Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > HTC > HTC Android based
HTC Android based General HTC Android phones discussion, firmwares, solution, root, help
Old 01-28-2015, 21:23   #76 (permalink)
Member: 1984599
Sonork: PM For Sonork Id ;P
Thanks Meter: 37
Puh..Tried Almost Thousand times to S-OFF But Failed..I m currently On Custom rom Given in this Thread And Now I Want to Get Back to Stock -
Hboot Is 1.57
CID is ROGER001
Android Version before installing Custom was 4.4 Kitkat
Now I Have Official OTA update file of My Mobile CID in zip
I want to Install It So I need help to Install My Stock Firmware
Note : What i Tried to get back to Stock
I Extracted recovery from OTA file then flashed thrgh fastboot - successfully flashed then when i go into recovery mode there is no option to install from internal/external storage- Only four option giving
Bootloader locked And TAMPERED
Old 01-28-2015, 22:50   #77 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
@server22,
you are with Locked Bootloader and S-ON, if i've understand good you want turn back to another version?, anyway post here you "Getvar all"
allumts
Old 01-30-2015, 14:19   #78 (permalink)
Member: 1984599
Thanks Meter: 37
D:\Android develpoment>fastboot getvar all
(bootloader) version: 0.5
(bootloader) version-bootloader: 1.57.0000
(bootloader) version-baseband: 4T.27.3218.14
(bootloader) version-cpld: None
(bootloader) version-microp: None
(bootloader) version-main:
(bootloader) version-misc: PVT SHIP S-ON
(bootloader) serialno: MB419W906413
(bootloader) imei: 354xxxxxxxxxxxx
(bootloader) meid: 00000000000000
(bootloader) product: m7_ul
(bootloader) platform: HBOOT-8064
(bootloader) modelid: PN0712000
(bootloader) cidnum: ROGER001
(bootloader) battery-status: good
(bootloader) battery-voltage: 4237mV
(bootloader) partition-layout: Generic
(bootloader) security: on
(bootloader) build-mode: SHIP
(bootloader) boot-mode: FASTBOOT
(bootloader) commitno-bootloader: dirty-e47fb74b
(bootloader) hbootpreupdate: 11
(bootloader) gencheckpt: 0
all: Done!
finished. total time: 0.047s
Old 01-30-2015, 21:54   #79 (permalink)
allumts's Avatar
Member: 1564612
all: Done!
@server22,
have put you all these 0000000000000 marked in red or it's show from you "Getvar all"?
You have wrong flashing only recovery from OTA official.
Have tryed pushing TWRP?
Ok, do a Nandroid BKP first
try copyng this Zip in one Sd card
Put Sd Card in Otg Usb
From recorery mode (clean good from C.Rom) then flash this Zip from Usb Otg
let me know
allumts
Old 01-30-2015, 23:56   #80 (permalink)
Member: 1984599
Thanks Meter: 37
Originally Posted by allumts View Post
@server22,
let me know
allumts
No I just edited imei.. Meid shows 000000 only in getvar all
OK I will and let you know
Old 01-31-2015, 21:46   #81 (permalink)
allumts's Avatar
Member: 1564612
SMALL TIP WITH MY VERSION OF "FIREWATER" FOR GAIN S-OFF
DOWNLOAD FROM HERE THIS VERSION: Firewater.Rar
If have "Sinc Error" or not Gain you S-OFF often is becouse you use Old Version and not Full from above link, (Now also becouse Firewater is ...Down???? ).
Try in this mode:
Before all process don't forget to change your phone date to 28/01/2014.
Also uncheck " automatic date &time " update option.
The procedure is the same in first page, change the ROM, KERNEL, TWRP used becouse are OLD.
STEPS:
Prepare phone for FIREWATER<<<<<IMPORTANT
1. unlock bootloader
2. custom recovery cwm or any
3. root
4. flashing this faux123 kernel m7-faux123-SENSE44-009u.zip (the cel have battery problem ignore this)
5. make s-off firewater the process is done yes done you are s-off
6. flashing this faux123 kernel m7-faux123-SENSE442-016u.zip is all the cel is ok not custom rom not cyanomod all is ok
LINK:
faux123 kernel for s-0ff htc m7 4.4.2
NOTE: This is only one ATTEMPT and NOT warranty that work with ALL M7, (the most recent think of no), and NO for M8, in one M7_ul CID: H3G_ITA has worked.
good lucky
Use only thank button
allumts
Old 02-07-2015, 16:42   #82 (permalink)
ndagi's Avatar
Member: 18926
Sonork: ndagi
Thanks Meter: 52
Try in this mode:
STEPS:
3. root
LINK:
good lucky
allumts
hi , followed your process and firewater is just like this (still moving dots) in the last 45 minutes is this normal?
==================== firewater S-OFF 8.0.9.10 ===========================
firewater S-OFF comes with NO WARRANTY (express or implied)
and NO GUARANTEE OF FITNESS for any particular task.
We have made every effort we can to make this a safe process for users
however the authors disclaim any liability for damage to your phone
or other materials or devices used during this process.
The entire risk of running firewater S-OFF lies with you, the user.
By using this software you acknowledge and accept that the authors
are not liable for any loss, material or otherwise howsoever caused.
firewater S-OFF may not be rehosted, repackaged, one-clicked, etc.
support is available @ #firewater on the freenode and andirc networks
support is much faster there vs. posting helpme threads on xda etc
Do not operate a motor vehicle after interacting with firewater
Do not inhale firewater or allow firewater to come in contact with eyes
firewater is best served at extremely cold temperatures
firewater has been known to cause temporary lapses in judgement
DO NOT TAUNT FIREWATER, YOU'VE BEEN WARNED
Do you understand the implications of these warnings?
(Yes/No)
Yes
Yes
!!If firewater hangs for more than 2 minutes or device enters qhusb mode, h
ld power for 60 seconds !!
Old 02-07-2015, 19:03   #83 (permalink)
allumts's Avatar
Member: 1564612
No, isn't normal, know that "Firewater" is Down now, but in some version of M7 (not recent), when get "Sinc Error" this Tip has worked, but Not for All and not always is just a attempt.
Listen me, use "SUNSHINE" and you gain S-OFF for sure 100%, not is free, but in alternative there's all Java Card, so you want to buy Java Card more good????, (it's not is chip price, i use this but becouse in my shop enter many HTC all models.
allumts
Old 02-12-2015, 06:07   #84 (permalink)
Member: 2050764
Originally Posted by marc84 View Post
Ok, I was able to finally get this to work. Some info in case it helps anyone:
HBOOT 1.57
T-Mobile One M7
cm-11-20140106-NIGHTLY-m7tmo
teaMseven_v57_CM11_CPUQUIET_BACK_MENU_HOME
Did as above, although firewater failed the first few times. I rebooted and kept trying, third time was successful. My phone is now s-off
Can you give me advise. I've been trying custom recovery but no luck. I tried CW and TWRP but I just get stuck at "Entering Recovery". any Ideas? Thanks.
Old 02-13-2015, 11:45   #85 (permalink)
allumts's Avatar
Member: 1564612
@amilayajr,
why you not read Post Data and all update?, not search more of to trye with "Firewater" becouse this is "Down Server" from his development.
You read post of 9/10 mounths ago and NOT read last post with all update.
Only "SunShine" work for get S-OFF or too much high price only for one phone, with "Java Card" no other solution.
Here in 10 sec. with Java Card:
allumts
Old 03-14-2015, 19:56   #86 (permalink)
Member: 2228558
Thanks Meter: 4
does any one know if this would work with Rumrunner since firewater is discontinued?
Old 03-14-2015, 20:54   #87 (permalink)
Member: 2228558
Thanks Meter: 4
C:\Users\Angel\Desktop\HTC One M7 4.4.2 S OFF\HTC One M7 4.4.2\firewater F
or S-Off & ADB Package>adb reboot
or S-Off & ADB Package>adb wait-for-device push firewater /data/local/tmp
3593 KB/s (4522136 bytes in 1.229s)
or S-Off & ADB Package>adb shell
shell@m7ul:/ $ su
su
root@m7ul:/ # chmod 755 /data/local/tmp/firewater
root@m7ul:/ # /data/local/tmp/firewater
root@m7ul:/ #
Old 03-14-2015, 21:00   #88 (permalink)
Member: 2228558
Thanks Meter: 4
it didn't work with Firewater I have the HTC One M7 AT&T bootloader unlocked, H.BOOT 1.57
I flashed the combo ROM plus Kernel together then Boot.img phone connceted to the internet so it's my computer, no screen lock, display active for 30 mins, USB debugging on, phone rooted what am I missing?
Old 03-14-2015, 21:01   #89 (permalink)
Member: 2228558
Thanks Meter: 4
I wanna achieve SIM unlock via SD Card already have the OTG cable but I need S-Off for this
Old 03-14-2015, 22:11   #90 (permalink)
allumts's Avatar
Member: 1564612
@prz0007, not spam more this thread.
No waste more time with "Firewater" or other FREE method, "Firewater" is Dead.
Is all explained clear above, No FREE method, ok?
For gain you S-OFF in this HTC can use only "SunShine.Apk" ...Payment service..the most chip method...other way is "Java Card" but not think you buy one of this for only one M7...
allumts
Page generated in 0.26234 seconds with 9 queries
