasirahmed For This Useful Post:
Old 02-04-2013, 21:55   #18 (permalink)
Member: 1525085
Sonork: basel
Thanks Meter: 2
Bro .....
will my cha cha become unrooted ond the boot-loader lucked
Old 02-04-2013, 22:06   #19 (permalink)
nasirahmed's Avatar
Member: 57760
Sonork: 100.1579298
Thanks Meter: 3,510
It will go back to stock, that means unrooted. And I think you can't go through these steps unless you relock the bootloader.
Old 02-06-2013, 13:13   #20 (permalink)
Member: 1769339
Sonork: 100.1627057
Thanks Meter: 13
Originally Posted by nasirahmed View Post
1. Extract rom.zip from an RUU
A. Run the RUU. For example, you want to update your Desire HD with RUU_Ace_Sense30_S_HTC_WWE_3.12.405.1_Radio_12.65.6 0.29_26.14.04.28_M_release_225512_signed.exe. Run this file and wait till extract (you'll see a bar going from left to right) and after that leave it as it is (don't click next or don't close the program)
B. Go to your PC temp folder. For win7 its C:\Users\<user name>\AppData\Local\Temp and for winXP its C:\Documents and Settings\<user name>\Local Settings\Temp and look for the last created folder. Open that.
C.
You'll get a rom.zip file there. Copy it to desktop or other suitable place. Now you can close the RUU program.
2. Rename the rom.zip file
A. You can't directly update the rom.zip file. You've to rename it according to your phone model number. Look for the model number in the serial sticker under battery. For Desire HD its PD98100, for Wildfire S its PG76100 etc. Take first four letter from this model number and then add IMG. So, for example for Desire HD rom.zip should be renamed as PD98IMG.zip and for Wildfire S it should be remaned as PG76IMG.zip
B. Now put this renamed file to a microSD card.
3. Update the ROM
A. Insert the card to microSD slot of the phone.
B. Power on the phone in HBOOT mode with microSD inserted. For most HTC android phones you have to press VolDown then Power to go to HBOOT mode. Wait for a while, phone will read the zip file and will ask you for update confirmaton. Read the screen instruction and press required button.
C. Update will start. Be patient and wait till being finished.
!!! CONGRATULATIONS !!! YOU'VE UPGRADED YOUR PHONE !!!
Common Errors:
* CID Incorrect : means you are trying wrong region ROM. Use correct region ROM or use Gold Card or make your phone superCID first.
* MODEL Incorrect : you're using other phone's ROM. you can't do it.
* Main Version Low : means phone's HBOOT version is higher than the ROM in your SD card. Use same or higher HBOOT rom's or S-OFF you phone.
is glod card required ?
Old 02-07-2013, 03:11   #21 (permalink)
nasirahmed's Avatar
Member: 57760
Sonork: 100.1579298
Thanks Meter: 3,510
When you are using different CID firmware, when your phone is not superCID, you'll need GoldCard.
Old 03-08-2013, 08:17   #22 (permalink)
Member: 1291309
Thanks Meter: 58
brother tell me 1st i wanna flash this set htc Exploler
verify that you want to update the room version
Frome :
image virgen 1.43.720.2
To
image vergin 1.17.479.2
so tell me dis vergn file i m uplod so koi risk tho nahi hai na sir
Old 03-08-2013, 08:20   #23 (permalink)
Rahul_Bhutani's Avatar
Member: 1713856
Sonork: Uninstalled
Thanks Meter: 4,500
Frome :
To
don't make double post,i already reply you.
http://forum.gsmhosting.com/vbb/f485...ml#post9251823
Old 03-10-2013, 14:20   #24 (permalink)
Member: 1897538
I have HTC legend , s-on, HBOOT-1.02 and i unlock it on HTC bootloader
and when i install ROM it says:
signature verification failed
installation aborted
could any one help me
Old 03-10-2013, 14:38   #25 (permalink)
nasirahmed's Avatar
Member: 57760
Sonork: 100.1579298
Thanks Meter: 3,510
Relock bootloader and try again.
Old 03-10-2013, 14:50   #26 (permalink)
Member: 1713856
Sonork: Uninstalled
Thanks Meter: 4,500
you are installing custom rom with stock reocovery?
Old 03-29-2013, 16:06   #27 (permalink)
Member: 1908437
Drained Battery results in Boot Loop of Death ...HELP!!!
C.
3. Update the ROM
Common Errors:
Upon battery approaching 0%, while on a phone call, phone shut down. Immediately inserted charger and tried to start phone.
Phone went into a boot loop and is stuck unless battery is removed.
I am thinking that a ROM Update might do the trick, but I am fuzzy in some areas:
1.) Is a ROM Update Non-Volatile? In other words, will my data both on the SD-Card and on the ROM, remain intact?
2.) Can I do the update without rooting the phone?
3.) Can I do the ROM update using the Update.zip method from the SD-Card?
4.) What are the various PC36 DIAG & IMG files, and how do they play into not being able to turn on the phone
5.) What about the message below, regarding: E:Can't open /cache/recovery/command ?
6.) Do I need to use an RUU?
7.) And most importantly, where do I get the most recent update for my phone, which I suspect is Gingerbread 5.07.651.1 710RD?
Model# PC36100
on the Inside of the phone, on Red Tape - SC-01 - 10/07/2012
UNROOTED, AND NEVER ROOTED
Booted into Android System Recovery (ASR) HBOOT
Ran FastBoot
Went into Recovery Mode
Green Arrows stay on screen.
Upon pressing [Volume Up] and then [Power] , I get:
ROM Details
*** Locked (OOW) ***
SUPERSONIC EVT3 SHIP S-ON
HBOOT-2.18.0001
MICROP-041f
TOUCH PANEL-ATMEL224_16ab
RADIO-2.15.00.01.15
Dec 21, 2011, 12:50:32
SD Checking
Loading PC36DIAG.ZIP
No Image!
Loading PC36DIAG.NHH
No Image or Wrong Image!
Loading PC36IMG.ZIP
No Image!
Loading PC36IMG.NHH
Old 07-20-2013, 07:42   #28 (permalink)
Member: 1982449
I did it to my HTC one V (already installed clockworkmod) but it said no img detected
Old 08-02-2013, 13:22   #29 (permalink)
Member: 1900437
Thanks Meter: 113
Will that work with my HTC Desire S?:? It's just that I am lil bit confused about such things and don't want any mess with my phone. So if someone over here has done that with Desire S, please share the results. Waiting for a reply
Old 02-21-2014, 18:53   #30 (permalink)
Member: 1769933
Sonork: shamimshroff
My HTC wild fire a3333 its shows s- on what's mean I don't understn please help set always get restarteda
Page generated in 0.24228 seconds with 8 queries
