HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
10-28-2014, 11:48 | #2 (permalink) | |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Quote:
if not download stock recovery frm xda forum must b supported yur main version flash via fastboot : fastboot flash recovery recovery.img After flash relock yur bootloader | |
10-28-2014, 14:22 | #3 (permalink) | |
No Life Poster Join Date: Jan 2005 Location: India
Member: 107448 Status: Offline Thanks Meter: 29 | Quote:
thx | |
10-28-2014, 17:04 | #5 (permalink) |
Member: 107448 Status: Offline Thanks Meter: 29 | (bootloader) version: 0.5 (bootloader) version-bootloader: 3.16.0.0000 (bootloader) version-baseband: 1.16.21331831.A11G (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 1.54.708.5 (bootloader) version-misc: PVT SHIP S-OFF (bootloader) serialno: HT44AWM07690 (bootloader) imei: 352090060133274 (bootloader) imei2: Not Support (bootloader) meid: 00000000000000 (bootloader) product: m8_ul (bootloader) platform: hTCBmsm8974 (bootloader) modelid: 0P6B63000 (bootloader) cidnum: HTC__622 (bootloader) battery-status: good (bootloader) battery-voltage: 0mV (bootloader) partition-layout: Generic (bootloader) security: off (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: ab0efa49 (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 all: Done! |
10-28-2014, 19:20 | #6 (permalink) |
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Yurs is asian model id 0P6B63000 No stock ruu or frmwares available to rollback to stock Yu hav s-off so yu can change yur model id to europe 0P6B10000 Easily Enable usb debuggin nd connt to pc Run cmd command adb shell su echo -ne '\x30\x00\x50\x00\x36\x00\x42\x00\x31\x00\x30\x00\ x30\x00\x30\x00\x30' | dd of=/dev/block/mmcblk0p5 bs=1 seek=16384 exit adb reboot bootloader fastboot getvar mid (or getvar all) verify 0P6B10000 for modelid fastboot reboot Without lose s-off flash stock rom nd stock recovery Procedure Stock Untouched Rom Download Download tis rom nd flash via custom recovery After flash if yu face bootloop extract boot.img frm rom nd flash via fastboot Command : fastboot flash boot boot.img Download Stock recovery Here Extract the zip Put yur mobile into fastboot mode Run the install-recovery-windows bat file Now fully stock rom vit stock recovery Proceder using Stock RUU yu vil lose s-off Before flash stock Ruu change yur cid to super cid Put yur mob into fastboot nd run below given command fastboot oem writecid 1111111 Download Europe Stock Ruu IF ruu flash it directly IF zip file rename the file as 0P6BIMG dnt change extension nd run the below cmmd to flash phone must be cnnted n fastboot mode fastboot flash zip 0P6BIMG.zip fastboot reboot All Ota Updates Here Rename the zip file as update dnt change extension copy to mobile update via stock recovery or update OTA via wifi Note: Before do take nandroid backup using custom recovery Last edited by jamesjerss; 10-28-2014 at 23:39. |
The Following User Says Thank You to jamesjerss For This Useful Post: |
10-29-2014, 12:34 | #8 (permalink) | |
