HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
08-14-2014, 17:15 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Htc Mini (m4) Hang logo unbrick nd install 4.4.2 solution No need S-off No Need RUU HTC One Mini with out S-OFF and no need RUU Stock ROM Note:if yu install Fastboot adb Driver below gven yu can run command from any where by pressing shift+ right click select open commad window here(win7 only) Procedure: HTC sync Driver must be installed Fastboot adb DriverrDownload nd install yu can run command from any where win7 only Unlock Bootloader Recover : TWRP 2.7.0.5 Download Rom file nandroid backup flash via Twrp recovery http://www.mediafire.com/download/4k...roid_4.4.2.rar ROM Download 1Download 2 USB Flash drive USB OTG * 1st unlock yur boot loader nd install TWRP 2.7.0.5 Tutorialhere * Download ROM and Copy to Flash Drive * Push your device to recovery mode by Hold " power + Volume Down * Go to recovery mode in your device , then plug in USB Flash drive with USB OTC and connect to your device * Select Advance >> Mount USB OTG , select Install located to ROM in Flash drive * Then just flash ROM m4kk_4.4.2_3.10.401.4_root-odex.zip * Wait for moment until Successfully Done and reboot your device !!!!!! Source:XDA Last edited by jamesjerss; 08-14-2014 at 23:22. |
The Following 2 Users Say Thank You to jamesjerss For This Useful Post: |
06-18-2015, 13:54 | #2 (permalink) |
No Life Poster Join Date: Mar 2003 Location: INDIA Age: 57
Member: 25662 Status: Offline Thanks Meter: 190 | jamesjerss sir i need ruu for mini m4_ul handset is in fastboot mode. info as below. INFOversion: 0.5 INFOversion-bootloader: 2.22.0000 INFOversion-baseband: N/A INFOversion-cpld: None INFOversion-microp: None INFOversion-main: 4.09.708.6 INFOversion-misc: PVT SHIP S-ON INFOserialno: HT38SWA04979 INFOimei: 358********** INFOmeid: INFOproduct: m4_ul INFOplatform: HBOOT-8930 INFOmodelid: PO5821000 INFOcidnum: HTC__622 INFObattery-status: good INFObattery-voltage: 3970mV INFOpartition-layout: Generic INFOsecurity: on INFObuild-mode: SHIP INFOboot-mode: FASTBOOT INFOcommitno-bootloader: dirty-0e1af350 INFOhbootpreupdate: 11 INFOgencheckpt: 0 all: Done! pls help. i had search for this file but no free no link. OTA_M4_UL_K44_SENSE55_MR_hTC_Asia_HK_3.10.708.4-2.12.708.3_release_351634.zip |
The Following User Says Thank You to Munir For This Useful Post: |
06-18-2015, 21:36 | #3 (permalink) | |
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Quote:
write recovery Write rom via recovery | |
The Following User Says Thank You to jamesjerss For This Useful Post: |
06-19-2015, 06:35 | #4 (permalink) |
Member: 25662 Status: Offline Thanks Meter: 190 | tahnx for reply. my handset is not getting complete on only show fastboot mode. Its possible to unlock bootloader in this state. And from my pc your given this link is not openning http://https://mega.co.nz/#!RVcEVQgL...Wds8e4uax8X_YY pls will you uploads its to 4shared.com |
06-19-2015, 08:06 | #5 (permalink) | |
Product Manager Join Date: Dec 2009 Location: CEO.of.ROMDevelopers Age: 32
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,979 | Quote:
I have check the link, Is working.. also you can download from from the link - https://dev.androidfilehost.com/?fid=95747613655045716 Br AzimBahar/ParvezAhmed | |
07-22-2015, 22:54 | #8 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Colombia Age: 42
Member: 452143 Status: Offline Thanks Meter: 198 | Please Master how S-Off in HTC one mini with Android 4.4.2.....?? ***TAMPERED*** ***UNLOCKED*** M4_UL PVT SHIP S-ON RH HBOOT-2.22.0000 RADIO-1.24.40e.00.26 OpenDSP-v19.2.0268.0927 os-3.10.599.3 eMMC-boot 1024MB Jan 29 2014.20:09:22.0 Best Regards karurosu316 |
07-23-2015, 16:55 | #9 (permalink) | |
Unlock Bootloader Flash CUstom Recovery Flash this rom Flash this kernel Use rumrunner to s-off yur device here | |
07-23-2015, 20:20 | #11 (permalink) | |
Flash twrp recovery from my post Copy rom nd kernel to yur mob Boot into recovery mode 1st backup yur current rom via recovery full wipe system,data,cache,delvik cache Flash rom den kernel Reboot Aftr boot s-off yur device Sent from my Moto G 2014 using Tapatalk | |
07-23-2015, 23:25 | #12 (permalink) | |
Member: 452143 Status: Offline Thanks Meter: 198 | Quote:
Not work Master, reboot only Bootloader mode.... and bootloader mode... | |
07-25-2015, 04:11 | #14 (permalink) |
Member: 452143 Status: Offline Thanks Meter: 198 | Master how degrade Hboot 2.22 0000 to Hboot 2.21 0000, I need S-off...?? I download five Stock roms and not work, only error... Custom Firmware only Reboot in Bootloader... Regards karurosu316 |
