Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > HTC > HTC Android based
HTC Android based General HTC Android phones discussion, firmwares, solution, root, help
Old 01-25-2013, 17:15   #1 (permalink)
nasirahmed's Avatar
Member: 57760
Sonork: 100.1579298
Thanks Meter: 3,461
[Guide] How to upgrade your HTC Android Phone with RUU
RUU stands for ROM Update Utility. In general the update procedure is, install HTC Driver, Connect your phone to Computer in Normal Mode or Fastboot Mode, Run the RUU and follow instructions showing on software. But it will work only when you are using same CID ROM, or your phone is superCID or you're using goldcard. Here I'll try to describe the update procedure in different conditions.
Determine Your Phnoe CID
CID stands for Customer ID. HTC implemented this check to prevent flashing other region firmwares. For example, if you have a phone which CID belongs to Singapore, you normally can't update ROM from other region like EURO/USA/CHINA etc. You've to use same region firmware. Remeber that, SIMLOCK is not related to CID, if you sim unlock a phone still you may not be able to flash other region ROM. But unlocking tools like XTC, HXC etc does CID unlock too as well as SIM unlock. To Determine your phone's CID I've made a small script. Download getcid.rar from attachment, extract, connect the phone to Computer in Fastboot Mode, run getcid.bat. It'll show phone's current CID.
SUPER CID
Super CID is a Universal CID. If your phone has superCID, you can flash any ROM from any region. To make your phone superCID, you must S-OFF your phone. Please visit our S-OFF Discussion if you don't have already. After you have succesfully S-OFF your phone use the supercid script (check attachment) to get superCID. Download supercid.rar, extract, connect the phone in Fastboot Mode to Computer, run suerpcid.bat and its done. Now you can flash any ROM.
CHANGE CID
Another method is Changing the CID (if you don't want superCID). Still you need S-OFF to do that. After you've successfully S-OFF your phone, send this commant in Fastboot mode fastboot oem writecid CIDNAME. For example you have e phone from a CID from UK and now you want to flash it with a German ROM which CID is HTC__102. To change the CID, your command will be fastboot oem writecid HTC__102
GOLD CARD
Its another method to flash different region ROM and you don't need S-OFF or superCID. Gold Card is a special microSD card that will turn your phone into temporary superCID state when it is inserted. With GoldCard you can flash only same or higher hboot version ROM's. You can use revskills, XTC Clip, HXC Dongle, AXE Box, Micro Box, LGE Tool etc to make GoldCard's for different models. After you've made a GoldCard, insert it to your phone, connect your phone to Compuer in normal mode or fastboot mode and run desired ROM as usual. CID check will be skipped.
WARNING : we have mentioned some professional tools like XTC Clip, HXC Dongle, AXE Box, Micro Box, LGE Tool etc just for reference. This is not the support section for them, rather they have different sections/forums and dedicated supporters are there to help you. So if you have any questions/problems operating those tools please post in their own forum.
The Following 26 Users Say Thank You to nasirahmed For This Useful Post:
Old 01-31-2013, 14:12   #2 (permalink)
nasirahmed's Avatar
Member: 57760
Sonork: 100.1579298
Thanks Meter: 3,461
Common RUU Errors:
Error 120 : Main Battery Low Charge your phone to 30% or more and try again.
Error 131 : Customer ID Error You are trying wrong region rom. Make superCID or use GoldCard.
Error 155 : Unknown Error if bootloader is unlocked, relock it (fastboot oem lock) and try RUU again.
Error 140 : Bootloader Version Error
The Following 5 Users Say Thank You to nasirahmed For This Useful Post:
Old 02-07-2013, 07:01   #3 (permalink)
ihsan.khan.gsm's Avatar
Member: 1489021
Sonork: 100.1620946
Thanks Meter: 708
bro its possible window to adoried
Old 02-08-2013, 09:31   #4 (permalink)
shinod's Avatar
Member: 55363
Thanks Meter: 146
htc one x phone cid HTC_038 where can i get full firmware please help me
The Following User Says Thank You to shinod For This Useful Post:
Old 02-08-2013, 11:32   #5 (permalink)
RIJAS2010's Avatar
Member: 1417101
Sonork: 100.1619006
Thanks Meter: 152
this is nice info ..
but i have one problem sir . i have one htc g1 . need to enter in fastboot mode.. i dont know about this ... so pls help me nasirahmed
thanks
Old 02-08-2013, 11:37   #6 (permalink)
Member: 59185
Sonork: 100.1593175
Thanks Meter: 4,830
[Q] [REQUEST URGENTLY] RUU htc India CID: htc_038 version: 2.17.720.2 - xda-developers
The Following 4 Users Say Thank You to lalitjsraks For This Useful Post:
Old 02-12-2013, 10:35   #7 (permalink)
..::HaCkEr::..'s Avatar
Member: 1370494
Sonork: dont have
Thanks Meter: 34
need rom for htc one x cid ,,,, j15 ,,,, plz ??
The Following User Says Thank You to ..::HaCkEr::.. For This Useful Post:
Old 02-23-2013, 03:20   #8 (permalink)
Member: 1798786
Originally Posted by nasirahmed View Post
Common RUU Errors:
Thanks a lot.
I was keep getting error 155 on HTC ONE S.I searched everywhere without success.
you're life saver.
Old 04-09-2013, 05:54   #9 (permalink)
Cheater -Don't Deal with him-
Member: 452256
Sonork: 100.1651051
Thanks Meter: 583
right man in the right place thanks nasirahmed
i have problem with my HTC ONE S my phone is s-on and i relocked it but i face always the same error 155 when am check my CID its H3G__001 so i used this tow ruu roms
RUU_Ville_U_H3G_UK_1.53.771.4_Radio_0.15.31501S.19 _2_10.13.31501S.06L_release_251870_signed
RUU_Ville_U_H3G_UK_1.78.771.5_Radio_0.16.31501S.19 _2_10.23.31501S.10L_release_258982_signed
and always same error 155
what is problem or how can i solve this error ?
Old 04-09-2013, 08:54   #10 (permalink)
Member: 452256
Sonork: 100.1651051
Thanks Meter: 583
this is my phone info ...
(bootloader) version: 0.5
(bootloader) version-bootloader: 2.13.0000
(bootloader) version-baseband: 1.11.50.05.28
(bootloader) version-cpld: None
(bootloader) version-microp: None
(bootloader) version-main:
(bootloader) version-misc: PVT SHIP S-ON
(bootloader) serialno: HT241W407245
(bootloader) imei: 359901042273546
(bootloader) product: vle
(bootloader) platform: HBOOT-8960
(bootloader) modelid: PJ4010000
(bootloader) cidnum: H3G__001
(bootloader) battery-status: good
(bootloader) battery-voltage: 4085mV
(bootloader) partition-layout: Generic
(bootloader) security: on
(bootloader) build-mode: SHIP
(bootloader) boot-mode: FASTBOOT
(bootloader) commitno-bootloader: dirty-26dff973
(bootloader) hbootpreupdate: 11
(bootloader) gencheckpt: 0
Old 04-09-2013, 14:57   #11 (permalink)
nasirahmed's Avatar
Member: 57760
Sonork: 100.1579298
Thanks Meter: 3,461
relock bootloader and try again.
fastboot oem relock
The Following User Says Thank You to nasirahmed For This Useful Post:
Old 04-09-2013, 17:34   #12 (permalink)
Member: 452256
Sonork: 100.1651051
Thanks Meter: 583
fastboot oem relock
thanks bro for reply but am already re lock boot loader but same
Old 04-12-2013, 07:32   #13 (permalink)
Rahul_Bhutani's Avatar
Member: 1713856
Sonork: Uninstalled
Thanks Meter: 4,442
just unlock bootloader again.
flash stock recovery,and boot vie fastboot.
relock bootloader,and run ruu.
yeah no more error
Old 05-10-2013, 11:13   #14 (permalink)
Member: 840253
Sonork: shuvo007
Thanks Meter: 8
[QUOTE=nasirahmed;9154661]Common RUU Errors:
i fully charged bt but same problem pls help............
Old 05-11-2013, 17:49   #15 (permalink)
s a dot com's Avatar
Member: 1779651
Sonork: 100.1603336
Thanks Meter: 84
sir how we know the file which cid
and how we get htc phone cid?
Page generated in 0.42137 seconds with 8 queries
