HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
09-14-2015, 15:35 | #16 (permalink) |
No Life Poster Join Date: Dec 2004 Age: 50
Member: 98139 Status: Offline Thanks Meter: 126 | |
The Following User Says Thank You to cdma-india For This Useful Post: |
09-18-2015, 21:40 | #17 (permalink) |
Member: 98139 Status: Offline Thanks Meter: 126 | fastboot flash frp frp.img problem can be solved with this command just s-off ur device and backup frp.img from other same handset try |
11-19-2015, 12:43 | #19 (permalink) |
Junior Member Join Date: Nov 2013 Location: targu jiu
Member: 2067480 Status: Offline Thanks Meter: 14 | hello. didn't test my solution for this htc model but for HTC M9 tested and work 100% -fist make s-off. ( i used htc 2 clip. shearch on google how to make s-off) -download and flash last twrp recovery -put phone in recovery mode then open adb and use this comands adb.exe kill-server adb.exe start-server adb.exe shell dd if=/dev/zero of=/dev/block/mmcblk0p48 /// mmcblk0p48- contains frp lock then hard reset phone, advance wipe dalvick cache. That's it. |
The Following User Says Thank You to yuly262 For This Useful Post: |
12-06-2015, 06:30 | #21 (permalink) |
Junior Member Join Date: Mar 2015
Member: 2364446 Status: Offline Thanks Meter: 0 | OK assuming you can get S-off via java card it would be possible to flash back to 5.0 stock rom prior to updated security to fix it. That's what I gleamed from some posts on xda. I will try it in the next couple of days and get back to youz. |
12-25-2015, 06:36 | #23 (permalink) | |
Registered User Join Date: Feb 2012 Location: swimming
Member: 1725884 Status: Offline Sonork: swimming Thanks Meter: 293 | Quote:
i need to know how did you made dump from working phone like htc 626s, i need to know because it will be useful to make dump by adb to work with jtag box but i dont know the way so please guide me,thanks... | |
02-07-2016, 00:15 | #26 (permalink) | |
No Life Poster Join Date: Jan 2013 Location: HUAWEI FRP KEY imei-code
Member: 1870489 Status: Offline Sonork: 100.1663831 Thanks Meter: 483 | Quote:
but it work or not im not sure i try huawei many device work for me but htc not tested yet............... | |
11-10-2016, 17:08 | #29 (permalink) |
Insane Poster Join Date: Mar 2008 Location: DERA BABA NANAK
Member: 723248 Status: Offline Thanks Meter: 7 | htc frp lock remove done https://yadi.sk/d/LrGNxxXKnb2Ep downlaod this watch this https://www.youtube.com/watch?v=BecBp07fK50 Use these command : devices shell netcfg shell content insert --uri content://settings/secure --bind name:s:user_setup_complete --bind value:s:1 |
01-22-2017, 08:50 | #30 (permalink) |
Insane Poster Join Date: Dec 2010 Location: nepal
Member: 1471030 Status: Offline Thanks Meter: 37 | no need to all type some word pres dowel tap go to asse opening google crome download #quick shortcut maker# go in file manager and instal itt and than add account thats all |
The Following User Says Thank You to mobile_sujan01 For This Useful Post: |
