how to flash desire 310 mt6582 hi i have one desire 310 i download firmware but i can`t flash with sp flashtool when i try flash with flashtool ,i have error 2004 i tested with many version of flashtool |
i think this phone only flash with sp flashtool but when i flash with sp flashtool i se error 2004 (mean sp flashtool not match with phone) |
I don't work with HTC set with sptool but if u have simple problem then just write user data area or flash the set with format + download option |
I used flashtool as in folder and Windows xp did the job... I flashed it to Desire 310u... working... |
https://forum.gsmhosting.com/vbb/****************************/?4g050pjvj0ujyub[IMG]****************************/?4g050pjvj0ujyub[/IMG] |
HTC desire 310 flash done this file n this tool but set startup time 1 time notice sku number 1.00.1402.6 cid htc_038 your cie is incorrect it must be one of below cids; htccn703 here link HTC-D310W by jamesjerss |
Dear Help to flash HTC Desire 310 MTK6582 with both boxes give error Help Thanks in advance |
hello everyone :) i got this problem today when i tried to flash HTC desire 310 dual _ spft error 2004 !!! :( but i decided to fix it and i did :D pre : - download this FW https://yadi.sk/d/7SGjVIxUbaUxe - download this ver of spft https://mega.nz/#!WcVGyYZK!FyFVPkKTd...J0rELMocvztyNI - Go to the Connection tab, and select the option: High Speed and w / o battery. - select the option Download DA DL All with checksum - important step " rename checksum.ini to checksum.old into ur fw package - press Download and connect ur device with v+ pressed until it start the flashing ---- i shared this to let everyone fall in the same error " 2004 " fix it good luck --- Devx |
any one with a link to download htc d310n mt6582 firmware |
flashed with xx0o0xx1 provided file, #11, now set is alive. thanks |
I could not do it, could result be a problem related to negative vehicle version |
