HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
10-20-2014, 09:11 | #1 (permalink) |
Freak Poster Join Date: May 2007 Location: Big iran Age: 40
Member: 509921 Status: Offline Thanks Meter: 24 | how to flash desire 310 mt6582 i have one desire 310 i download firmware but i can`t flash with sp flashtool when i try flash with flashtool ,i have error 2004 i tested with many version of flashtool |
10-20-2014, 15:55 | #2 (permalink) | |
Member: 509921 Status: Offline Thanks Meter: 24 | Quote:
i think this phone only flash with sp flashtool but when i flash with sp flashtool i se error 2004 (mean sp flashtool not match with phone) | |
02-15-2015, 18:44 | #5 (permalink) | |
Banned Join Date: Nov 2014
Member: 2300899 Status: Offline Thanks Meter: 5 | Quote:
I don't work with HTC set with sptool but if u have simple problem then just write user data area or flash the set with format + download option | |
03-03-2015, 15:03 | #6 (permalink) | |
No Life Poster Join Date: Jan 2008 Location: Pakistan
Member: 682736 Status: Offline Thanks Meter: 457 | Quote: I used flashtool as in folder and Windows xp did the job... I flashed it to Desire 310u... working... | |
The Following User Says Thank You to adnon For This Useful Post: |
10-25-2015, 15:22 | #7 (permalink) |
Freak Poster Join Date: Jul 2011 Age: 36
Member: 1625194 Status: Offline Thanks Meter: 30 | https://forum.gsmhosting.com/vbb/****************************/?4g050pjvj0ujyub[IMG]****************************/?4g050pjvj0ujyub[/IMG] |
12-22-2015, 08:52 | #9 (permalink) |
Freak Poster Join Date: Dec 2011 Location: india
Member: 1701545 Status: Offline Thanks Meter: 100 | HTC desire 310 flash done this file n this tool but set startup time 1 time notice sku number 1.00.1402.6 cid htc_038 your cie is incorrect it must be one of below cids; htccn703 here link HTC-D310W by jamesjerss |
05-29-2016, 14:52 | #11 (permalink) |
No Life Poster Join Date: Sep 2013 Location: The Hell Age: 31
Member: 2033150 Status: Offline Thanks Meter: 624 | hello everyone i got this problem today when i tried to flash HTC desire 310 dual _ spft error 2004 !!! but i decided to fix it and i did pre : - download this FW https://yadi.sk/d/7SGjVIxUbaUxe - download this ver of spft https://mega.nz/#!WcVGyYZK!FyFVPkKTd...J0rELMocvztyNI - Go to the Connection tab, and select the option: High Speed and w / o battery. - select the option Download DA DL All with checksum - important step " rename checksum.ini to checksum.old into ur fw package - press Download and connect ur device with v+ pressed until it start the flashing ---- i shared this to let everyone fall in the same error " 2004 " fix it good luck --- Devx |
The Following 4 Users Say Thank You to xx0o0xx1 For This Useful Post: |
