Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > HTC > HTC Android based
HTC Android based General HTC Android phones discussion, firmwares, solution, root, help
Old 05-21-2015, 18:56   #16 (permalink)
Member: 69514
Thanks Meter: 66
Mistake found .I should type this command "fastboot flash zip PO49IMG.zip"
But with this command I got following error,
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Program Files\Minimal ADB and Fastboot>fastboot flash zip PO49IMG.zip
sending 'zip' (876183 KB)...
OKAY [ 79.375s]
writing 'zip'...
(bootloader) signature checking...
FAILED (remote: signature verify fail)
finished. total time: 188.875s
Why allways "signature verify fail"?
Is this file not compatible?
My version is,
#Detecting device
Connected mode ... [fastboot]
Reading information ... [ok]
product : cp3dug
version main : 1.22.707.2
version bootloader : 1.03.0001
version : 0.5
serialno : xxxxxxxxxxxxxx
imei : xxxxxxxxxxxxxxx
platform : HBOOT-8x25Q
cidnum : HTC__038
modelid : PO4910000
security : on
battery status : good
battery voltage : 3640mV
build mode : SHIP
partition layout : HTC
version-baseband : 14.11.36Q.25
Old 05-21-2015, 18:59   #17 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
seems lik yur emmc is faulty
james
Old 05-21-2015, 19:06   #18 (permalink)
Member: 69514
Thanks Meter: 66
I cannot unlock bootloader also.
At the time of boot loader unlock when I select option yes with volume keys to unlock bootloader after writing unlocked bin.
I try to press on/off for yes selection it doesn't work for that time only.
Is there any other option to unlock bootloader without pressing on off.
Old 05-21-2015, 20:04   #19 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
You no need to unlock yur bootloader to flash stock roms.
I vil check the file sme times asia wwe file won't support cid htc_38
wil upload correct file tmrw
james
Old 05-21-2015, 20:15   #20 (permalink)
Member: 69514
Thanks Meter: 66
Ok,I will wait for your file.
Thanks,
Old 05-22-2015, 14:48   #21 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Thanks,
CP3_DUG_JB_50_hTC_Asia_India_1.22.707.2_Radio_14.1 1.36Q.25_14.31.36
The Following User Says Thank You to jamesjerss For This Useful Post:
Old 05-22-2015, 16:57   #22 (permalink)
Member: 69514
Thanks Meter: 66
Thanks for your great help,
But fault is same.I think you are right it is emmc fault.
For simplicity I renamed your latest file as PO49IMG.zip.
sending 'zip' (876320 KB)...
(bootloader) start check_usb: usb_ep0: type=128, request=6
OKAY [113.125s]
writing 'zip'...
finished. total time: 222.656s
Old 05-22-2015, 17:33   #23 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
OKAY [113.125s]
writing 'zip'...
Not emmc only signature error now check yur bootloder its locked or unlocked. if unlocked relock again flash the rom nd note battery charge must b above 50%
Sent from my XT1068 using Tapatalk
Old 05-22-2015, 18:16   #24 (permalink)
Member: 69514
Thanks Meter: 66
I double checked ,
Bootloader is locked & battery is charged but error is same signature verification.
Old 05-22-2015, 18:22   #25 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
I double checked ,
Read boot info nd post here
Run below givn cmmd
fastboot getvar all
Old 05-22-2015, 18:50   #26 (permalink)
Member: 69514
Thanks Meter: 66
C:\Program Files\Minimal ADB and Fastboot>fastboot getvar all
(bootloader) version: 0.5
(bootloader) version-bootloader: 1.03.0001
(bootloader) version-baseband: 14.11.36Q.25
(bootloader) version-cpld: None
(bootloader) version-microp: None
(bootloader) version-main: 1.22.707.2
(bootloader) version-misc: PVT SHIP S-ON
(bootloader) serialno: FA39YWB04827
(bootloader) imei: 357209051373039
(bootloader) meid:
(bootloader) product: cp3dug
(bootloader) platform: HBOOT-8x25Q
(bootloader) modelid: PO4910000
(bootloader) cidnum: HTC__038
(bootloader) battery-status: good
(bootloader) battery-voltage: 3700mV
(bootloader) partition-layout: HTC
(bootloader) security: on
(bootloader) build-mode: SHIP
(bootloader) boot-mode: FASTBOOT
(bootloader) commitno-bootloader: dirty-a87dbd86
(bootloader) hbootpreupdate: 12
(bootloader) gencheckpt: 0
all: Done!
finished. total time: 0.016s
Old 05-22-2015, 19:50   #27 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Try this rename the file as PO49IMG
copy to sdcard
Boot yur device n bootloder mode it vil start to flash.
Old 05-22-2015, 20:17   #28 (permalink)
Member: 69514
Thanks Meter: 66
Ok,
I will try & post result tomorrow.
Thanks,
Old 05-23-2015, 17:34   #29 (permalink)
Member: 69514
Thanks Meter: 66
Flashing is ok.
After it says press power button.
Than after pressing power mobile vibrates seven times on htc screen & it stucks there only.
Old 05-23-2015, 17:58   #30 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Flashing is ok.
strange did yu try hard reset if not gng into recovery mode unlock bootloader it vil reset yur device.
Page generated in 0.23441 seconds with 9 queries
