Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > HTC > HTC Android based
HTC Android based General HTC Android phones discussion, firmwares, solution, root, help
Old 09-29-2017, 14:13   #121 (permalink)
Moderator
...:::SHAMIM:::...'s Avatar
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,713
Originally Posted by Kuama View Post
But how do i flash a .exe do i not need a zip?
No Need Anything.
Just Relock Bootloader and Run exe of Firmware.
__________________
__________________
Rules are for the obedience of fools and the guidance of wise men.
Best Regards,
Shamim
Old 10-15-2017, 07:06   #122 (permalink)
Member: 2151844
Sir I Need This File.
0P6BIMG_M8_UL_M60_SENSE70_MR_Rogers_WWE_6.13.631.7 _Radio_1.29.214500021.11G_20.76.4196t.01_F_release _463851_signed_2_4.zip
Link Is Dead...
Old 10-15-2017, 07:29   #123 (permalink)
Moderator
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,713
Link Is Dead...
OTA_M8_UL_M60_SENSE70_MR_Rogers_WWE_6.13.631.7-4.20.631.3_release_463918.zip
__________________
__________________
Best Regards,
Shamim
The Following User Says Thank You to ...:::SHAMIM:::... For This Useful Post:
Old 10-15-2017, 10:50   #124 (permalink)
Member: 2151844
Sir Can U Explain Please How Can I Write OTA File My Phone Is Fastboot State
Old 10-15-2017, 11:10   #125 (permalink)
Member: 2151844
Thanks Sir For Help I M Done
Old 10-16-2017, 21:22   #126 (permalink)
Member: 2768759
bricked phone
Hi there!
I really need your help. So my htc one m8 had an issue with playing audio files (not only mp3 files but also basic ringtones etc. It didn't play anything audio related) and video files via the YouTube app. It also failed to recognize the carrier and wouldn't install system updates. So I tried to fix all that by flashing a Custom ROM (the Marshmallow Viper version)--problem is my android version was 4.4.4. so OF COURSE installing a marshmallow ROM only made everything worse. I couldn't even turn on wifi anymore.
Once I realized that, I tried to undo everything by wiping the device with twrp and ended up wiping not only all my data but also the OS. So now I have a device with no OS, which means I'm stuck in bootloader mode and there is my problem. Since I can't boot into my system I can't check my model number which I need to determine the firmware I have to install in oder to fix everything. I have s-on and bootloader relocked so I can't flash just any firmware. And I can't get into recovery anymore.
This is what I got from adb running the phoneinfo command:
(bootloader) version: 0.5
(bootloader) version-bootloader: 3.18.0.0000
(bootloader) version-baseband: 1.19.21331147A1.09G
(bootloader) version-cpld: None
(bootloader) version-microp: None
(bootloader) version-main:
(bootloader) version-misc: PVT SHIP S-ON
(bootloader) serialno: HT46KWM11338
(bootloader) imei: 357871053407568
(bootloader) imei2: Not Support
(bootloader) meid: 00000000000000
(bootloader) product: m8_ul
(bootloader) platform: hTCBmsm8974
(bootloader) modelid: 0P6B10000
(bootloader) cidnum: HTC__102
(bootloader) battery-status: good
(bootloader) battery-voltage: 0mV
(bootloader) partition-layout: Generic
(bootloader) security: on
(bootloader) build-mode: SHIP
(bootloader) boot-mode: FASTBOOT
(bootloader) commitno-bootloader: 5e4b24e4
(bootloader) hbootpreupdate: 11
(bootloader) gencheckpt: 0
all: Done!
finished. total time: 0.013s
So... what do I do now? Do I need to give up on my phone? Help would be much appreciated.
Old 10-17-2017, 07:07   #127 (permalink)
Moderator
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,713
@Ricktastic
If Phone is Bootloader Locked Then Try This Ruu:-
0P6BIMG_M8_UL_M60_SENSE70_MR_HTC_Europe_6.12.401.4 _Radio_1.29.214500021.12G_20.72.4196t.01_release_4 64360_signed.zip
__________________
__________________
Best Regards,
Shamim
Old 10-17-2017, 21:55   #128 (permalink)
Member: 2768759
Thanks for the quick reply!
Unfortunately, I can't flash it. Adb says it can't load the zip file
Old 10-18-2017, 06:17   #129 (permalink)
Moderator
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,713
Try to Flash Ruu via Sd Card Method!
Check Sticky Thread, Tutorial are Available There!
__________________
__________________
Best Regards,
Shamim
Old 10-18-2017, 15:13   #130 (permalink)
Member: 2768759
I tried that too. But I can't move the file to the sd card, neither with adb nor via usb cable using another phone. I think the file is the problem. I can't unzip it or even open it to look at the content. It says it's not recognized as 'achive file'
Old 10-18-2017, 17:49   #131 (permalink)
Moderator
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,713
Leave The File as Like Zip!
Don't Try to Extract it, They are Encrypted!
From PC Send File to Memory Card via Reader.
Put The Phone in Bootloader Mode and Press Power for Update.
__________________
__________________
Best Regards,
Shamim
Old 10-19-2017, 09:46   #132 (permalink)
Member: 2769627
(bootloader) version-bootloader: 3.19.0.0000
(bootloader) version-baseband: 1.25.214500021.06G
(bootloader) version-main: 4.16.401.10
(bootloader) version-misc: PVT SHIP S-OFF
(bootloader) modelid: 0P6B13000
(bootloader) cidnum: 11111111
(bootloader) security: off
(bootloader) commitno-bootloader: 3aa067db
all: Done!
finished. total time: 0.090s
Need firmware, please.
Thank you.
Old 10-19-2017, 15:59   #133 (permalink)
Moderator
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,713
all: Done!
Thank you.
RUU_M8_UL_L50_SENSE60_MR_HTC_Europe_4.16.401.10_Ra dio_1.25.214500021.06G_20.68.4196t.01_F_release_41 7003_signed.exe
__________________
__________________
Best Regards,
Shamim
Old 10-21-2017, 13:11   #134 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
all: Done!
Thank you.
Suggested file is seems ok , but yur model id is confusing
Old 10-21-2017, 13:16   #135 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Yu can not unzip this file frnd
1st yu need to pun in fastboot
then reboot to ruu mode by cmmd
Then send file via fastboot.
But givn file yu can not flash yu re on old bootloader so newer version files wont accept yur bootloader
Page generated in 0.24047 seconds with 8 queries
