Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > HTC > HTC Android based
HTC Android based General HTC Android phones discussion, firmwares, solution, root, help
Old 07-06-2017, 22:26   #16 (permalink)
Yasir Ali's Avatar
Member: 270869
Sonork: 100.1600061
Thanks Meter: 328
c:\adbfastboot>fastboot getvar all
< waiting for device >
INFOkernel: lk
INFOproduct: htc_v36bml_dugl
INFOversion: 1.0
INFOimei: 357292076609744
INFOversion-main: 1.17.401.1
INFOboot-mode: download
INFOversion-baseband: READ version-baseband ERROR
INFOversion-bootloader: 1.01.0000
INFOmid: 2PVG20000
INFOcid: HTC__J15
all:
finished. total time: 0.005s
The Following User Says Thank You to Yasir Ali For This Useful Post:
Old 07-07-2017, 13:37   #17 (permalink)
IMIM@HACK99's Avatar
Member: 2688744
Thanks Meter: 149
INFOkernel: lk
INFOversion: 1.0
INFOmid: 2PVG20000
INFOcid: HTC__J15
all:
i sersh for you but not any free link if i find this version i well upluad it here .
The Following User Says Thank You to [email protected] For This Useful Post:
Old 07-07-2017, 18:02   #18 (permalink)
Yasir Ali's Avatar
Member: 270869
Sonork: 100.1600061
Thanks Meter: 328
sir how to flash with this file ????
Old 07-07-2017, 18:05   #19 (permalink)
Moderator
...:::SHAMIM:::...'s Avatar
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,164
[Noob Guide] Htc zip format file flashing & Via SdCard flashing Guide!!!
__________________
__________________
Rules are for the obedience of fools and the guidance of wise men.
Best Regards,
Shamim
The Following 3 Users Say Thank You to ...:::SHAMIM:::... For This Useful Post:
Old 07-07-2017, 20:15   #20 (permalink)
Yasir Ali's Avatar
Member: 270869
Sonork: 100.1600061
Thanks Meter: 328
C:\adbfastboot>fastboot flash zip 2PVGIMG.zip
target reported max download size of 800000000 bytes
Invalid sparse file format at header magi
sending sparse 'zip' (9769 KB)...
OKAY [ 1.387s]
writing 'zip'...
(bootloader) HOSD CL#822405
FAILED (remote: 9: SD_SECURITY_FAIL zip from usb command in download mode)
finished. total time: 2.401s
OKAY [ 1.398s]
writing 'zip'...
finished. total time: 2.412s
C:\adbfastboot>
error flashing
Old 07-07-2017, 21:41   #21 (permalink)
Member: 2733164
help
I am looking for firmware htc hd2, i want help
thanks
The Following User Says Thank You to tidorepair For This Useful Post:
Old 07-08-2017, 07:53   #22 (permalink)
Moderator
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,164
OKAY [ 1.387s]
writing 'zip'...
OKAY [ 1.398s]
writing 'zip'...
C:\adbfastboot>
error flashing
Flash phone to via Sd card Method!
__________________
__________________
Best Regards,
Shamim
The Following User Says Thank You to ...:::SHAMIM:::... For This Useful Post:
Old 07-08-2017, 07:55   #23 (permalink)
Moderator
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,164
thanks
Use Search Button after that you will get your solution.
__________________
__________________
Best Regards,
Shamim
Old 07-08-2017, 08:46   #24 (permalink)
Member: 2590250
please help my phone is htc desire 820n I cannot flash anything on it here is my getvar
(bootloader) version: 0.5
(bootloader) version-bootloader: 3.19.0.0000
(bootloader) version-baseband: 01.01.010_U10305041_08.01.50512
(bootloader) version-cpld: None
(bootloader) version-microp: None
(bootloader) version-main:
(bootloader) version-misc: PVT SHIP S-ON
(bootloader) serialno: HT56FYC02339
(bootloader) imei: 3xxxxxxxxxxxx01
(bootloader) imei2: Not Support
(bootloader) meid: 00000000000000
(bootloader) product: a51_ul
(bootloader) platform: hTCBmsm8939
(bootloader) modelid: 0PFJ40000
(bootloader) cidnum: HTC__M27
(bootloader) battery-status: good
(bootloader) battery-voltage: 0mV
(bootloader) partition-layout: Generic
(bootloader) security: on
(bootloader) build-mode: SHIP
(bootloader) boot-mode: RUU
(bootloader) commitno-bootloader: 1be89947
(bootloader) hbootpreupdate: 11
(bootloader) gencheckpt: 0
(bootloader) mfg-name: 0001
all: Done!
finished. total time: 0.445s
The Following User Says Thank You to den3d For This Useful Post:
Old 07-08-2017, 08:53   #25 (permalink)
Moderator
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,164
all: Done!
Create own your new thread and post it getvar info log with main version!
__________________
__________________
Best Regards,
Shamim
Old 07-08-2017, 09:26   #26 (permalink)
Yasir Ali's Avatar
Member: 270869
Sonork: 100.1600061
Thanks Meter: 328
now my set is ok flash with sd card
1= first rename file 2PVGIMG_V36BML_DUGL_L51_DESIRE_SENSE70_HTC_Europe_ 1.17.401.2_Radio_0.1524V28P45.0504.0422.zip
with name 2PVGIMG
2= put the file in memory card
3= then put in card phone and pres VOL+VOL-and power button go to download mode after press vol up file instaltion
start then finsh press power key
The Following 2 Users Say Thank You to Yasir Ali For This Useful Post:
Old 07-09-2017, 07:18   #27 (permalink)
mbiborna's Avatar
Member: 770503
Thanks Meter: 1,059
If Someone have Full Dump bin For MT6582 Htc_OPA2210_310 Duel sim Please Share.
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
DA Select done, will use SecMode DA
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x87
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A4834473164040503A2F339B16B
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164040503A2F339B16B
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID    : 0x0A09E13555FD7152B88F0E56135E7B53
INT RAM    : 0x00020000
EXT RAM    : 0x40000000 [1 GiB]
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
The Following User Says Thank You to mbiborna For This Useful Post:
Old 07-09-2017, 09:27   #28 (permalink)
Moderator
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,164
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Did you tried Full Backup of Firmware?
What Happened to your Phone? Why You want Dump?
__________________
__________________
Best Regards,
Shamim
Old 07-09-2017, 14:38   #29 (permalink)
mbiborna's Avatar
Member: 770503
Thanks Meter: 1,059
phone rechived with logo only ( Dl image failed ) By mistake i made erase phone with some flasher tool Now phone goes dead.
i try flash all fw which is posted in 1st post of this thread with flasher tool SP_Flash_Tool_v5.1348.01_SEC but still dead
If have please share running phone Full dump bin fw To revive my phone
thanks
Old 07-09-2017, 15:37   #30 (permalink)
mbiborna's Avatar
Member: 770503
Thanks Meter: 1,059
I don't made backup dump before erase
Page generated in 0.42286 seconds with 7 queries
