HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
07-21-2018, 19:09 | #1 (permalink) |
Freak Poster Join Date: Oct 2009 Location: bangladesh
Member: 1142388 Status: Offline Sonork: 100.1617280 Thanks Meter: 85 | htc a9 HIA_AERO_UHL flashing error here is fastboot log Model : HTC_HIAEWHL IMEI : 990005706386316 Build : 2.18.651.2 CID : 11111111 HBoot : 1.0.0.0000 MID : 2PQ910000 Security : CURITY FAILED (REMOTE: UNKNOWN COMMAND) Region : Super_CID RBSofts V1.3 Mobile Tool. flashing log Starting flash process... target rom version: 2.17.401.2 found large-zip header, file count: 21 processing file 1/21... sending 'zip' (98794 KB)... OKAY [ 4.986s] writing 'zip'... (bootloader) HOSD CL#897721 (bootloader) GPT (gpt_main_32g.img) is up-to-dated. [17408] (bootloader) WARN Skip partition_info due to unmatched partition name (bootloader) WARN Skip backup_android-info.txt due to unmatched partitio (bootloader) n name (bootloader) get 25 images from zip(zip_type=3) (bootloader) start@25 (bootloader) apppreload.img@22% (bootloader) apppreload.img@45% (bootloader) apppreload.img@68% (bootloader) apppreload.img@90% (bootloader) apppreload.img@100% (bootloader) aboot_signed.img@100% (bootloader) cota.img@100% (bootloader) sbl1-8952-1.img@100% (bootloader) hosd_signed.img@100% (bootloader) rpm-8952-1.img@100% (bootloader) boot_signed.img@100% (bootloader) recovery_signed.img@100% (bootloader) adsp.img@100% (bootloader) dsp.img@100% (bootloader) wcnss.img@100% (bootloader) rcdata.img@100% (bootloader) rfg_3.img@100% (bootloader) modemst1.img@100% (bootloader) modemst2.img@100% (bootloader) fsc.img@100% (bootloader) tz-8952-1.img@100% (bootloader) hyp-8952-1.img@100% (bootloader) cmnlib32.img@100% (bootloader) keymaster.img@100% (bootloader) pg2fs_ship_signkey.img@100% (bootloader) splash1.nb0@100% (bootloader) radio.img@100% (bootloader) sensor_hub.img@0% (bootloader) sensor_hub.img@0% (bootloader) sensor_hub.img@0% (bootloader) sensor_hub.img@0% (bootloader) sensor_hub.img@0% (bootloader) sensor_hub.img@0% (bootloader) sensor_hub.img@0% (bootloader) sensor_hub.img@0% (bootloader) sensor_hub.img@0% (bootloader) sensor_hub.img@0% (bootloader) ERR do_firmware_update_thread: child exited with non-zero s (bootloader) tatus: 255 (bootloader) ERR Flashing [sensor_hub.img] failed with status [255] (bootloader) ERR Faild to update firmware [sensor_hub.img] (bootloader) sensor_hub.img@FAIL (bootloader) tp_SYN3708.img@BYPASS (bootloader) Update zip file OK (bootloader) ERR WRITE ERROR, 33 (bootloader) end@Done FAILED (remote: 33 RU_UPDATE_FIRMWARE_FAIL ) finished. total time: 69.276s Flash process completed. Flash not successfull, reboot will not be done plase help me br, gsm_uzzal |
