HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
08-11-2014, 04:51 | #1 (permalink) |
Freak Poster Join Date: Apr 2013 Location: Bangladesh Age: 40
Member: 1910629 Status: Offline Sonork: 100.1653190 Thanks Meter: 65 | htc golfu restart problem Model : GOLFU IMEI : 352276050731686 Build : 2.00.415.2 CID : HTC__J15 HBoot : 1.31.0000 MID : PL0110000 Security : ON Region : HTC-GCC help me how to flash with link thank u..... |
08-12-2014, 00:00 | #2 (permalink) |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | * Install ADB and Fastboot on your computer. Download here * unlock yur bootloader tutorial here 2nd post http://forum.gsmhosting.com/vbb/f485...reset-1846891/ * After unlock bootloader Root yur mobile put yur mob into fastboot mode nd run the install-superboot-windows batch file. Download here * After root complete install custom recovery Download here ClockworkMod Recovery * put yur mob into fastboot mode run the command from where recovery file placed (shift right click open windows command here ) Run tis command to flash the recovery fastboot flash recovery recovery.img (it vil tak 10min to boot small bug) (rename the file as recovery) * Download this rom Here * Extract oly boot.img from the rom nd flash it 1st. put yur mob into fast boot mode launch the command from where yu saved the file (shift right click open windows command here ) Run these command 1by 1 Fastboot flash boot boot.img fastboot erase cache fastboot reboot * Now copy the Rom into external memory card nd insert into yur mobile * put yur mob into bootloader mode there select recovery there full factory reset den goto advance wipe delvik cache * Now goto sdcard path nd install the rom |
The Following User Says Thank You to jamesjerss For This Useful Post: |
08-15-2014, 18:48 | #3 (permalink) |
Member: 1910629 Status: Offline Sonork: 100.1653190 Thanks Meter: 65 | htc dev registration problem many time try but....
i am bangladeshi help me...... |
08-15-2014, 19:23 | #4 (permalink) | |
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Quote:
password example : Aa1349757 (try lik this) | |
08-17-2014, 21:19 | #5 (permalink) | |
Member: 1910629 Status: Offline Sonork: 100.1653190 Thanks Meter: 65 | .failed pro Quote:
fastboot flash recovery recovery.img and boot image flashing failed problem....... | |
