HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
05-21-2015, 18:56 | #16 (permalink) |
No Life Poster Join Date: Jun 2004 Age: 51
Member: 69514 Status: Offline Thanks Meter: 66 | But with this command I got following error, Microsoft Windows XP [Version 5.1.2600] (C) Copyright 1985-2001 Microsoft Corp. C:\Program Files\Minimal ADB and Fastboot>fastboot flash zip PO49IMG.zip sending 'zip' (876183 KB)... OKAY [ 79.375s] writing 'zip'... (bootloader) signature checking... FAILED (remote: signature verify fail) finished. total time: 188.875s Why allways "signature verify fail"? Is this file not compatible? My version is, #Detecting device Connected mode ... [fastboot] Reading information ... [ok] product : cp3dug version main : 1.22.707.2 version bootloader : 1.03.0001 version : 0.5 serialno : xxxxxxxxxxxxxx imei : xxxxxxxxxxxxxxx platform : HBOOT-8x25Q cidnum : HTC__038 modelid : PO4910000 security : on battery status : good battery voltage : 3640mV build mode : SHIP partition layout : HTC version-baseband : 14.11.36Q.25 |
05-21-2015, 19:06 | #18 (permalink) |
Member: 69514 Status: Offline Thanks Meter: 66 | I cannot unlock bootloader also. At the time of boot loader unlock when I select option yes with volume keys to unlock bootloader after writing unlocked bin. I try to press on/off for yes selection it doesn't work for that time only. Is there any other option to unlock bootloader without pressing on off. |
05-21-2015, 20:04 | #19 (permalink) | |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Quote:
I vil check the file sme times asia wwe file won't support cid htc_38 wil upload correct file tmrw Br james | |
05-22-2015, 14:48 | #21 (permalink) |
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | |
The Following User Says Thank You to jamesjerss For This Useful Post: |
05-22-2015, 16:57 | #22 (permalink) |
Member: 69514 Status: Offline Thanks Meter: 66 | Thanks for your great help, But fault is same.I think you are right it is emmc fault. For simplicity I renamed your latest file as PO49IMG.zip. Microsoft Windows XP [Version 5.1.2600] (C) Copyright 1985-2001 Microsoft Corp. C:\Program Files\Minimal ADB and Fastboot>fastboot flash zip PO49IMG.zip sending 'zip' (876320 KB)... (bootloader) start check_usb: usb_ep0: type=128, request=6 OKAY [113.125s] writing 'zip'... (bootloader) signature checking... FAILED (remote: signature verify fail) finished. total time: 222.656s C:\Program Files\Minimal ADB and Fastboot> |
05-22-2015, 17:33 | #23 (permalink) | |
Sent from my XT1068 using Tapatalk | |
05-22-2015, 18:50 | #26 (permalink) |
Member: 69514 Status: Offline Thanks Meter: 66 | Microsoft Windows XP [Version 5.1.2600] (C) Copyright 1985-2001 Microsoft Corp. C:\Program Files\Minimal ADB and Fastboot>fastboot getvar all (bootloader) version: 0.5 (bootloader) version-bootloader: 1.03.0001 (bootloader) version-baseband: 14.11.36Q.25 (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 1.22.707.2 (bootloader) version-misc: PVT SHIP S-ON (bootloader) serialno: FA39YWB04827 (bootloader) imei: 357209051373039 (bootloader) meid: (bootloader) product: cp3dug (bootloader) platform: HBOOT-8x25Q (bootloader) modelid: PO4910000 (bootloader) cidnum: HTC__038 (bootloader) battery-status: good (bootloader) battery-voltage: 3700mV (bootloader) partition-layout: HTC (bootloader) security: on (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: dirty-a87dbd86 (bootloader) hbootpreupdate: 12 (bootloader) gencheckpt: 0 all: Done! finished. total time: 0.016s C:\Program Files\Minimal ADB and Fastboot> |
05-22-2015, 19:50 | #27 (permalink) |
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Try this rename the file as PO49IMG copy to sdcard Boot yur device n bootloder mode it vil start to flash. |
