HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
06-04-2014, 16:18 | #1 (permalink) |
Freak Poster Join Date: Aug 2005 Location: Greece Age: 38
Member: 173946 Status: Offline Sonork: 100.1585498 Thanks Meter: 42 | How to root HTC HTC Sensation (PYRAMID) |
06-06-2014, 13:24 | #4 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | The S-OFF is to disable security bootloader to allow us, among other things, write in system ROM. You need to change to get the ROMs and root. There are 2 methods to get the official HTC would not recommend to anyone and the Revolutionary Booting into bootloader mode if we see written S-OFF or S-ON. We are interested to always have S-OFF and the only reason you should go back to S-ON is to send the terminal SAT and we did not see S-OFF. An advantage of the method is that it allows Revolutionary back to being S-ON. Method Toiiki S-OFF The Toiiki S-OFF method is only valid for today Hboot or Bootloader. 1.18.0000,1.19 xxxx, 1.20.xxxx, 1.21.xxxx, 1.23.xxxx and 1.27.xxxx To find out what version of Hboot you do the following: Turn off the phone, remove the battery and put it back thereupon pressing volume - and the power button at the same time. This will give you access to Hboot, and will show the version at the top. If you do not have the version shown above will not be able to get S-Off, which will not be able to do the complete installation. Revolutionary Method The revolutionary method is only valid for today Hboot or Bootloader: 1.17.0006, .0008, .0011, .0012 and 1.18.0000 To find out what version of Hboot you do the following: Turn off the phone, remove the battery and put it back thereupon pressing volume - and the power button at the same time. This will give you access to Hboot, and will show the version at the top. If you do not have the version shown above will not be able to get S-Off, which will not be able to do the complete installation. Do not try to unblock your sensation if you have a version of ICS installed The revolutionary method is only valid for today Hboot or Bootloader: 1.17.0006, .0008, .0011, .0012 and 1.18.0000 To find out what version of Hboot you do the following: Turn off the phone, remove the battery and put it back thereupon pressing volume - and the power button at the same time. This will give you access to Hboot, and will show the version at the top. A computer with Linux or Windows is required. Method is recommended whenever you have a hboot of the above mentioned, as it is completely reversible. Make a backup of your important data, this process if it does not work to erase forever the first, and only be restored from a backup We need Uninstall HTC Sync and and / or DoubleTwist if they are installed on the computer. Windows users should have the HTC driver installed. Having the USB debugging enabled, is (Settings -> Applications -> Development). Steps to follow Go to Page Revolutionary Revolutionary Download the appropriate application for your "Linux / Windows" operating system Fill the form that appears when turning the download link We complement: OS, your device version of Hboot "Bootloader" and the serial "The serial number you find behind the battery is the type N:. HTAF12341 with other numbers .. As Knowing Hboot "Bootloader" have? Running the application which you have downloaded from Revolutionary and when you find the device should read something like this: "Found your Device. HTC Sensation Z710 * <pyramid-1.17 **** <This is your Hboot version" 1.17 **. ** " Turn off the phone, remove the battery and put it back thereupon pressing volume - and the power button at the same time. This will give you access to Hboot, and will show the version at the top. When completing the form, it shall provide the beta key to enable S-OFF. WRITE IN A SAFE PLACE THE KEY PROVIDED. Beginning the process Starts the program in administrator mode. With the phone on the screen in normal boot (not in HBOOT), connect the USB cable and set it to HTC sync mode (ignore messages HTC Sync). The program will begin the process for the S-OFF, and once completed the device will restart entering the bootloader automatically. Now the program will ask the continuous Beta key, insert and. Be sure to write the code correctly with case-sensitive, and careful not to confuse with 1 l since in that page use a source where 1 and l are very similar. When the process is complete, it will ask if you want to install the Recovery or not, if you have internet connection confirms, if not, give no. Once you finish all, restart the terminal and go. If you get the S-OFF is that you have successfully completed the entire process. If not, reset the factory settings and re-do the steps has from point number 1 Starting the process. Your phone is already security-disabled! (You do S-OFF) |
06-06-2014, 13:29 | #5 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | HTCDev Method Important Notice: This process is recorded by HTC, if you make a mistake in the future, you might not covered by warranty. The only valid today HTCDev method for Hboot or Bootloader: 1.17.0006, .0008, .0011, .0012 and 1.18.0000 To find out what version of Hboot you do the following: Turn off the phone, remove the battery and put it back thereupon pressing volume - and the power button at the same time. This will give you access to Hboot, and will show the version at the top. If you do not have the version shown above will not be able to get S-Off, just unlock the hboot, which will not be able to do the complete installation. Legend and Recommendations The HTCDev method is only valid today for Terminals origin: Sensation (Arabic), Sensation (Bouygues FRA), Sensation (Europe), Sensation (SKT Korea), Sensation (TUR), Sensation (Vodafone), Sensation 4G ( T-Mobile U.S.) A computer with Linux, Mac or Windows is required. Make a backup of your important data, this process will erase forever, and can only be restored from a backup We need It is necessary for users of Windows have HTC Sync installed You need to install the Java Runtime Environment You must have installed the Google Android SDK Steps to follow Go to page HTC Developer Portal Sign up and provides the required data. Once registered, click below entirely on Unlock Bootloader Now you appear to the right a list of devices, you select the Sensation model we have, "eg Sensation (EU)". "Where else come from mobile, select the right". Click Begin unlock Bootloader We are now a small screen that asks for our confirmation will appear, click on Yes Below you will the small screen legal terms, we select the two boxes and click on proceded to Unlock Instruccions Now you will have a tutorial in English to continue the installation, and very detailed drawings. Before you must have installed the three files listed in the section: What we need |
06-06-2014, 13:42 | #6 (permalink) | |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Quote:
http://forum.gsmhosting.com/vbb/f485.../#post10359332 | |
