Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > HTC > HTC Android based
HTC Android based General HTC Android phones discussion, firmwares, solution, root, help
Old 08-15-2017, 08:21   #1 (permalink)
zeerik's Avatar
Member: 282066
Sonork: 100.1590696
Thanks Meter: 569
HTC M8 WLV Flash file needed
hi need this file please
8/13/2017 4:01:30 PM Reading information...
8/13/2017 4:01:30 PM Using Fastboot mode...
8/13/2017 4:01:30 PM Reading common information
8/13/2017 4:01:30 PM (bootloader) version: 0.5
(bootloader) version-bootloader: 3.19.0.0000
(bootloader) version-baseband: 1.12.20.1211
(bootloader) version-cpld: None
(bootloader) version-microp: None
(bootloader) version-main: 4.21.512.5
(bootloader) version-misc: PVT SHIP S-ON
(bootloader) serialno: FA4A2SF02177
(bootloader) imei: 990004298653373
(bootloader) imei2: Not Support
(bootloader) meid: 99000429865337
(bootloader) product: m8_wlv
(bootloader) platform: hTCBmsm8974
(bootloader) modelid: 0P6B20000
(bootloader) cidnum: LRA__001
(bootloader) battery-status: good
(bootloader) battery-voltage: 0mV
(bootloader) partition-layout: Generic
(bootloader) security: on
(bootloader) build-mode: SHIP
(bootloader) boot-mode: FASTBOOT
(bootloader) commitno-bootloader: e7c075a3
(bootloader) hbootpreupdate: 11
Old 08-15-2017, 09:03   #2 (permalink)
lastmile's Avatar
Member: 2482400
Sonork: 100.1677259
Thanks Meter: 115
htc m8 wlv
https://www.androidfilehost.com/?fid=24665542585483368
Old 08-15-2017, 09:07   #3 (permalink)
zeerik's Avatar
Member: 282066
Sonork: 100.1590696
Thanks Meter: 569
Originally Posted by lastmile View Post
bro my problem is that set was ok after update with mashmelo 6.0 baseband unknown i have call problem need sam file as info given above
Old 08-15-2017, 09:27   #4 (permalink)
lastmile's Avatar
Member: 2482400
Sonork: 100.1677259
Thanks Meter: 115
try this file
https://www.dropbox.com/s/25wc3ptiqs...2_4_7.zip?dl=0
Old 08-15-2017, 13:14   #5 (permalink)
zeerik's Avatar
Member: 282066
Sonork: 100.1590696
Thanks Meter: 569
after flash with same firmware acording to the info baseband still unknown
Old 08-15-2017, 14:17   #6 (permalink)
prasath_max's Avatar
Member: 584122
Thanks Meter: 30
You should be flash hboot.img
Old 08-15-2017, 14:33   #7 (permalink)
zeerik's Avatar
Member: 282066
Sonork: 100.1590696
Thanks Meter: 569
from where i can get this file ? and how to write it ?
Old 08-15-2017, 16:00   #8 (permalink)
Member: 584122
Thanks Meter: 30
Use XTC2CLIP Box or IR-Key use. can help to you
Old 05-06-2019, 10:28   #9 (permalink)
Member: 2637597
Sonork: 100.1680047
Thanks Meter: 11
Firmware Needed
c:\tool>fastboot getvar all
(bootloader) version-main: 4.17.605.17
(bootloader) serialno: FA48JSF01349
(bootloader) imei: 990004997644905
(bootloader) meid: 99000499764490
(bootloader) cidnum: VZW__001
(bootloader) commitno-bootloader: 981b9dde
(bootloader) gencheckpt: 0
all: Done!
finished. total time: 0.063s
Old 05-16-2019, 14:39   #10 (permalink)
Member: 2771307
Thanks Meter: 772
Here you can get the firmware for your phone with free and direct link
HTC Stock Firmware Database by HardReset.info Team
Files for your phone are:
First, write this file Hboot to update the Android version:
1. 0P6BIMG M8 WL M60 SENSE70 VZW MR VERIZON WWE 6.21.605.3 Radio 1.14.20.0930 CNV VZW 2.93002 release 470442 Hboot
then write this file to update full firmware:
2. 0P6BIMG M8 WL M60 SENSE70 VZW MR VERIZON WWE 6.21.605.3 Radio 1.14.20.0930 CNV VZW 2.93002
Page generated in 0.19846 seconds with 8 queries
