HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
05-23-2015, 18:40 | #181 (permalink) | |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Quote:
Download this htc fastboot exe here Extract fastboot folder Copy firmware.zip to fastboot folder Cnnt yur device in fastboot mode In fastboot folder Hold shif+right click select open command window here Run followng cmmds fastboot devices fastboot oem rebootRUU Fastboot flash zip 5.12.502.2.firmware.zip fastboot reboot after reboot again cnnt yur device in bootloader mode nd run the Lollipop RUU | |
The Following User Says Thank You to jamesjerss For This Useful Post: |
05-24-2015, 09:57 | #182 (permalink) | |
Junior Member Join Date: Oct 2013 Location: Pune-India
Member: 2039736 Status: Offline Thanks Meter: 5 | Quote:
I tried & getting following "C:\ADBFAST>fastboot flash zip 5.12.502.2.firmware.zip target reported max download size of 1514139648 bytes sending 'zip' (44105 KB)... OKAY [ 3.016s] writing 'zip'... (bootloader) adopting the signature contained in this image... (bootloader) signature checking... FAILED (remote: not allowed) finished. total time: 8.189s " | |
05-24-2015, 10:57 | #183 (permalink) | |
Please ignore previous post reply, there was a misake in using the fastboot file executed using another fastboot file the execution & updating your firmware was successful also after that i executed the latest oem RUU downloaded from HTC website for AT&T the RUU got sucessfully installed/executed now my phone is updated with new os 5.0.2 software 7.23.502.1 without any problem thanks james for you help/support | |
05-27-2015, 08:57 | #184 (permalink) |
No Life Poster Join Date: Jan 2013 Location: HUAWEI FRP KEY imei-code
Member: 1870489 Status: Offline Sonork: 100.1663831 Thanks Meter: 483 | pls give me this flash file ruu Device Info Security status: S-ON Model Id: PN0710000 Custom Id: HTC__J15 (HTC-GCC) Serial number: SH38CW900201 Product: m7_ul IMEI: 357864058000272 Platform: HBOOT-8064 Bootloader ver: 1.61.0000 Baseband ver: 4T.35.3218.16 Cpld verersion: None Microp version: None Main version: 7.19.401.2 Battery Status: good Battery Volt: 3824mV PartitionLayout: Generic Commitno bl: dirty-0e2a13e5 Hbootpreupdate: 11 Get device information done , time used 0.23s Time used : 0.3 s |
05-27-2015, 13:45 | #185 (permalink) |
Insane Poster Join Date: Apr 2014 Location: casablanca
Member: 2176686 Status: Offline Thanks Meter: 13 | Device Info Security status: S-ON Model Id: PN0710000 Custom Id: HTC__J15 (HTC-GCC) Serial number: HT45YW901511 Product: m7_ul IMEI: 359405052813183 Platform: HBOOT-8064 Bootloader ver: 1.57.0000 Baseband ver: 4T.29.3218.08 Cpld verersion: None Microp version: None Main version: 6.09.401.11 Battery Status: good Battery Volt: 4024mV PartitionLayout: Generic Commitno bl: dirty-6d8a0b9b Hbootpreupdate: 11 plz need rom |
05-27-2015, 15:45 | #186 (permalink) | ||
M7_UL_L50_SENSE60_MR_HTC_Europe_7.19.401.2_Radio_4 T.35.3218.16_10.33Q.1718.01L_release_421790_signed rename yur file as PN07IMG Before req check my thread correctly Flashing guide here http://forum.gsmhosting.com/vbb/f485...guide-1952646/ | ||
05-27-2015, 22:48 | #188 (permalink) | ||
Sent from my XT1068 using Tapatalk | ||
05-28-2015, 14:31 | #190 (permalink) |
No Life Poster Join Date: Aug 2006 Location: gsmchaudhrayarshad Age: 43
Member: 328688 Status: Offline Thanks Meter: 2,282 | hi this one lollypops but it freezing which rom i must flash it Model : M7_UL IMEI : 355859051079960 Build : 7.21.980.5 CID : VODAP021 HBoot : 1.61.0000 MID : PN0714000 Security : ON Region : VODA-Australia Model : M7_UL IMEI : 355859051079960 Build : 7.21.980.5 CID : VODAP021 HBoot : 1.61.0000 MID : PN0714000 Security : ON Region : VODA-Australia <<<< Identifier Token Start >>>> 66236DF8A1C45E08E05338F690636F6F 55F42CAB8D1698DF890338417C93576D FF60ED657D7AA1ACF465F28C72F6CA95 86F2D897D1B26863B1744AD8D7F1141F 9F170DD8BF0D80D98D264D7293B7F64B 0F5D5939F8F3A80F6BD8146CE18B470E 229BF1D242C0ADB88C526E7C4DFD32E5 03C9BBD237EECC666AA5496211AC3750 39FE1726B3CCD0E68EB58DA9223496C7 87669A65AAD72F844445E87787F9DFB1 571E1EAFB3957DC33359CF9568C65BD7 2D6D4A1A9A3B204C95DE35BFDBDFB99D 459D0D0D99223BC675272AF1A2337A3A 57C619681093420571576FF213DF8197 DB4E4AC3BE0714690E8783E377AA8211 B66B3207ACE475897F5CD654C8141718 <<<<< Identifier Token End >>>>> |
05-28-2015, 15:32 | #191 (permalink) | |
unlock bootloder flash custom recovery flash custom rom check files n 1st page | |
05-28-2015, 16:32 | #192 (permalink) |
No Life Poster Join Date: Feb 2007 Location: GSM World
Member: 457470 Status: Offline Thanks Meter: 159 | i have an htc m7 sprint for unlock, the os is 5.02. but when i use other sim card it is not asking for network unlock code. hboot is 1.60 and s-on. how to unlock it. i have riff if possible to downgrade hboot |
05-28-2015, 16:37 | #193 (permalink) |
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | You can not unlock yur device officially But yu can unlock by sme tricks nd hack methods google it for unlock solution. To Downgrd yur bootloader yu need to s-off yur device yu can s-off yur device using java card nd sunshine apk but its not free. |
06-02-2015, 00:41 | #195 (permalink) | |
Registered User Join Date: Jul 2012
Member: 1784151 Status: Offline Sonork: 0 Thanks Meter: 75 | Quote:
Thanks | |
