HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
06-25-2014, 11:06 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Algérie Age: 43
Member: 570252 Status: Offline Thanks Meter: 207 | HELP to flash arabic rom to Wildfire S unlocked boot loader with htcdev and rooted and flashed boot.img and system.img via fastboot but not working i'v try multi tools to get super cid but cant get it Code: -------------------------------------------- Starting.. Searching Phone ...( Found ) Reading Info... -------------------------------------------- Manufacturer : HTC Model : marvel Build Id : GRI40 Id : GRI40 BaseBand Ver. : 47.23a.35.3035H_7.53.39.03M Android Ver. : 2.3.3 Region : Locale : mdpi Chipset : msm7k Hw Version : marvel Cpu : ARMv6 Cpu Implementer : 0x41 Cpu Architecture : 6TEJ Cpu Variant : 0x1 Cpu Part : 0xb36 Cpu Revision : 5 Kernal Ver. : 2.6.35.10-g60b2609 -------------------------------------------- Root Status : Not Rooted - :( -------------------------------------------- All Done.. Operation Log Saved.. Code: -------------------------------------------- Starting.. Searching Phone ...( Found ) Reading Info... -------------------------------------------- product: marvel version: 0.5 serialno: SH16XTR02245 cid: VODAP203 -------------------------------------------- INFOversion: 0.5 INFOversion-bootloader: 1.09.0099 INFOversion-baseband: 7.53.39.03M INFOversion-cpld: None INFOversion-microp: 0451 INFOversion-main: 2.17.0.0 INFOserialno: SH16XTR02245 INFOimei: 358225042550658 INFOproduct: marvel INFOplatform: HBOOT-7227 INFOmodelid: PG7610000 INFOcidnum: VODAP203 INFObattery-status: good INFObattery-voltage: 4190mV INFOpartition-layout: HTC INFOsecur -------------------------------------------- All Done.. Operation Log Saved.. |
06-25-2014, 11:54 | #2 (permalink) |
Freak Poster Join Date: Oct 2008 Location: Romania
Member: 882067 Status: Offline Sonork: 100.1604678 Thanks Meter: 45 | do s-off for your phone. now all most any htc tool supports s-off for this model. after that, conect it in fastboot. give command : fastboot oem writecid 11111111 press Enter than fastboot reboot-bootloader to reboot it in to fastboot again. you can conform operation by comand " fastboot getvar all" at the var's you should see "CID:11111111 thats factory cid. right now your cid is vodafone and apears conflict in writing different cid firmware. good luck |
