HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
06-27-2015, 16:16 | #1 (permalink) |
Freak Poster Join Date: Jan 2011 Location: syria
Member: 1483268 Status: Offline Thanks Meter: 55 | help with htc one x [solved] fastboot getvar all (bootloader) version: 0.5a (bootloader) version-bootloader: 0.43.0000 (bootloader) version-baseband: 1.1204.105.14 (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 1.26.707.4 (bootloader) serialno: SH24GW106988 (bootloader) imei: 353043055069879 (bootloader) product: endeavoru (bootloader) platform: HBOOT-T30S (bootloader) modelid: PJ4610000 (bootloader) cidnum: None (bootloader) battery-status: good (bootloader) battery-voltage: 3871mV (bootloader) devpower: 61 (bootloader) partition-layout: None (bootloader) security: on (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: None (bootloader) hbootpreupdate: 2 (bootloader) gencheckpt: 0 all: Done! ----------------------------------- before flash this is device info Device Info Serial number: SH24GW106988 Model ID: PJ4610000 CID: HTC__044 Carrier ID: HTC-Asia-SEA-WWE (HTC__044) Hardware: endeavoru Bootmode: normal Bootloader ver: 0.43.0000 Revision: 0 Main version: 1.29.415.11 Baseband ver: None GSM baseband: 1.1204.105.14 GSM sim state: ABSENT ------------------- how to fix it and give me link to correct rom thanx Last edited by jamesjerss; 06-28-2015 at 14:24. |
06-27-2015, 19:13 | #2 (permalink) |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | yu may b flashed lateset version custom on old bootloader try stock rom here PJ46IMG_ENDEAVOR_U_JB_50_S_hTC_Asia_WWE_4.19.707.5 _Radio_5.1204.167.31_release_392884_combined_signe d Guide http://forum.gsmhosting.com/vbb/f485...guide-1952646/ |
06-27-2015, 19:45 | #3 (permalink) | |
Member: 1483268 Status: Offline Thanks Meter: 55 | Quote:
thanx | |
06-27-2015, 21:44 | #4 (permalink) | |
07-31-2016, 15:55 | #5 (permalink) |
No Life Poster Join Date: May 2006 Location: Palermo
Member: 281998 Status: Offline Thanks Meter: 117 | Hi friend... please help me C:\htc fastboot driver spl>fastboot flash zip PJ46IMG.zip sending 'zip'... (8501 KB) OKAY sending time = 1.125 secs writing 'zip'... (bootloader) adopting the signature contained in this image... (bootloader) Your memory size = 29820MB, choose rawpt_32g.img FAIL99 unknown fail FAILED (remote: 99 unknown fail) Execution time is 1(s) |
07-31-2016, 19:55 | #6 (permalink) | |
No Life Poster Join Date: Jan 2014 Location: GM7
Member: 2102992 Status: Offline Sonork: 100.1626305 Thanks Meter: 2,763 | Quote:
Note : chk your device bootloader is unlock or not,if unlock relock nd try flash Don't forget to press Thanks Button Read The Rules Careful HERE Br M@SUD | |
08-05-2016, 10:02 | #7 (permalink) |
Member: 281998 Status: Offline Thanks Meter: 117 | After relock bootloader: Code: C:\htc fastboot driver spl>fastboot devices SH23xxxxxxxx fastboot C:\htc fastboot driver spl>fastboot oem rebootRUU ... (bootloader) Save data from original MSC... (bootloader) Save data from SIF... (bootloader) Update partition data to SIF partition (bootloader) Update partition data from original MSC... (bootloader) [MSG] OKAY OKAY Execution time is 293(ms) C:\htc fastboot driver spl>fastboot flash zip PJ46IMG.zip sending 'zip'... (8501 KB) OKAY sending time = 1.356 secs writing 'zip'... (bootloader) adopting the signature contained in this image... (bootloader) signature checking... (bootloader) Your memory size = 29820MB, choose rawpt_32g.img (bootloader) checking model ID... (bootloader) checking custom ID... (bootloader) checking main version... (bootloader) checking hboot version... (bootloader) start image[hboot] unzipping for pre-update check... (bootloader) start image[hboot] unzipping & flushing... (bootloader) [RUU]WP,hboot,50 (bootloader) signature checking... (bootloader) start image[spl] unzipping & flushing... (bootloader) Format partition SP1 done (bootloader) [RUU]WP,spl,100 (bootloader) start image[tp] unzipping & flushing... (bootloader) Enable Flash Programming! (bootloader) [RUU]WP,tp,0 (bootloader) [RUU]WP,tp,17 (bootloader) [RUU]WP,tp,35 (bootloader) [RUU]WP,tp,53 (bootloader) [RUU]WP,tp,71 (bootloader) [RUU]WP,tp,89 (bootloader) Program Firmware Image success! (bootloader) start image[wlan] unzipping & flushing... (bootloader) Format partition WLN done (bootloader) start image[pg3] unzipping & flushing... (bootloader) Format partition PG3 done (bootloader) start image[recovery] unzipping & flushing... (bootloader) Format partition SOS done (bootloader) ERASE cache partition... (bootloader) ERASE backup cid OKAY sending 'zip'... (697991 KB) OKAY sending time = 91.434 secs writing 'zip'... (bootloader) adopting the signature contained in this image... (bootloader) signature checking... (bootloader) rom parsing start ... (bootloader) time: 4207 (bootloader) rom parsing finish ... (bootloader) checking model ID... (bootloader) checking custom ID... (bootloader) checking main version... (bootloader) checking hboot version... (bootloader) start image[system] unzipping & flushing... (bootloader) Format partition APP done (bootloader) [RUU]WP,system,4 (bootloader) [RUU]WP,system,9 (bootloader) [RUU]WP,system,15 (bootloader) [RUU]WP,system,20 (bootloader) [RUU]WP,system,26 (bootloader) [RUU]WP,system,31 (bootloader) [RUU]WP,system,37 (bootloader) [RUU]WP,system,42 (bootloader) [RUU]WP,system,48 (bootloader) [RUU]WP,system,54 (bootloader) [RUU]WP,system,59 (bootloader) [RUU]WP,system,65 (bootloader) [RUU]WP,system,70 (bootloader) [RUU]WP,system,76 (bootloader) [RUU]WP,system,81 (bootloader) [RUU]WP,system,87 (bootloader) [RUU]WP,system,93 (bootloader) [RUU]WP,system,98 (bootloader) [RUU]WP,system,100 (bootloader) ERASE cache partition... (bootloader) ERASE backup cid OKAY sending 'zip'... (5104 KB) OKAY sending time = 0.703 secs writing 'zip'... (bootloader) adopting the signature contained in this image... (bootloader) signature checking... (bootloader) rom parsing start ... (bootloader) time: 0 (bootloader) rom parsing finish ... (bootloader) checking model ID... (bootloader) checking custom ID... (bootloader) checking main version... (bootloader) checking hboot version... (bootloader) start image[userdata] unzipping & flushing... (bootloader) Format partition UDA done (bootloader) [RUU]WP,userdata,18 (bootloader) [RUU]WP,userdata,81 (bootloader) [RUU]WP,userdata,100 (bootloader) start image[boot] unzipping & flushing... (bootloader) Format partition LNX done (bootloader) [RUU]WP,boot,100 (bootloader) ERASE cache partition... (bootloader) ERASE backup cid OKAY Flash Zip Complete Execution time is 268(s) C:\htc fastboot driver spl> |
