HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
11-26-2014, 07:24 | #2 (permalink) |
No Life Poster Join Date: Oct 2010 Location: India Age: 31
Member: 1713856 Status: Offline Sonork: Uninstalled Thanks Meter: 4,500 | First unlock bootloader. Then flash cwm or any other custom recovery. FLash supersu zip vie sideload you can get from xda. You have rooted phone,now you can install arabic lang with morelocal app. If you have to flash different region rom,try some prof tool to make this phone s-ff. |
The Following User Says Thank You to Rahul_Bhutani For This Useful Post: |
11-26-2014, 09:52 | #3 (permalink) | |
Registered User Join Date: Aug 2010 Location: turkey
Member: 1361365 Status: Offline Sonork: 100.1670394 Thanks Meter: 15 | Quote:
I need flash different region rom so i need s-off but i cant root this phone تم الإرسال بواسطة iPhone بإستخدام Tapatalk | |
11-26-2014, 09:58 | #4 (permalink) |
Member: 1713856 Status: Offline Sonork: Uninstalled Thanks Meter: 4,500 | You can root as i said in post#2. If you jtag,better change cid to "11111111" with that and flash your arabic rom. PS:If doing just for language there is more way to do this. |
11-26-2014, 10:07 | #6 (permalink) |
Member: 1713856 Status: Offline Sonork: Uninstalled Thanks Meter: 4,500 | Root your phone as i told you in second post,open playstore in phone,download morelocal 2 and select your language,that's it. |
11-26-2014, 10:10 | #7 (permalink) |
Member: 1361365 Status: Offline Sonork: 100.1670394 Thanks Meter: 15 | Ah this methode doent work the letters not appear correctly i tried morelocale and enable language تم الإرسال بواسطة iPhone بإستخدام Tapatalk |
11-26-2014, 10:22 | #8 (permalink) |
Member: 1713856 Status: Offline Sonork: Uninstalled Thanks Meter: 4,500 | SO use jtag box and make your cid super then you can flash arabic rom. |
11-26-2014, 11:05 | #10 (permalink) |
Member: 1713856 Status: Offline Sonork: Uninstalled Thanks Meter: 4,500 | Try AAHK2 script from xda once,otherwise jtag is your friend :P |
