HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
08-10-2014, 11:32 | #3 (permalink) |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Yur mobile has german CID HTC_102 Official Ruu not found There is other ways to flash yur mobile Download other Ruu from here Run the RUU executable as you normally would, but don't proceed to the second step i.e. when a second window appears, do nothing. Do not proceed, just ignore it for now, but don't close the window.
This is only required if the RUU you have is not for your CID and you don't have SuperCID. |
08-11-2014, 23:24 | #5 (permalink) |
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | OTA update for yur CID HTC_102 copy to memory card nd update rename the file as PG58IMG.zip http://dl4.htc.com/RomCode/Source_an...16-e733189.zip File cant downlod visit here http://www.htcdev.com/devcenter/downloads select model EVO 3D Region GER hit find files. |
