Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > HTC > HTC android based
HTC android based General HTC Android phones discussion, firmwares, solution, root, help
Old 09-14-2011, 17:32   #1 (permalink)
fares122's Avatar
Member: 719979
Sonork: 100.1589075
How To: Gain Permanent Root and S-OFF on the T-Mobile MyTouch 4G / HTC Glacier
How To: Temporarily Root
I. Before You Begin
1. This method gives you temporary root, but you can go to the next procedure immediately after finishing this one to get permanent root and s-off.
2. This will allow you to WiFi tether (if you can find an appropriate WiFi tethering app for the phone).
II. Root the G2
1. On your phone, go to Settings > Applications > Development > and make sure USB Debugging is ON (it MUST be ON) and make sure Fastboot is checked OFF (if it exists in your settings, otherwise don’t worry about it).
2.Download Visionary from here
3. Plug in your phone via USB cable and mount the sd card so we can transfer files to it.
4.Copy the Visionary .apk file to the root of your phone’s memory card (NOT in any folder just on the sd card itself).
5. Then simply open any file manager app on your phone (like Linda File Manager for free from the Market for example) find the visionary apk file in the file manager and click it and follow the prompts to install it.
6. Once installed, open Visionary and check ON Temp Root After Reboot, and check ON System R/W After Root. Then click TempRoot Now and wait for it to finish.
7. Once it is done, you have temp root and can use rooted apps without rebooting, OR continue to the next procedure to gain persistent root access and s-off to load custom ROMs, etc.
How To: S-OFF on the T-Mobile MyTouch 4G / HTC Glacier
This ONLY works on T-Mobile MyTouch 4G’s that have gotten the OTA. You can check by going to Settings > About Phone > Firmware and your Android Version should read 2.2.1 or higher! If you are Android 2.2, either just wait for Android 2.2.1 to automatically come to your phone OR download this file save it to the root of your sd card and then turn off your phone and turn it back on holding down Volume Down and Power and then apply the update when asked. After that, you can continue with this procedure.Thanks to Grankin01 for his rooting scripts!
II. Flash the S-OFF Hboot Image and Gain Perm Root
1. Download the rooting files:
2. Extract the files somewhere to your computer.
3. Plug your phone in via USB cable and mount the SD card so we can transfer files to it.
4. Copy the entire root folder from inside the extracted folder from step 2 to the root of your sd card on your phone (NOT in any folders, just on the SD card itself).
5. Unplug the phone.
6. Go to the Market on your phone and download/install Android Terminal Emulator (free).
4. Open the Terminal Emulator app and type the following with hitting enter at the end of each line (to get the touch screen keyboard to come up hit the menu button then toggle soft keyboard):
su
cd /sdcard/root
sh root.sh
5. Now, wait for it to finish.
6. After that is done, reboot the phone. When it boots back up, turn it off and back on holding down Volume Down and Power until the HBoot screen comes up. Confirm it says S-OFF at the top. If so, you have S-OFF.
10. Now, to get permanent root, turn the phone back on to get to the normal home screen.
11. Open Visionary and Uncheck TempRoot on Boot and click Temproot Now.
12. Then select Attempt Perm Root Now and the phone should reboot.
13. Once the phone reboots, open Terminal Emulator on the phone and type su and hit enter. If you get the # symbol, you have permanent root access and S-OFF, enjoy!
el fnan-gsm
The Following User Says Thank You to fares122 For This Useful Post:
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 8 05-21-2013 19:20
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 04-10-2013 02:07
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 28 08-30-2012 03:40
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 11-15-2011 12:08
Page generated in 0.55748 seconds with 11 queries
