HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
01-28-2015, 21:23 | #76 (permalink) |
Freak Poster Join Date: Jul 2013 Location: A Planet Called Earth Age: 34
Member: 1984599 Status: Offline Sonork: PM For Sonork Id ;P Thanks Meter: 37 | Hboot Is 1.57 CID is ROGER001 Android Version before installing Custom was 4.4 Kitkat Now I Have Official OTA update file of My Mobile CID in zip I want to Install It So I need help to Install My Stock Firmware Note : What i Tried to get back to Stock I Extracted recovery from OTA file then flashed thrgh fastboot - successfully flashed then when i go into recovery mode there is no option to install from internal/external storage- Only four option giving Bootloader locked And TAMPERED |
01-28-2015, 22:50 | #77 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @server22, you are with Locked Bootloader and S-ON, if i've understand good you want turn back to another version?, anyway post here you "Getvar all" BR allumts |
01-30-2015, 14:19 | #78 (permalink) |
Member: 1984599 Status: Offline Sonork: PM For Sonork Id ;P Thanks Meter: 37 | D:\Android develpoment>fastboot getvar all (bootloader) version: 0.5 (bootloader) version-bootloader: 1.57.0000 (bootloader) version-baseband: 4T.27.3218.14 (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: (bootloader) version-misc: PVT SHIP S-ON (bootloader) serialno: MB419W906413 (bootloader) imei: 354xxxxxxxxxxxx (bootloader) meid: 00000000000000 (bootloader) product: m7_ul (bootloader) platform: HBOOT-8064 (bootloader) modelid: PN0712000 (bootloader) cidnum: ROGER001 (bootloader) battery-status: good (bootloader) battery-voltage: 4237mV (bootloader) partition-layout: Generic (bootloader) security: on (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: dirty-e47fb74b (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 all: Done! finished. total time: 0.047s |
01-30-2015, 21:54 | #79 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
have put you all these 0000000000000 marked in red or it's show from you "Getvar all"? You have wrong flashing only recovery from OTA official. Have tryed pushing TWRP? Ok, do a Nandroid BKP first try copyng this Zip in one Sd card Put Sd Card in Otg Usb From recorery mode (clean good from C.Rom) then flash this Zip from Usb Otg let me know BR allumts | |
01-30-2015, 23:56 | #80 (permalink) | |
Member: 1984599 Status: Offline Sonork: PM For Sonork Id ;P Thanks Meter: 37 | Quote:
OK I will and let you know | |
01-31-2015, 21:46 | #81 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | SMALL TIP WITH MY VERSION OF "FIREWATER" FOR GAIN S-OFF DOWNLOAD FROM HERE THIS VERSION: Firewater.Rar If have "Sinc Error" or not Gain you S-OFF often is becouse you use Old Version and not Full from above link, (Now also becouse Firewater is ...Down???? ). Try in this mode: Before all process don't forget to change your phone date to 28/01/2014. Also uncheck " automatic date &time " update option. The procedure is the same in first page, change the ROM, KERNEL, TWRP used becouse are OLD. STEPS: Prepare phone for FIREWATER<<<<<IMPORTANT 1. unlock bootloader 2. custom recovery cwm or any 3. root 4. flashing this faux123 kernel m7-faux123-SENSE44-009u.zip (the cel have battery problem ignore this) 5. make s-off firewater the process is done yes done you are s-off 6. flashing this faux123 kernel m7-faux123-SENSE442-016u.zip is all the cel is ok not custom rom not cyanomod all is ok LINK: faux123 kernel for s-0ff htc m7 4.4.2 m7-faux123-SENSE44-009u.zip m7-faux123-SENSE442-016u.zip NOTE: This is only one ATTEMPT and NOT warranty that work with ALL M7, (the most recent think of no), and NO for M8, in one M7_ul CID: H3G_ITA has worked. good lucky Use only thank button BR allumts |
02-07-2015, 16:42 | #82 (permalink) | |
No Life Poster Join Date: Dec 2002 Location: nigeria
Member: 18926 Status: Offline Sonork: ndagi Thanks Meter: 52 | Quote:
==================== firewater S-OFF 8.0.9.10 =========================== firewater S-OFF comes with NO WARRANTY (express or implied) and NO GUARANTEE OF FITNESS for any particular task. We have made every effort we can to make this a safe process for users however the authors disclaim any liability for damage to your phone or other materials or devices used during this process. The entire risk of running firewater S-OFF lies with you, the user. By using this software you acknowledge and accept that the authors are not liable for any loss, material or otherwise howsoever caused. firewater S-OFF may not be rehosted, repackaged, one-clicked, etc. support is available @ #firewater on the freenode and andirc networks support is much faster there vs. posting helpme threads on xda etc Do not operate a motor vehicle after interacting with firewater Do not inhale firewater or allow firewater to come in contact with eyes firewater is best served at extremely cold temperatures firewater has been known to cause temporary lapses in judgement DO NOT TAUNT FIREWATER, YOU'VE BEEN WARNED ================================================== ======================= Do you understand the implications of these warnings? (Yes/No) Yes Yes !!If firewater hangs for more than 2 minutes or device enters qhusb mode, h !!If firewater hangs for more than 2 minutes or device enters qhusb mode, h !!If firewater hangs for more than 2 minutes or device enters qhusb mode, h ld power for 60 seconds !! .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... .................................................. .......... | |
02-07-2015, 19:03 | #83 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | No, isn't normal, know that "Firewater" is Down now, but in some version of M7 (not recent), when get "Sinc Error" this Tip has worked, but Not for All and not always is just a attempt. Listen me, use "SUNSHINE" and you gain S-OFF for sure 100%, not is free, but in alternative there's all Java Card, so you want to buy Java Card more good????, (it's not is chip price, i use this but becouse in my shop enter many HTC all models. BR allumts |
02-12-2015, 06:07 | #84 (permalink) | |
Junior Member Join Date: Oct 2013
Member: 2050764 Status: Offline Thanks Meter: 1 | Quote:
02-13-2015, 11:45 | #85 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @amilayajr, why you not read Post Data and all update?, not search more of to trye with "Firewater" becouse this is "Down Server" from his development. You read post of 9/10 mounths ago and NOT read last post with all update. Only "SunShine" work for get S-OFF or too much high price only for one phone, with "Java Card" no other solution. Here in 10 sec. with Java Card: BR allumts Last edited by allumts; 02-13-2015 at 11:50. |
03-14-2015, 20:54 | #87 (permalink) |
Freak Poster Join Date: Jul 2014
Member: 2228558 Status: Offline Thanks Meter: 4 | C:\Users\Angel\Desktop\HTC One M7 4.4.2 S OFF\HTC One M7 4.4.2\firewater F or S-Off & ADB Package>adb reboot C:\Users\Angel\Desktop\HTC One M7 4.4.2 S OFF\HTC One M7 4.4.2\firewater F or S-Off & ADB Package>adb wait-for-device push firewater /data/local/tmp 3593 KB/s (4522136 bytes in 1.229s) C:\Users\Angel\Desktop\HTC One M7 4.4.2 S OFF\HTC One M7 4.4.2\firewater F or S-Off & ADB Package>adb shell shell@m7ul:/ $ su su root@m7ul:/ # chmod 755 /data/local/tmp/firewater chmod 755 /data/local/tmp/firewater root@m7ul:/ # /data/local/tmp/firewater /data/local/tmp/firewater root@m7ul:/ # |
03-14-2015, 21:00 | #88 (permalink) |
Member: 2228558 Status: Offline Thanks Meter: 4 | it didn't work with Firewater I have the HTC One M7 AT&T bootloader unlocked, H.BOOT 1.57 I flashed the combo ROM plus Kernel together then Boot.img phone connceted to the internet so it's my computer, no screen lock, display active for 30 mins, USB debugging on, phone rooted what am I missing? |
03-14-2015, 22:11 | #90 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @prz0007, not spam more this thread. No waste more time with "Firewater" or other FREE method, "Firewater" is Dead. Is all explained clear above, No FREE method, ok? For gain you S-OFF in this HTC can use only "SunShine.Apk" ...Payment service..the most chip method...other way is "Java Card" but not think you buy one of this for only one M7... BR allumts |
