Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > HTC > HTC Android based
HTC Android based General HTC Android phones discussion, firmwares, solution, root, help
Old 06-04-2015, 20:34   #1 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,219
Lightbulb Htc Enable Arabic + All languages Only for Rooted Device
Note: Not supported all devices jus giv a try
* Device must b rooted
* Install Root explorer
* Open root explorer make backup default.xml frm below givn path
system/customize/CID/default.xml
* Download Below given edited default.xml file
* Copy to system/customize/CID/ replace it.
* Reboot yur device
Test nd post result
Download
[Password:jamesjerss]
Other way:
* Root your Device
* Install region changer from play store
PLEASE DON'T SAY THANKSJUST PRESS BUTTON
BUTTON
The Following 45 Users Say Thank You to jamesjerss For This Useful Post:
Old 06-05-2015, 19:33   #2 (permalink)
Member: 1687437
Thanks Meter: 7
i have tested and working 100% HTC One
The Following 3 Users Say Thank You to murad312 For This Useful Post:
Old 06-07-2015, 16:31   #3 (permalink)
sobaro's Avatar
Member: 630795
Thanks Meter: 162
Does it work with all variants Roms or just Europe Roms ?
Thank you !
The Following User Says Thank You to sobaro For This Useful Post:
Old 06-07-2015, 16:40   #4 (permalink)
Member: 217891
Thanks Meter: 226
and without risk ? ..........
The Following User Says Thank You to moh_boulk17 For This Useful Post:
Old 06-07-2015, 16:53   #5 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,219
Yes should wrk vit al variants no risks.
The Following User Says Thank You to jamesjerss For This Useful Post:
Old 06-08-2015, 04:05   #6 (permalink)
Member: 31027
Thanks Meter: 175
yes all variants
but no update
its same morelocal but you add in lang system and need unlock bootloader
Old 06-08-2015, 04:23   #7 (permalink)
NKhan_Gsm's Avatar
Member: 1646177
Sonork: 100.1604654
Thanks Meter: 338
There are tow default.xml files in zip file which one should be used for replacing default.xml ?
WBR
Old 06-08-2015, 08:20   #8 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,219
WBR
use any 1 both has arabic check the folder name there i hav gvn supported lang.
Sent from my XT1068 using Tapatalk
The Following 3 Users Say Thank You to jamesjerss For This Useful Post:
Old 06-09-2015, 03:49   #9 (permalink)
otherboy123's Avatar
Member: 2006794
Sonork: 100.1664636
Thanks Meter: 82
there have myanmar burma launguages ?
Old 06-09-2015, 04:38   #10 (permalink)
Member: 1298774
Sonork: 100.1584126
Thanks Meter: 84
i try in d816h and not found folder CID in customiz
Old 06-10-2015, 17:53   #11 (permalink)
Member: 164505
Thanks Meter: 16
i make all steps to add arabic XML file but no arabic
please help
Thanks
Old 06-11-2015, 07:21   #12 (permalink)
Member: 2400584
Absolutely fine with HTC mobiles, thanks for this. And if you have something for non rooted device, plz upload.
Old 06-11-2015, 07:39   #13 (permalink)
Faheem Anjum's Avatar
Member: 399832
Thanks Meter: 23,775
@All
there is many firmware which have limited language infect if you delete are replace and the xml file . still you cant get these arabic language . i have a solution which can help to add these language which not enabled with xml file
The Following 4 Users Say Thank You to Faheem Anjum For This Useful Post:
Old 06-11-2015, 07:48   #14 (permalink)
Member: 1298774
Sonork: 100.1584126
Thanks Meter: 84
Originally Posted by Faheem Anjum View Post
@All
Can share it
Sent from my SM-N9005 using Tapatalk
Old 06-12-2015, 16:12   #15 (permalink)
Member: 217891
Thanks Meter: 226
@All
can u share it ......
Page generated in 0.64767 seconds with 7 queries
