HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
05-25-2015, 17:39 | #1 (permalink) |
Freak Poster Join Date: Jan 2014
Member: 2112242 Status: Offline Sonork: tali1000 Thanks Meter: 22 | htc one m7 imei null help needed how do you do i hope every one are happy i have htc one m7 no imei unlocked s-on i tried with lolipop csutom and with stock rom .zip but not slove Microsoft Windows [Version 6.1.7601] Copyright (c) 2009 Microsoft Corporation. All rights reserved. C:\Users\asas>cd c:\Android c:\android>fastboot getvar cid cid: HTC__J15 finished. total time: 0.001s c:\android>fastboot getvar mid mid: PN0710000 finished. total time: 0.001s c:\android>fastboot getvar all (bootloader) version: 0.5 (bootloader) version-bootloader: 1.57.0000 (bootloader) version-baseband: 4T.29.3218.08 (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: (bootloader) version-misc: PVT SHIP S-ON (bootloader) serialno: FA364W922377 (bootloader) imei: 357864052141833 (bootloader) meid: 00000000000000 (bootloader) product: m7_ul (bootloader) platform: HBOOT-8064 (bootloader) modelid: PN0710000 (bootloader) cidnum: HTC__J15 (bootloader) battery-status: good (bootloader) battery-voltage: 3735mV (bootloader) partition-layout: Generic (bootloader) security: on (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: dirty-6d8a0b9b (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 all: Done! finished. total time: 0.044s c:\android> |
05-25-2015, 18:24 | #2 (permalink) |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Download latest m7 ul Europe lollipop rom nd flash http://forum.gsmhosting.com/vbb/f485...p-ruu-1863513/ if same aftr flash should b hardware |
The Following User Says Thank You to jamesjerss For This Useful Post: |
05-25-2015, 18:36 | #5 (permalink) |
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | |
05-25-2015, 20:56 | #9 (permalink) |
Member: 2112242 Status: Offline Sonork: tali1000 Thanks Meter: 22 | C:\android>cd c:\Android C:\android>adb reboot-bootloader * daemon not running. starting it now on port 5037 * * daemon started successfully * C:\android>fastboot oem rebootRUU ... (bootloader) Start Verify: 3 OKAY [ 0.033s] finished. total time: 0.033s C:\android>fastboot flash zip ruu.zip target reported max download size of 1514139648 bytes Invalid sparse file format at header magi error: write_sparse_skip_chunk: don't care size 162706427 is not a multiple of t he block size 4096 sending sparse 'zip' (1478648 KB)... error: write_sparse_skip_chunk: don't care size 162706427 is not a multiple of t he block size 4096 error: write_sparse_skip_chunk: don't care size 162706427 is not a multiple of t he block size 4096 OKAY [ 64.161s] writing 'zip'... (bootloader) zip header checking... FAILED (remote: 32 header error) finished. total time: 64.336s C:\android>fastboot flash zip ruu.zip target reported max download size of 1514139648 bytes Invalid sparse file format at header magi error: write_sparse_skip_chunk: don't care size 162706427 is not a multiple of t he block size 4096 sending sparse 'zip' (1478648 KB)... error: write_sparse_skip_chunk: don't care size 162706427 is not a multiple of t he block size 4096 error: write_sparse_skip_chunk: don't care size 162706427 is not a multiple of t he block size 4096 OKAY [ 63.890s] writing 'zip'... (bootloader) zip header checking... FAILED (remote: 32 header error) finished. total time: 64.067s C:\android>fastboot reboot rebooting... finished. total time: 0.034s C:\android>adb reboot-bootloader * daemon not running. starting it now on port 5037 * * daemon started successfully * C:\android>fastboot oem lock ... (bootloader) Lock successfully... (bootloader) mipi display off (bootloader) mipi_dsi_cmds_tx_ext (bootloader) pm8921_vreg_disable function, vreg_id = 38 (bootloader) pm8921_vreg_disable function, vreg_id = 1 (bootloader) TZ_HTC_SVC_DISABLE ret = 534642044 (0x1FDDFD7C) (bootloader) Use PSHOLD to reset device. (bootloader) Use PSHOLD to reset device.4642044 (0x1FDDFD7C)♦€·**╨`{♣€·** FAILED (unknown status code) finished. total time: 1.134s C:\android>fastboot oem rebootRUU ... (bootloader) Start Verify: 3 OKAY [ 0.036s] finished. total time: 0.037s C:\android>fastboot flash zip ruu.zip target reported max download size of 1514139648 bytes Invalid sparse file format at header magi error: write_sparse_skip_chunk: don't care size 162706427 is not a multiple of t he block size 4096 sending sparse 'zip' (1478648 KB)... error: write_sparse_skip_chunk: don't care size 162706427 is not a multiple of t he block size 4096 error: write_sparse_skip_chunk: don't care size 162706427 is not a multiple of t he block size 4096 OKAY [ 63.652s] writing 'zip'... (bootloader) signature checking... FAILED (remote: 12 signature verify fail) finished. total time: 227.186s C:\android>fastboot flash zip ruu.zip target reported max download size of 1514139648 bytes Invalid sparse file format at header magi error: write_sparse_skip_chunk: don't care size 162706427 is not a multiple of t he block size 4096 sending sparse 'zip' (1478648 KB)... error: write_sparse_skip_chunk: don't care size 162706427 is not a multiple of t he block size 4096 error: write_sparse_skip_chunk: don't care size 162706427 is not a multiple of t he block size 4096 OKAY [ 63.683s] writing 'zip'... (bootloader) signature checking... FAILED (remote: 12 signature verify fail) finished. total time: 227.233s C:\android>fastboot reboot rebooting... finished. total time: 0.034s C:\android> |
05-25-2015, 21:59 | #10 (permalink) |
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Download this htc fastboot exe here try using this fastboot driver before flash stock lock yur bootloder if already unlocked Sent from my XT1068 using Tapatalk |
01-25-2016, 12:38 | #13 (permalink) |
Freak Poster Join Date: Mar 2004 Location: Egypt Age: 40
Member: 58081 Status: Offline Thanks Meter: 10 | HTC M7C IMEI NULL problem M7C_DUG imei is NULL i updated it to android 5 but still same problem NULL C:\htcfastboot>fastboot getvar all (bootloader) version: 0.5 (bootloader) version-bootloader: 2.49.0000 (bootloader) version-baseband: U3.19.3509.04 (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 7.17.402.5 (bootloader) version-misc: PVT SHIP S-ON (bootloader) serialno: HT494W900199 (bootloader) imei: 351523060887094 (bootloader) meid: 00000000000000 (bootloader) product: m7cdug (bootloader) platform: HBOOT-8064 (bootloader) modelid: PN0771000 (bootloader) cidnum: HTC__J15 (bootloader) battery-status: good (bootloader) battery-voltage: 4257mV (bootloader) partition-layout: Generic (bootloader) security: on (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: dirty-d0e3b226 (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 all: Done! |
