HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
01-21-2018, 15:13 | #1 (permalink) |
Insane Poster Join Date: Nov 2016
Member: 2647181 Status: Offline Thanks Meter: 9 | HTC M8 i need this firmware urgent please help me Model Id: 0P6B65000 Custom Id: HTC__038 (HTC-India) Serial number: HT46HWM01158 Product: m8_ul IMEI: 352442060356100 Platform: hTCBmsm8974 Bootloader ver: 3.19.0.0000 Baseband ver: 1.29.214500021.12G Cpld verersion: None Microp version: None Main version: 6.15.720.2 Battery Status: good Battery Volt: 0mV PartitionLayout: Generic Commitno bl: 205bdca3 Hbootpreupdate: 11 |
01-22-2018, 07:48 | #3 (permalink) | |
Moderator Join Date: Oct 2011 Location: U.A.E
Member: 1676524 Status: Offline Sonork: 100.1608473 Thanks Meter: 2,713 | Quote:
__________________ __________________ Rules are for the obedience of fools and the guidance of wise men. Best Regards, Shamim | |
The Following User Says Thank You to ...:::SHAMIM:::... For This Useful Post: |
01-22-2018, 12:12 | #4 (permalink) | |
Member: 2647181 Status: Offline Thanks Meter: 9 | Quote: Check battery status ... ok Erasing cache ... ok Erasing userdata ... ok Checking bootloader ... support unlock Checking bootloader lock status ... Locked Device security status is S-ON This rom don't have signature data. S-ON device will check ROM signature Sending data ... Flash failed, error:signature verify fail | |
01-23-2018, 12:34 | #5 (permalink) |
Member: 2647181 Status: Offline Thanks Meter: 9 | sir can you please give me ruu file .exe please Security status: S-ON Model Id: 0P6B65000 Custom Id: HTC__038 (HTC-India) Serial number: HT46HWM01158 Product: m8_ul IMEI: 352442060356100 Platform: hTCBmsm8974 Bootloader ver: 3.19.0.0000 Baseband ver: 1.29.214500021.12G Cpld verersion: None Microp version: None Main version: 6.15.720.2 Battery Status: good Battery Volt: 0mV PartitionLayout: Generic Commitno bl: 205bdca3 Hbootpreupdate: 11 |
01-26-2018, 14:52 | #7 (permalink) |
Member: 1676524 Status: Offline Sonork: 100.1608473 Thanks Meter: 2,713 | Flash Above Firmware by Sd Card via Bootloader Mode.
01-28-2018, 14:44 | #11 (permalink) |
