HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
03-02-2014, 08:28 | #46 (permalink) |
No Life Poster Join Date: Mar 2012 Location: gsm world
Member: 1741973 Status: Offline Thanks Meter: 115 | Microsoft Windows XP [Version 5.1.2600] (C) Copyright 1985-2001 Microsoft Corp. C:\Documents and Settings\Android-PC>fastboot getvar all INFOversion: 0.5 INFOversion-bootloader: 2.00.0002 INFOversion-baseband: 3822.10.08.04_M INFOversion-cpld: None INFOversion-microp: None INFOversion-main: 13.10.401.8 INFOserialno: SH164TJ04299 INFOimei: 356708049732868 INFOproduct: saga INFOplatform: HBOOT-7230 INFOmodelid: PG8810000 INFOcidnum: HTC__Y13 INFObattery-status: good INFObattery-voltage: 3918mV INFOpartition-layout: Generic INFOsecurity: on INFObuild-mode: SHIP INFOboot-mode: FASTBOOT INFOcommitno-bootloader: ebd3df7d INFOhbootpreupdate: 12 INFOgencheckpt: 0 all: Done! finished. total time: 0.016s C:\Documents and Settings\Android-PC>fastboot oem lock ... INFODevice was already locke OKAY [ 0.000s] finished. total time: 0.000s i tried to flash with same firmware as indicated on the baseband that phone have it.. but the result is customer ID error... CID mismatch.. any ways to create a gold card for this? revskills website is not responding |
10-16-2014, 11:19 | #48 (permalink) |
Junior Member Join Date: Oct 2014
Member: 2275142 Status: Offline Thanks Meter: 0 | pls i need either the original or the higher original rom for this htc one v below is the make up (bootloader) version: 0.5 (bootloader) version-bootloader: 1.18.0000 (bootloader) version-baseband: 3831.24.01.30_M (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: (bootloader) serialno: HT23STV12357 (bootloader) imei: 351816051631228 (bootloader) product: primou (bootloader) platform: HBOOT-7230 (bootloader) modelid: PK761**** (bootloader) cidnum: 11111111 (bootloader) battery-status: good (bootloader) battery-voltage: 3994mV (bootloader) partition-layout: Generic (bootloader) security: off (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: 8591a55c (bootloader) hbootpreupdate: 12 (bootloader) gencheckpt: 0 all: Done! |
10-18-2014, 17:03 | #50 (permalink) | |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Quote:
11-06-2014, 18:56 | #52 (permalink) | |
CID, main version & product id read using tis tool http://forum.gsmhosting.com/vbb/f485...eased-1789408/ put yur mob in bootloader mode run the tool read boot info post detail | |
12-14-2014, 07:26 | #55 (permalink) |
No Life Poster Join Date: Oct 2010 Location: India Age: 31
Member: 1713856 Status: Offline Sonork: Uninstalled Thanks Meter: 4,500 | @elpring Simple download ruu for your phone. If phone is frmo tmob use tmobile rom,otherwise use any and before flash make phone hard spl. You can get rom here : Shipped ROMs |
02-03-2015, 14:45 | #57 (permalink) |
Freak Poster Join Date: Apr 2012
Member: 1745548 Status: Offline Thanks Meter: 85 | - Recovery Not Working - Stuck on HTC Logo Bro Recovery twrp not working "entering recovery..." try to flash recovery twrp all version htc_621 but no luck, is there any way or method i can fix this phone?..or Correct RUU for this model? Model : M7CDWG Build : 4.25.500.2 CID : HTC__621 HBoot : 2.49.0000 MID : PN0751000 Security : ON Region : TWM-TW |
02-16-2015, 11:19 | #59 (permalink) |
Junior Member Join Date: Sep 2010
Member: 1402834 Status: Offline Thanks Meter: 1 | Sir please , I have a problem with htc desire 300 , can not lock bootloader.Bootloader is unlocked but can not insert CWM When an I light it goes directly into fastboot mode . Freeze on htc logo .. |
The Following User Says Thank You to Kameni_38 For This Useful Post: |
05-26-2015, 10:53 | #60 (permalink) |
Junior Member Join Date: May 2015
Member: 2399461 Status: Offline Thanks Meter: 3 | need working RUU for kddi au htc j butterfly htl 21. heres me device info: *** LOCKED *** DELUXE_J PVT SHIP S-ON HBOOT-1.39.0000 RADIO-1.00.10.1127_3 OpenDSP-v5.120.240.1123 eMMC-boot Nov 29 2012, 15:56:09:16651 the device is stucked in bootloop so there is no way for me to enable usb debugging via the phone. i can however enter the bootloader and do the fastboot commands via cmd. only the adb does not work because it does not detect the device. i believe it is because of the usb debugging option not being enabled. i need some help with this. thank you. |
