Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > HTC > HTC Android based
HTC Android based General HTC Android phones discussion, firmwares, solution, root, help
Old 08-15-2015, 23:14   #31 (permalink)
Member: 2444744
will that work with all htc models??
Old 08-29-2015, 19:35   #32 (permalink)
Member: 57712
Sonork: 1010
Thanks Meter: 49
hello bro
htc 816g mt6582 stock rom not working
after flash rom Desire 816gFarsi call 4.4.2 supported farsi language not working
any help for added arabic
thanks a lot
Old 09-17-2015, 21:19   #33 (permalink)
Member: 2151281
Sonork: 100.16528700
i have tested and working 100%
Old 10-04-2015, 11:30   #34 (permalink)
Member: 1798129
Sonork: kissforyou32
Thanks Meter: 2
didint work with me htc 816g mt6582
Old 10-04-2015, 11:31   #35 (permalink)
Member: 1798129
Thanks Meter: 2
please can any one post arabic firmware
Old 10-08-2015, 10:50   #36 (permalink)
Moderator
...:::SHAMIM:::...'s Avatar
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,712
Post
apk language unable is batter then root method arabic.
just go to play store download "localmore2" apps & follow the below method.
this method no need to root!
br,
shamim
Old 10-09-2015, 02:49   #37 (permalink)
Member: 2414762
Thanks Meter: 47
Is this method add Farsi or Persian language?
Old 10-09-2015, 02:52   #38 (permalink)
Member: 2414762
Thanks Meter: 47
You should flash new rom, i'm using this rom and it have Persian language, i not sure but it should have Arabic too (Post #2):
http://www.ir-tci.org/forum/showthread.php?t=237969
Old 10-28-2015, 17:49   #39 (permalink)
Member: 1013938
Nice post...works 100%
Old 11-11-2015, 03:01   #40 (permalink)
Member: 1838642
Sonork: 055
Thanks Meter: 5
please can any one post arabic firmware 816g 6582
Old 11-13-2015, 12:16   #41 (permalink)
Member: 839471
Thanks Meter: 34
please upload arabic firmware for htc phone really we need arabic firmware
The Following User Says Thank You to shafee3113 For This Useful Post:
Old 01-07-2016, 15:43   #42 (permalink)
Member: 1445590
Thanks Meter: 70
C:\Users\acer\Desktop\fastboot-win>fastboot getvar all
(bootloader) version: 0.5
(bootloader) version-bootloader: 3.19.0.0000
(bootloader) version-baseband: 01.01.010_U1030412_08.01.41007
(bootloader) version-cpld: None
(bootloader) version-microp: None
(bootloader) version-main: 1.10.1400.4
(bootloader) version-misc: PVT SHIP S-OFF
(bootloader) serialno: HC4AWYC03159
(bootloader) meid: 00000000000000
(bootloader) product: a51_dtul
(bootloader) platform: hTCBmsm8939
(bootloader) modelid: 0PFJ11000
(bootloader) cidnum: 11111111
(bootloader) battery-status: good
(bootloader) battery-voltage: 0mV
(bootloader) partition-layout: Generic
(bootloader) security: off
(bootloader) build-mode: SHIP
(bootloader) boot-mode: FASTBOOT
(bootloader) commitno-bootloader: a2fde288
(bootloader) hbootpreupdate: 11
(bootloader) gencheckpt: 0
(bootloader) mfg-name:
(bootloader) zip header checking...
(bootloader) shift signature_size for header checking..
FAILED (remote: 32 header error)
finished. total time: 58.257s
C:\Users\acer\Desktop\fastboot-win>fastboot flash 0PFJ11000.zip
unknown partition '0PFJ11000.zip'
error: cannot determine image filename for '0PFJ11000.zip'
I am get all this error help me
Old 01-11-2016, 19:00   #43 (permalink)
Member: 1839920
Thanks Meter: 46
i edit default.xml after Reboot my device default.xml Back as it was
help me
Old 01-12-2016, 15:28   #44 (permalink)
Member: 1480529
Sonork: 100.1612553
Thanks Meter: 12
Originally Posted by jamesjerss View Post
Htc Enable Arabic + All languages Only for Rooted Device
Note: Not supported all devices jus giv a try
* Device must b rooted
* Install Root explorer
* Open root explorer make backup default.xml frm below givn path
system/customize/CID/default.xml
* Download Below given edited default.xml file
* Copy to system/customize/CID/ replace it.
* Reboot yur device
Test nd post result
Download
[Password:jamesjerss]
Other way:
* Root your Device
* Install region changer from play store
PLEASE DON'T SAY THANKSJUST PRESS BUTTON
BUTTON
i try this htc one m7 but not work please help me i need arabic language.
The Following User Says Thank You to s.rahman For This Useful Post:
Old 01-25-2016, 08:19   #45 (permalink)
Member: 2168928
Thanks Meter: 8
Page generated in 0.20660 seconds with 8 queries
