Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > HTC > HTC Android based
HTC Android based General HTC Android phones discussion, firmwares, solution, root, help
Old 11-23-2014, 05:14   #1 (permalink)
Super Moderator
Member: 813309
Thanks Meter: 1,912
Htc M8 COLLECTION of Stock backup's
Welcome to the M8 Stock backup collection thread, as i have noticed on the HTC One X RUU's where very rare in the end and the latest weren't even released (leaked) at all. The stock backup is a saviour to people who did not make them !
If you made a stock nandroid backup please share it here so users have a place to collect one if they are in need ! If you can't host it at least for a longer period of time i can take over the nandroid backup and host it myself.
When you have a stock backup ready you can upload it to MEGA or Android File Host for free :
MEGA
Android File Host
How do i backup the stock HTC recovery ?
Boot the custom recovery, preferably with Philz touch recovery as it will back up the stock recovery for sure, you need the following command to boot it and not flash it over the stock recovery :
fastboot boot recovery_filename.img (this does not work on the latest 3.xx firmwares !!! we need to get the stock recoveries from the OTA files)
Then make a full nandroid backup, the stock recovery is located inside the backup folder
The OTA files can be found here in the OTA files and update discussion thread thanks to exocetdj and nintendolinky
How do i find the correct backup here ?
perform the following fastboot commands to determine the correct one :
fastboot getvar version-main
fastboot oem readcid
fastboot getvar all (if you post this one please delete the serial and IMEI !)
When the main version is EMPTY you check your CID and go from there, compare the cid and the hboot number :
3.16 hboot = 1.12 / 1.54 software
3.18 hboot = 2.22 software
3.19 hboot = 3.xx software
Take the main version number and CID and check if it exists in the collection below ! You can restore a lower nandroid backup than your main version actually is !!! when you have as example 2.22.401.5 and that's not available you can use a 1.54.401 version for instance, flash back the matching stock recovery and go through all the OTA's again.
Note :
The WWE (World Wide English) nandroid backups have the same main version build numbers. All these nands have the main number that is based on the x.xx.401.xx build and all these CIDS are compatible
HTC__001
HTC__E11
HTC__102
HTC__203
HTC__405
HTC__Y13
HTC__304
HTC__A07
HTC__002
HTC__016
HTC__032
HTC__J15
HTC__M27
HTC__A48
HTC__K18
So if you are looking for a 401 main nandroid backup you can pick one of these CIDs, restore it and flash back the stock recovery then perform OTA if you wish/needed (do NOT relock the bootloader before you have done at least 1 official OTA !!!)
[HIDE]
CID ORANG001
2.26.61.1 - TWRP Thanks to exocetdj
1.54.61.5 - CWM Philz touch Thanks to Stuart0001
1.54.61.5 - CWM Philz touch Thanks to Brds7t7
1.54.61.5 - TWRP Thanks to Brds7t7
CID ORANG202
1.70.73.2 - TWRP Thanks to ckpv5
1.54.73.5 - TWRP Thanks to ckpv5
CID T-MOB102
2.23.112.x - CWM Philz touch Thanks to stoana
CID T-MOB009
1.57.118.2 - TWRP Thanks to airmon.ru
CID VODAP001 / VODAP102 / VODAP304 / VODAP405 / VODAPE17 / VODAPD18
2.22.161.6 - TWRP Thanks to ckpv5
2.22.161.6 - TWRP Thanks to DarkFussel92
1.54.161.5 - TWRP Thanks to Roach2010
1.54.161.10 - TWRP Thanks to uronfire
1.54.161.10 - TWRP Thanks to ckpv5
1.12.161.17 - TWRP Thanks to Coops1977
CID O2__001 / O2___102
1.54.206.5 - TWRP Thanks to Sensor1
1.12.206.17 - TWRP Thanks to shorty1483
1.12.206.17 - TWRP Thanks to Sensor1
CID HTC__001 / HTC__E11 / HTC__102 / HTC__203 / HTC__405 / HTC__Y13 / HTC__304 / HTC__A07 / HTC__002 / HTC__016 / HTC__032 / HTC__J15 / HTC__M27 / HTC__A48 / HTC__K18
3.28.401.9 - TWRP Thanks to sardor
3.28.401.7 - TWRP Thanks to SoLdieR9312
3.28.401.6 - TWRP (yes i know it's rooted, no influence on ota) Thanks to ahsan64
3.28.401.6 - TWRP Thanks to 10rdan
2.22.401.5 - TWRP Thanks to ckpv5
2.22.401.5 - CWM Philz touch Thanks to MATRIKS
2.22.401.4 - TWRP Thanks to ckpv5
1.54.401.10 - CWM Philz touch Thanks to spikeydoo2006
1.54.401.10 - TWRP Thanks to ckpv5
1.54.401.5 - TWRP Thanks to Fisha21
1.54.401.5 - CWM Philz touch Thanks to krihoum
1.54.401.5 - Philz 6.4.1.6-M8 Thanks to zimilaci
1.54.401.5 - Philz touch Thanks to PopAhmad
1.54.401.5 - Philz touch Thanks to Ambious
1.54.401.5 - TWRP Thanks to jontyjon
1.54.401.5 - CWM Philz touch Thanks to Provencebiker
1.12.401.17 - CWM Philz touch Thanks to RobbinM
1.12.401.17 - TWRP Thanks to MaximN97
CID CWS__001
1.58.502.1 - TWRP Thanks to MLIGN
1.12.502.18 - TWRP 2.6.3.3 Thanks to Wonders_Never_Cease
CID T-MOB010
2.22.531.5 - TWRP Thanks to technogeek82
1.12.531.19 - TWRP Thanks to Garmig
CID HTC__332
2.25.599.1 - TWRP Thanks to ckpv5
1.57.599.1 - TWRP Thanks to ckpv5
CID ROGER001
3.34.631.4 - TWRP Thanks to exocetdj
2.23.631.2 - TWRP Thanks to ckpv5
1.12.631.17 - TWRP Thanks to brar.arsh
1.12.631.17 - CWM Philz touch Thanks to CWolfCW (unlocked bootloader only)
1.12.631.17 - CWM Philz touch Thanks to CWolfCW (flashlight, calculator already restored)
CID TELUS001
3.34.661.4 - TWRP Thanks to shaboobla use this KEY if needed : 0gcKEs5WfKxJgFbb95nupF__MQDmQKwaj2bT8E03msw
CID BM___001
1.55.666.4 - TWRP Thanks to Canadianreaper
CID HTC_044 / HTC_059
3.32.707.9 - TWRP Thanks to Hazem99922
3.32.707.9 - TWRP Thanks to pinbacninh_city
3.32.707.9 - TWRP Thanks to ckpv5
2.22.707.4 - TWRP Thanks to ckpv5
2.22.707.3 - TWRP Thanks to ckpv5
2.22.707.3 - TWRP Thanks to huyhoangytn
1.54.707.7 - CWM Philz touch Thanks to ffforce
1.54.707.7 - TWRP Thanks to konanda
CID HTC__622
3.32.708.4 - TWRP 2.8.1.0 Thanks to bigd4ve
2.11.708.2 - TWRP 2.7.1.0 Thanks to anddiiss
2.11.708.2 - TWRP Thanks to ckpv5
1.60.708.2 - TWRP 2.8.1.0 Thanks to bigd4ve
1.60.708.2 - TWRP 2.7.0.2 Thanks to BenPope
CID HTC__621
2.22.709.4 - TWRP topjohnwu
2.22.709.3 - TWRP Thanks to ckpv5
1.54.709.12 - TWRP Thanks to ckpv5
CID HTC_039
2.23.710.1 - TWRP Thanks to ross152
1.54.710.8 - TWRP Thanks to Clay21
CID VODAP021
1.12.710.17 - CWM Philz touch Thanks to rolphez
CID HTC__038
3.35.720.1 - TWRP Thanks to n1234d
2.10.720.1 - TWRP Thanks to n1234d
1.56.720.6 - TWRP Thanks to NikGarg
CID H3G___001
2.22.771.5 - TWRP Thanks to ckpv5
154.771.9 - TWRP Thanks to ckpv5
1.54.771.5 - Philz touch Thanks to E
1.12.771.17 - TWRP Thanks to Timnyce19
CID TELST001
1.12.841.17 - TWRP Thanks to wineds
CID TIM__401
2.22.901.5 - TWRP Thanks to ckpv5
1.54.901.10 - TWRP Thanks to ckpv5
CID OPTUS001
1.22.980.1 - Philz touch Thanks to G0B1IN5486
CID BS_US001 / BS_US002
3.28.1540.5 - TWRP Thanks to Thapinn
2.22.1540.4 - TWRP Thanks to ckpv5
2.22.1540.3 - TWRP Thanks to ckpv5
2.22.1540.3 - Philz touch Thanks to komugi
1.54.1540.9 - TWRP Thanks to jmjm003
1.12.1540.17 - TWRP Thanks to Ruddy0580
1.12.1540.17 - CWM Philz touch Thanks to daorderdillon
GPE
KOT49H.H16 - 1.16.1700.16 - CWM Philz touch Thanks to graffixnyc & chrisch1974
DUAL SIM BACKUPS
1.45.401.12 - TWRP Thanks to kakyyabata[/HIDE]
[HIDE]
1.12.401.17
1.12.502.18
1.12.531.19
1.12.631.17
1.12.710.17
1.12.771.17
1.12.1540.17
1.16.1700.16
1.22.980.1
1.54.61.5
1.54.73.5
1.54.161.5
1.54.161.10
1.54.206.5
1.54.401.5
1.54.401.10
1.54.651.8
1.54.707.5
1.54.707.7
1.54.709.12
1.54.710.8
1.56.720.6
1.54.771.5
1.54.771.9
1.54.1540.9
1.55.666.4
1.57.112.2
1.58.502.1
1.60.708.2
1.70.73.2
2.10.720.1
2.11.708.1
2.11.708.2
2.22.401.4
2.22.401.5
2.22.161.6
2.22.163.6
2.22.707.3
2.22.707.4
2.22.709.3
2.22.709.4
2.22.771.5
2.22.901.5
2.22.1540.3
2.22.1540.4
2.23.112.x
2.23.631.2
2.23.710.1
2.25.599.1
2.26.61.1
2.26.73.2
3.28.401.6
3.28.401.7
3.28.401.9
3.28.709.5
3.29.112.5
3.29.161.5
3.32.206.2
3.32.531.2
3.32.707.9
3.32.708.4
3.32.771.3
3.33.61.9
3.34.661.4
3.34.666.4
DUAL SIM 1.45.401.12[/HIDE]
I uploaded the recovery with it's original name at the end so when it says "Stock recovery 1.54.401.5 recovery.img" it's original name is recovery.img
This one can be flashed with the following command :
fastboot flash recovery recovery.img
when it's named "Stock recovery 1.54.401.5 recovery.emmc.win" it's original name is recovery.emmc.win
this one can be flashed with the following command :
fastboot flash recovery recovery.emmc.win
For sprint devices go here
Stock backups and ota's
For some german back-up's go here
German stock backups
Some more very helpfull threads Here
[GUIDE] Everything Explained
[INDEX][REPO][AIO] HTC ONE (M8) - ROMs | Kernels | MODs | Recoveries
VomerGuides [M8]: Bootldr Unlock, S-OFF, SuperCID, Firmware Upgrade & Custom Recovery
[GUIDE] Return your M8 to 100% Stock
HTC One firmware collection for different CID/MID
The Following 2 Users Say Thank You to Braycel For This Useful Post:
Old 03-25-2015, 08:39   #2 (permalink)
Member: 2368445
I have a htc one m8 with cid - htc__332 already rooted and I wanted to reinstall stick version for lollipop ��
2.25.599.1
Stock link not working pls reupload
Thank. You
Old 11-09-2015, 09:23   #3 (permalink)
Member: 2086461
Thanks Meter: 7
i need htc m8et firmware
Old 11-26-2015, 11:16   #4 (permalink)
cooloxf's Avatar
Member: 120893
Thanks Meter: 69
i need this rom
RUU_M8_UL_K44_SENSE60_SECURITY_BrightstarUS_WWE_1. 54.1540.10_Radio_1.16.21331931.LA11G_20.31A.4145.0 2L_release_372510_signed_2.exe
Old 11-26-2015, 11:16   #5 (permalink)
cooloxf's Avatar
Member: 120893
Thanks Meter: 69
i need this rom
Old 12-08-2015, 23:29   #6 (permalink)
Member: 2498176
My htc one m8 is S -On, want to go back to the original and receive OTA updates. I need Nandroid Backup, below my phone data :
CID : CWS__001 , Model: OP6B120
these links are not working.
Thnks.
Old 01-26-2016, 14:43   #7 (permalink)
Member: 2521886
Sonork: 100.1671664
please can you update the links, i'm in need for stock recovery of htc one m8 cid orang001, thank you very much.
Old 02-07-2016, 17:57   #8 (permalink)
Member: 2528236
You can pull the stock recovery from the OTA.
Move the OTA over to your PC and open it with 7zip. Find the firmware zip and unzip it. The stock recovery img is in there.
Flash that in fastboot, and then you can install the OTA.
Old 02-17-2016, 03:50   #9 (permalink)
Member: 355613
Sonork: 100.1674359
Thanks Meter: 170
neeed backup for m8_ul hboot3.19 os3.12.401.4 cid111111
Old 03-19-2016, 15:41   #10 (permalink)
Member: 2030130
When I unlock my bootloader it boot to recovery and refresh it self again it also have software status official on it
Pls can any help me with the stock ROM because it is also s-on
Old 09-28-2016, 01:21   #11 (permalink)
Member: 2630079
This Stock link not working please reupload:
Version-Main: 1.58.502.1
cidnum: CWS__001
Thank You
Old 04-06-2017, 19:46   #12 (permalink)
Member: 2560889
Thanks Meter: 106
hello, this is my phone info which recovery is compatible with
C:\Users\sematech\Desktop>fastboot devices
HT4B3WM01024 fastboot
C:\Users\sematech\Desktop>fastboot getvar version-main
version-main: 5.07.1700.6
finished. total time: 0.001s
C:\Users\sematech\Desktop>fastboot oem readcid
(bootloader) cid: 11111111
OKAY [ 0.002s]
finished. total time: 0.002s
C:\Users\sematech\Desktop>fastboot getvar all
(bootloader) version: 0.5
(bootloader) version-bootloader: 3.19.0.0000
(bootloader) version-baseband: 1.23.213311491.A13G
(bootloader) version-cpld: None
(bootloader) version-microp: None
(bootloader) version-main: 5.07.1700.6
(bootloader) version-misc: PVT SHIP S-ON
(bootloader) serialno: HT4B3WM01024
(bootloader) imei: 352993055037089
(bootloader) imei2: Not Support
(bootloader) meid: 00000000000000
(bootloader) product: m8_ul
(bootloader) platform: hTCBmsm8974
(bootloader) modelid: 0P6B11000
(bootloader) cidnum: 11111111
(bootloader) battery-status: good
(bootloader) battery-voltage: 0mV
(bootloader) partition-layout: Generic
(bootloader) security: on
(bootloader) build-mode: SHIP
(bootloader) boot-mode: FASTBOOT
(bootloader) commitno-bootloader: 11459804
(bootloader) hbootpreupdate: 11
(bootloader) gencheckpt: 0
all: Done!
finished. total time: 0.072s
Old 02-05-2018, 13:33   #13 (permalink)
Member: 2304667
cid: htc_044 model: OP6B110
Old 02-05-2018, 18:29   #14 (permalink)
Member: 2725921
Sonork: www.sonork.com
I need Fix htc one m8 baseband unknown
Old 02-23-2018, 11:48   #15 (permalink)
Member: 1826869
Thanks Meter: 10
Reading information...
Using Fastboot mode...
Reading common information
(bootloader) version-baseband: 1.24.21331147A1.09G
(bootloader) version-main: 4.18.720.8
(bootloader) serialno: HT46CWM00528
(bootloader) imei: 352442060269402
(bootloader) modelid: 0P6B65000
(bootloader) cidnum: HTC__038
(bootloader) commitno-bootloader: 3aa067db
all: Done
Page generated in 0.30768 seconds with 8 queries
