HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
10-04-2014, 00:27 | #1 (permalink) |
Insane Poster Join Date: Mar 2014
Member: 2154571 Status: Offline Thanks Meter: 2 | Htc desire 300 stuck at HTC logo |
The Following User Says Thank You to iwin4god For This Useful Post: |
10-04-2014, 08:19 | #2 (permalink) |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Yu can not use htc sync to update mobile nd official ruu also not available Only way is flash custom rom 1st unlock bootloader Flash custom recovery Download here Download tis rom copy to memory card flash it via recovery Last edited by jamesjerss; 10-18-2014 at 13:18. |
The Following User Says Thank You to jamesjerss For This Useful Post: |
10-04-2014, 09:20 | #3 (permalink) | |
Member: 2154571 Status: Offline Thanks Meter: 2 | Quote:
10-04-2014, 09:25 | #4 (permalink) |
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Recovery dwnlod frm here same model oly http://forum.gsmhosting.com/vbb/f485...known-1865259/ |
10-04-2014, 09:36 | #5 (permalink) | |
i need to put cwm recovery in my sd card unzipped? and then go to recovery,and install it from there? sorry for disturbing you,but im not really into this...Thanks again i really appreciate your help..best regards. | |
10-04-2014, 09:40 | #6 (permalink) |
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | b4 flash dnt frgrt to unlock bootloader flash recovery via fastboot extarct nd rename the file as recovery nd run below givn cmmd to flash cmmd : fastboot flash recovery recovery.img after flash recovery copy rom to sdcard flash via recovery . |
11-19-2014, 04:55 | #10 (permalink) |
Freak Poster Join Date: Feb 2008
Member: 706023 Status: Offline Sonork: 100.1647210 Thanks Meter: 75 | I have the same phone which stocks on HTC logo and restarts after that. I flashed custom recovery and when I tried to enter custom recovery in the phone, entering recovery message appeared and the phone restarted again. I also tried to find RUU for this phone, but I couldn't. Does anyone have Ruu file for this phone? Is the problem caused by the software or the hardware? The following is the phone's info: (bootloader) version: 0.5 (bootloader) version-bootloader: 1.18.0002 (bootloader) version-baseband: 14.11.36Q4.21 (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 1.¦0.401.4 (bootloader) version-misc: PVT SHIP S-ON (bootloader) serialno: HT3BAWL00967 (bootloader) imei: 35828********** (bootloader) meid: (bootloader) product: g3u (bootloader) platform: HBOOT-8225 (bootloader) modelid: 0P6A10000 (bootloader) cidnum: HTC__A07 (bootloader) battery-status: good (bootloader) battery-voltage: 3660mV (bootloader) partition-layout: HTC (bootloader) security: on (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: dirty-e1c32097 (bootloader) hbootpreupdate: 12 (bootloader) gencheckpt: 0 all: Done! finished. total time: 0.020s Thanks in advance. |
11-19-2014, 10:53 | #11 (permalink) | |
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Quote:
1st extract boot.img from custom rom nd flash it via fastboot fastboot flash boot boot.img Den flash the recovery Custom recovery should wrk if same may b hardware issues | |
The Following 2 Users Say Thank You to jamesjerss For This Useful Post: |
01-11-2015, 14:36 | #12 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Hell
Member: 679176 Status: Offline Sonork: 1585224 Thanks Meter: 119 | all what i read here is perfect theory but is not work, if someone have tested this solution pls post here. I try to unlock bootloader with htcdev, BUT when set ask me if i want to unlock bootloader is necessary to pres power key and this key dont work, if i say i dont want to unlock bootloader also is necesary to pres power key and now is work. I read many page and i test many solution but doesent work if someone have any solution pls help. Br, Pr3dict3r |
01-26-2015, 21:01 | #13 (permalink) |
No Life Poster Join Date: Sep 2003 Location: Dubai
Member: 39022 Status: Offline Sonork: 1575244 Thanks Meter: 94 | G3U PUT SHIP S-ON RH HBOOT-1.18.0002 RADIO-14.11.36Q4.21 OS- eMMC-boot everything done but flashing with rom via mmc shows error. where i m wrong. Regards |
06-03-2015, 09:48 | #15 (permalink) |
No Life Poster Join Date: May 2007 Location: lahore
Member: 504906 Status: Offline Sonork: 1604032 Thanks Meter: 141 | @ jamesjerss plz check my problem.i m stuck here. <a href='http://postimg.org/image/d9mmqghcj/' target='_blank'><img src='http://s5.postimg.org/d9mmqghcj/WP_20150602_21_52_21_Pro_highres.jpg' border='0' alt="WP 20150602 21 52 21 Pro highres" /></a> here i cannot select next,try well but failed,sometime ago i succcefully flashed this rom,but this time have problem. plz check and need help. |
The Following User Says Thank You to Hamidshah07 For This Useful Post: |
