Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > HTC > HTC Android based
HTC Android based General HTC Android phones discussion, firmwares, solution, root, help
Old 09-30-2015, 20:16   #31 (permalink)
xx0o0xx1's Avatar
Member: 2033150
Thanks Meter: 624
Originally Posted by vanzan1 View Post
thx 4 the file but
zip problem cant extract system file from archive for the given 2 links
(unexpected end of archive)
redownload the file again should work
Old 10-24-2015, 10:31   #32 (permalink)
Member: 2477221
In flash file my imei no. Is null
Old 10-24-2015, 10:57   #33 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
You can repair imei using supported china boxes.
Old 11-05-2015, 11:16   #34 (permalink)
Member: 2164581
Sonork: 100.1670571
Thanks Meter: 6
Imei Invalid
after flash
... test, before you post any thing broda.
Old 11-05-2015, 23:22   #35 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Originally Posted by z3x1 View Post
Imei Invalid
after flash
Its already tested http://forum.gsmhosting.com/vbb/f485...l#post11079839
If imei invalid simply repair it using supported boxes.
Old 11-08-2015, 10:38   #36 (permalink)
Member: 2164581
Sonork: 100.1670571
Thanks Meter: 6
successfully repaired null imei 620g without anybox..
need root and some easy steps..
Old 11-23-2015, 07:24   #37 (permalink)
Member: 960725
Thank You,
it's works after flash should to Hard reset
Old 01-18-2016, 21:02   #38 (permalink)
Member: 1413143
Thanks Meter: 15
hi,
i have an 620G that give "Process has stop working" for 2 apps. Made hard reset, and same problem.
Can i flash it successfully with this fimware? i can't afford any mistakes with it!
Here are some info about the phone:
Old 02-12-2016, 19:49   #39 (permalink)
Member: 2488735
the problem with me . when i press download then puting USB the phone is just charge it didn't flashing . any solution
Old 02-13-2016, 05:09   #40 (permalink)
..::Nokian CareŽ::..'s Avatar
Member: 505794
Sonork: 100.1627614 QQ:1958018248
Thanks Meter: 2,266
Power off your phone then press volum up & down then plug usb...
Old 03-06-2016, 08:57   #41 (permalink)
AniAxn's Avatar
Member: 1045758
Sonork: 100.1613661(Offline)
Thanks Meter: 4,307
Hello,
I think this Firmware is not Good ..
Phone status is Restart on Boot loop ..
I Flash with this firmware ..
Result is Same !!
Also trying Format & after flash again but no luck ..
If have any Working Firmware ..Plz Share link ..
Wbr,
AniAXN
Old 06-13-2016, 10:53   #42 (permalink)
RICKY great's Avatar
Member: 641849
Sonork: 100.1619689
Thanks Meter: 44
both link file same or different
Old 07-23-2016, 15:22   #43 (permalink)
khalidahmed's Avatar
Member: 2298142
Thanks Meter: 240
HTC Desire 620G DUAL SIM D620h firmware. 100% workink file tested by me.
https://docs.google.com/uc?id=0B4jyo...xport=download
Old 07-23-2016, 15:29   #44 (permalink)
Member: 2298142
Thanks Meter: 240
Originally Posted by aselasanjeewab View Post
Please create post for using
HTC Desire 620 dual sim, HTC 620g, HTC 620h (A31MG_DUG_K44 Asia_India_1.12.720.001)
how to install it cheers Respect !!!!!
The Following User Says Thank You to khalidahmed For This Useful Post:
Old 07-31-2016, 17:21   #45 (permalink)
Member: 219296
Thanks Meter: 5
sorry, link not work
Page generated in 0.28963 seconds with 8 queries
