Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > HTC > HTC Android based
HTC Android based General HTC Android phones discussion, firmwares, solution, root, help
Old 03-08-2017, 09:27   #16 (permalink)
Moderator
...:::SHAMIM:::...'s Avatar
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,713
Bye the way, Your Phone is working thats fine
Recovery Doesn't happened to you anymore.
Old 03-14-2017, 17:16   #17 (permalink)
Member: 1910005
Thanks Meter: 10
Device Info
Security status: S-ON
Model Id: 0P6B67000
Custom Id: HTC__J15 (HTC-GCC)
Serial number: HC53AWM01415
Product: m8_ul
IMEI:
Platform: hTCBmsm8974
Bootloader ver: 3.19.0.0000
Baseband ver: 1.29.214500021.12G
Cpld verersion: None
Microp version: None
Main version: 6.21.401.1
Battery Status: good
Battery Volt: 0mV
PartitionLayout: Generic
Commitno bl: 205bdca3
Hbootpreupdate: 11
i need this device firmware,
i tried to flash with this firmware 0P6BIMG_M8_UL_M60_SENSE70_MR_HTC_Europe_6.12.401.4 _Radio_1.29.214500021.12G_20.72.4196t.01_release_4 64360_signed.zip
but get FAILED
Here is the RBsoft logs
Connecting to server wait..Ok
Login Success
Credit : 0
Rebooting Phone To RUU Mode..Ok
Loading firmware It may Take Some Time
sending 'zip'... (53965 KB) OKAY
writing 'zip'... (bootloader) adopting the signature contained in this image...
(bootloader) signature checking...
(bootloader) zip header checking...
(bootloader) zip info parsing...
(bootloader) checking model ID...
FAIL41 model id check fail
sending time = 2.655 secs
FAILED (remote: 41 model id check fail)
Execution time is 6(s)
i tried via adb fastboot method and sdcard method too, but same result,
Old 03-16-2017, 13:11   #18 (permalink)
Moderator
Sitlay KING's Avatar
Member: 1483853
Sonork: 100.1611111
Thanks Meter: 1,628
Originally Posted by navasnoozy View Post
Device Info
Model Id: 0P6B67000
Product: m8_ul
IMEI:
Battery Volt: 0mV
Hbootpreupdate: 11
but get FAILED
Login Success
Credit : 0
Lock you bootloader if its unlocked and flash this firmware.
http://download1514.mediafire.com/fc..._GeM_FlAsH.rar
If you need more help , post it below.
Thanks
Old 03-16-2017, 14:38   #19 (permalink)
Member: 2696091
Sonork: world wide
Thanks Meter: 4
what is the password sir
Old 03-16-2017, 14:43   #20 (permalink)
Member: 2696091
Sonork: world wide
Thanks Meter: 4
Model : M8_UL
IMEI : 35xxxxxxxxxxxxx
Build : 6.21.401.1
CID : HTC__J15
HBoot : 3.19.0.0000
MID : 0P6B67000
Security : ON
Region : HTC-GCC
RBSofts V1.5 Mobile Tool.
need firmware
Old 03-16-2017, 15:01   #21 (permalink)
Moderator
Member: 1483853
Sonork: 100.1611111
Thanks Meter: 1,628
www.gem-flash.com
use this as password
Old 03-16-2017, 15:05   #22 (permalink)
Member: 2696091
Sonork: world wide
Thanks Meter: 4
Originally Posted by Sitlay KING View Post
www.gem-flash.com
extracting error ...post without password file sir
Old 03-16-2017, 15:18   #23 (permalink)
Moderator
Member: 1483853
Sonork: 100.1611111
Thanks Meter: 1,628
post the error with pic.
The file and the password is perfectly correct.
Old 03-28-2017, 07:46   #24 (permalink)
Member: 2611311
Thanks Meter: 4
I need RUU for HTC M8 cidnum: HTC__G09
someone can help me?
Old 03-29-2017, 06:49   #25 (permalink)
Moderator
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,713
Post here your phone fastboot getvar all info.
Old 03-29-2017, 11:32   #26 (permalink)
Member: 136052
Thanks Meter: 75
www.gem-flash.com
password not correct (((
Old 03-30-2017, 14:29   #27 (permalink)
LordMen007's Avatar
Member: 184793
Sonork: 100.1574609
Thanks Meter: 45
bootloader is relocked
version : 0.5
version-bootloader : 3.19.0.0000
version-baseband : 1.29.214500021.12G
version-cpld : None
version-microp : None
version-main : 6.12.161.4
version-misc : PVT SHIP S-ON
serialno : FA46MWM00677
imei : xxxxxxxxx590
imei2 : Not Support
meid : 00000000000000
product : m8_ul
platform : hTCBmsm8974
modelid : 0P6B10000
cidnum : VODAP304
battery-status : good
battery-voltage : 0mV
partition-layout : Generic
security : on
build-mode : SHIP
boot-mode : FASTBOOT
commitno-bootloader : 76df2b54
hbootpreupdate : 11
gencheckpt : 0
thanks in advane
Old 03-31-2017, 11:42   #28 (permalink)
Registered User
Member: 763623
Thanks Meter: 37
(bootloader) version: 0.5
(bootloader) version-bootloader: 3.19.0.0000
(bootloader) version-baseband: 1.29.214500021.12G
(bootloader) version-cpld: None
(bootloader) version-microp: None
(bootloader) version-main:
(bootloader) version-misc: PVT SHIP S-ON
(bootloader) serialno: HT46AWM00672
(bootloader) imei: 352442060229646
(bootloader) imei2: Not Support
(bootloader) meid: 00000000000000
(bootloader) product: m8_ul
(bootloader) platform: hTCBmsm8974
(bootloader) modelid: 0P6B65000
(bootloader) cidnum: HTC__038
(bootloader) battery-status: good
(bootloader) battery-voltage: 0mV
(bootloader) partition-layout: Generic
(bootloader) security: on
(bootloader) build-mode: SHIP
(bootloader) boot-mode: FASTBOOT
(bootloader) commitno-bootloader: 205bdca3
(bootloader) hbootpreupdate: 11
(bootloader) gencheckpt: 0
all: Done!
finished. total time: 0.047s
need firmware
tnx in advance
Old 03-31-2017, 15:52   #29 (permalink)
Registered User
Member: 763623
Thanks Meter: 37
unable to update
sir i hav dis file but unable to update handset ..there is no sdcard slot in handset.. i tried fastboot ruu and fastboot zip flashing it says (unable to load op6bimg.zip)
plz help me
tnx
handset is in normal condition som one flash it with custom rom twrp recovery
handset baseband is unknown...
i hav locked bootloader ..it shows on screen relocked..but still unable to flash
tnx in advance
Old 03-31-2017, 16:06   #30 (permalink)
Moderator
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,713
plz help me
tnx
tnx in advance
Htc M8 Must be have Sd card Slot!
If no, install zip file via USB OTG Method. This way same like sd card method just put the file in usb drive and connect usb drive with usb otg.
Enter phone Bootloader mode and Start flash.
If you doesn't getting my way then use search button after you will get many others way or tutorial to update this rom.
Best Regards
Shamim
Page generated in 0.25275 seconds with 8 queries
