Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > HTC > HTC Android based
HTC Android based General HTC Android phones discussion, firmwares, solution, root, help
Old 04-14-2014, 11:30   #1 (permalink)
Cheater -Don't Deal with him-
Member: 2089356
Sonork: Threema: 3N5W6VV9
Thanks Meter: 520
HTC htc pd98100 G10
the phone is bricked when i boot to bootloader i cant perform reset
how can i flash phone ? cause i dont know nothing for htc just samsung
so what i need ? sd card fastboot rom ? how to
Old 04-14-2014, 22:52   #2 (permalink)
..::Rizwan::..'s Avatar
Member: 777415
Sonork: 1589702
Thanks Meter: 1,420
You Need To Learn Some Basic For HTC Flashing And This Section Too
Coz if U Need any Help You Need To Provide Here Some Information Then
someone Can Help You
Go here And Learn Some Basic
http://forum.gsmhosting.com/vbb/f485...r-etc-1638931/
The Following User Says Thank You to ..::Rizwan::.. For This Useful Post:
Old 04-14-2014, 22:58   #3 (permalink)
Member: 2089356
Thanks Meter: 520
Okay i learn how to get cid after that what to do ??
If i helped you press thanks button ↓
Old 04-16-2014, 10:18   #4 (permalink)
Member: 777415
Sonork: 1589702
Thanks Meter: 1,420
Now Paste here Ur Detail CID Main version Flash Inside Ur Phone
Old 04-18-2014, 08:50   #5 (permalink)
Member: 2089356
Thanks Meter: 520
next step please
C:\Users\Besfort\Desktop\Fastboot+ADB(20926)\Fastb oot+ADB\Win32>fastboot getvar
all
(bootloader) version: 0.5
(bootloader) version-bootloader: 2.00.0027
(bootloader) version-baseband: 26.14.04.28_M
(bootloader) version-cpld: None
(bootloader) version-microp: 0438
(bootloader) version-main:
(bootloader) serialno: 123456789012
(bootloader) imei: 356812043314093
(bootloader) product: ace
(bootloader) platform: HBOOT-7230
(bootloader) modelid: PD98*****
(bootloader) cidnum: HTC__102
(bootloader) battery-status: good
(bootloader) battery-voltage: 4052mV
(bootloader) partition-layout: Generic
(bootloader) security: on
(bootloader) build-mode: SHIP
(bootloader) boot-mode: FASTBOOT
(bootloader) commitno-bootloader: 743ca94a
(bootloader) hbootpreupdate: 11
(bootloader) gencheckpt: 0
(bootloader) region-id: 0
all: Done!
finished. total time: 0.027s
So now what ? what should i do now ?
Old 04-18-2014, 09:00   #6 (permalink)
Member: 777415
Sonork: 1589702
Thanks Meter: 1,420
Download This And Flash Ur Handset In Fastboot USB Mode Connected Run this EXE File And follow Steps
RUU_Ace_Sense30_S_hTC_Asia_WWE_3.13.707.4_R_Radio_ 12.65.60.29_26.14.04.28_M_release_234022_signed.ex e
If U Get Any Error Let me Know
Old 04-18-2014, 09:32   #7 (permalink)
Member: 2089356
Thanks Meter: 520
Well i downloaded the rom i boted in fastboot and here is error
Phone is already restarted in fastboot
And it end with this
Old 04-18-2014, 10:16   #8 (permalink)
Member: 777415
Sonork: 1589702
Thanks Meter: 1,420
Look Like Problem In Ur fastboot Drivers Or USB Cable Connection Problem Please Upload Device manager Picture Too When Handset Connected Via Fastboot USB
Old 04-18-2014, 10:37   #9 (permalink)
Member: 2089356
Thanks Meter: 520
looks fine /
Old 04-18-2014, 15:52   #10 (permalink)
Member: 777415
Sonork: 1589702
Thanks Meter: 1,420
Yes Looks Fine Charge UR Handset battery Minimum 60% & Change Port If possible Check On Other PC Fresh Driver Installation
Old 04-18-2014, 23:35   #11 (permalink)
Member: 2089356
Thanks Meter: 520
I did it still same error ! I will download more rooms and post result , how can i flash via cmd with fastboot command if i have a zip rom on desktop
Old 04-19-2014, 08:26   #12 (permalink)
Member: 2089356
Thanks Meter: 520
i think i know the problem bootloader veersion is "2.00.0027"
rom bootloader version 3.13.468.2 something like that
Old 04-19-2014, 11:42   #13 (permalink)
Member: 777415
Sonork: 1589702
Thanks Meter: 1,420
no u can flash via fast boot zip
'' fastboot erase cache ''
'' fastboot oem rebootRUU ''
'' fastboot flash zip rom.zip ''
after done '' fastboot reboot ''
Old 04-19-2014, 16:57   #14 (permalink)
Member: 2089356
Thanks Meter: 520
i think is emmc error or internal storage demaged
C:\Users\Besfort\Desktop\Fastboot+ADB(20926)\Fastb oot+ADB\Win32>fastboot clear c
ache
usage: fastboot [ <option> ] <command>
commands:
update <filename> reflash device from update.zip
flashall flash boot + recovery + system
flash <partition> [ <filename> ] write a file to a flash partition
erase <partition> erase a flash partition
format <partition> format a flash partition
getvar <variable> display a bootloader variable
boot <kernel> [ <ramdisk> ] download and boot kernel
flash:raw boot <kernel> [ <ramdisk> ] create bootimage and flash it
devices list all connected devices
continue continue with autoboot
reboot reboot device normally
reboot-bootloader reboot device into bootloader
help show this help message
options:
-w erase userdata and cache
-s <serial number> specify device serial number
-p <product> specify product name
-c <cmdline> override kernel commandline
-i <vendor id> specify a custom USB vendor id
-b <base_addr> specify a custom kernel base address
-n <page size> specify the nand page size. default:
2048
C:\Users\Besfort\Desktop\Fastboot+ADB(20926)\Fastb oot+ADB\Win32>fastboot erase c
ache
erasing 'cache'...
FAILED (remote: erasing error!)
finished. total time: 0.016s
C:\Users\Besfort\Desktop\Fastboot+ADB(20926)\Fastb oot+ADB\Win32>erase -w
Could Not Find C:\Users\Besfort\Desktop\Fastboot+ADB(20926)\Fastb oot+ADB\Win32\-
w
C:\Users\Besfort\Desktop\Fastboot+ADB(20926)\Fastb oot+ADB\Win32>flashall
'flashall' is not recognized as an internal or external command,
operable program or batch file.
C:\Users\Besfort\Desktop\Fastboot+ADB(20926)\Fastb oot+ADB\Win32>update
'update' is not recognized as an internal or external command,
C:\Users\Besfort\Desktop\Fastboot+ADB(20926)\Fastb oot+ADB\Win32>fastboot flashal
l
error: neither -p product specified nor ANDROID_PRODUCT_OUT set
C:\Users\Besfort\Desktop\Fastboot+ADB(20926)\Fastb oot+ADB\Win32> fastboot erase
cache
erasing 'cache'...
finished. total time: 0.025s
C:\Users\Besfort\Desktop\Fastboot+ADB(20926)\Fastb oot+ADB\Win32>fastboot oem reb
ootRUU
(bootloader) [SD_HW_ERR] read data fail in CMD18
(bootloader) [SD_HW_ERR] SD: Read data fail..
(bootloader) [ERR] partition_read_emmc(453): error 1
OKAY [ 0.056s]
finished. total time: 0.058s
C:\Users\Besfort\Desktop\Fastboot+ADB(20926)\Fastb oot+ADB\Win32>fastboot flash z
ip htcrom.zip
error: cannot load 'htcrom.zip'
ip htcrom.zip
ip htcroom.zip
sending 'zip' (334030 KB)...
OKAY [ 57.427s]
writing 'zip'...
(bootloader) adopting the signature contained in this image...
(bootloader) signature checking...
FAILED (remote: not allowed)
finished. total time: 99.506s
Old 04-20-2014, 14:27   #15 (permalink)
Member: 777415
Sonork: 1589702
Thanks Meter: 1,420
if you have jtag box you can easily S-off Ur Device + Make Super CID Then You Can Flash Any Rom any Region No Problem (If You Have Jtag Box)
Page generated in 0.22969 seconds with 9 queries
