HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
10-01-2015, 21:55 | #1 (permalink) |
Freak Poster Join Date: Nov 2005
Member: 195855 Status: Offline Thanks Meter: 26 | HTC M7ul restarts in every few mins C:\Users\admin\Desktop\ADB>fastboot getvar all (bootloader) version: 0.5 (bootloader) version-bootloader: 1.57.0000 (bootloader) version-baseband: 4A.27.3263.27 (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: (bootloader) version-misc: PVT SHIP S-ON (bootloader) serialno: FA364W916759 (bootloader) imei: 357864xxxxxxxxx (bootloader) meid: 00000000000000 (bootloader) product: m7_ul (bootloader) platform: HBOOT-8064 (bootloader) modelid: PN0710000 (bootloader) cidnum: ORANG001 (bootloader) battery-status: good (bootloader) battery-voltage: 3838mV (bootloader) partition-layout: Generic (bootloader) security: on (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: dirty-660ef031 (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 all: Done! finished. total time: 0.164s fastboot info we can see imei number gsm_masud7 suggested me to download this file n flash it...... PN07IMG_M7_UL_L50_SENSE60_MR_Orange_UK_7.19.61.10_ Radio_4T.35.3218.16_10.33Q.1718.01L_release_428118 _signed.zip i relocked the bootloader n when i try to flash with above file it gives error , HTC SPECIAL FASTBOOT DRIVERS INFO IS HERE ..... C:\Users\admin\Desktop\special Htc fastboot driver>fastboot flash zip PN07IMG.zi p sending 'zip'... (43284 KB) OKAY sending time = 3.136 secs writing 'zip'... (bootloader) adopting the signature contained in this image... (bootloader) signature checking... (bootloader) rom parsing start ... (bootloader) rom parsing finish ... (bootloader) zip header checking... (bootloader) zip info parsing... (bootloader) Read zipped android_info fail FAIL22 loading zip info fail Please check if you flash part FAILED (remote: 22 loading zip info fail Please check if you flash part) ADB FASTBOOT DRIVERS INFO HERE BELOW..... C:\Users\admin\Desktop\ADB>fastboot flash zip PN07IMG.zip target reported max download size of 1514139648 bytes Invalid sparse file format at header magi error: write_sparse_skip_chunk: don't care size 184138016 is not a multiple of t he block size 4096 sending sparse 'zip' (1478648 KB)... error: write_sparse_skip_chunk: don't care size 184138016 is not a multiple of t he block size 4096 error: write_sparse_skip_chunk: don't care size 184138016 is not a multiple of t he block size 4096 OKAY [139.093s] writing 'zip'... (bootloader) signature checking... FAILED (remote: 12 signature verify fail) finished. total time: 280.252s So let me know am i flashing with wrong file r what ??? |
10-02-2015, 00:57 | #3 (permalink) | |
Member: 195855 Status: Offline Thanks Meter: 26 | Quote:
fastboot oem rebootRUU fastboot flash zip PN07IMG.zip i have done all this commands then it gives error ..... sending 'zip'... (43284 KB) OKAY sending time = 3.136 secs writing 'zip'... (bootloader) adopting the signature contained in this image... (bootloader) signature checking... (bootloader) rom parsing start ... (bootloader) rom parsing finish ... (bootloader) zip header checking... (bootloader) zip info parsing... (bootloader) Read zipped android_info fail FAIL22 loading zip info fail Please check if you flash part FAILED (remote: 22 loading zip info fail Please check if you flash part) as i mention above ............ | |
10-02-2015, 16:56 | #5 (permalink) | |
No Life Poster Join Date: Jan 2014 Location: GM7
Member: 2102992 Status: Offline Sonork: 100.1626305 Thanks Meter: 2,763 | Not Seem Radio Ver: then you find like seem Radio Ver: 4A.27.3263.27 rom Quote:
other way Flash custom rom to recover yur device Don't forget to press Thanks Button Br M@SUD Last edited by jamesjerss; 10-02-2015 at 17:16. Reason: quote remove | |
10-02-2015, 17:14 | #6 (permalink) |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | The problem is your old bootloader is not adopting with the new Bootloader tats why getting such errors. To prevent these errors flash older version kitkat stock or need to find lollipop firmware zip which you can extract from lp ota's. Or Try the above file using Ycable |
10-02-2015, 18:51 | #7 (permalink) | |
Note :No need S-off or Super cid Procedure: Unlock yur Bootloader 1st manual wayTutorial here Or Use Below given Tool [Tool] HTX Multi Tool V1.0 Beta Tool Released! Credits Rahul_Bhutani Download Twrp Recovery For Yur Model Frm Below m7u m7ul m7vzw m7wls Rename the Downloaded Twrp Recovery as recovery nd run below cmmd to flash Cnnt yur mob n fastboot mode fastboot flash recovery recovery.img Download Tested CustomRom Here Credits Team Venom * Go to recovery mode in your device , then plug in USB Flash drive with USB OTC and connect to your device OTG usb Image Below * Select Advance >> Mount USB OTG , select Install located to ROM in Flash drive * Then just flash ROM * Wait for moment until Successfully Done and reboot your device Note : If yu dnt hav usb otg sideload to push yur rom into yur internal Memory in twrp select advance enable adb slideload den opn Htx tool there goto adb tab nd select slideload nd show the Rom path to Load | |
10-02-2015, 22:26 | #8 (permalink) |
Member: 195855 Status: Offline Thanks Meter: 26 | well i downloaded twrp recovery v2.6.3.3 and custom rom viperone+9.0.0-fix.zip flashed the twrp recovery in fastboot and then done everything as said above when i select sideload in htx it gives uploading wait......fail |
10-02-2015, 23:35 | #9 (permalink) |
Member: 195855 Status: Offline Thanks Meter: 26 | i flashed it with custom rom( DU_m7_5.1.1_20150925-1945.v9.7-OFFICIAL.zip) and the restarts problem is solved but still IMEI AND BASEBAND IS UNKNOWN ...now how i solve this problem plz help me |
10-03-2015, 20:37 | #11 (permalink) |
Member: 2102992 Status: Offline Sonork: 100.1626305 Thanks Meter: 2,763 | br here all system how custom rom install Team Venom Custom Rom Many Time Tested by Me you install Team Venom Custom Rom Then solve your problem if not solve your problem flash stock htc-m7-all-all-carriers-m7-u-ul-m7vzw-m7wls-easly-recover-official-lollipop-ruu by jamesjerss Don't forget to press Thanks Button Br M@SUD |
10-04-2015, 02:09 | #13 (permalink) | |
