HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
09-29-2017, 14:13 | #121 (permalink) |
Moderator Join Date: Oct 2011 Location: U.A.E
Member: 1676524 Status: Offline Sonork: 100.1608473 Thanks Meter: 2,713 | Just Relock Bootloader and Run exe of Firmware.
__________________ __________________ Rules are for the obedience of fools and the guidance of wise men. Best Regards, Shamim |
10-15-2017, 07:29 | #123 (permalink) | |
Member: 1676524 Status: Offline Sonork: 100.1608473 Thanks Meter: 2,713 | Quote:
__________________ __________________ Rules are for the obedience of fools and the guidance of wise men. Best Regards, Shamim | |
The Following User Says Thank You to ...:::SHAMIM:::... For This Useful Post: |
10-16-2017, 21:22 | #126 (permalink) |
Junior Member Join Date: Oct 2017 Location: Germany
Member: 2768759 Status: Offline Thanks Meter: 0 | bricked phone Hi there! I really need your help. So my htc one m8 had an issue with playing audio files (not only mp3 files but also basic ringtones etc. It didn't play anything audio related) and video files via the YouTube app. It also failed to recognize the carrier and wouldn't install system updates. So I tried to fix all that by flashing a Custom ROM (the Marshmallow Viper version)--problem is my android version was 4.4.4. so OF COURSE installing a marshmallow ROM only made everything worse. I couldn't even turn on wifi anymore. Once I realized that, I tried to undo everything by wiping the device with twrp and ended up wiping not only all my data but also the OS. So now I have a device with no OS, which means I'm stuck in bootloader mode and there is my problem. Since I can't boot into my system I can't check my model number which I need to determine the firmware I have to install in oder to fix everything. I have s-on and bootloader relocked so I can't flash just any firmware. And I can't get into recovery anymore. This is what I got from adb running the phoneinfo command: (bootloader) version: 0.5 (bootloader) version-bootloader: 3.18.0.0000 (bootloader) version-baseband: 1.19.21331147A1.09G (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: (bootloader) version-misc: PVT SHIP S-ON (bootloader) serialno: HT46KWM11338 (bootloader) imei: 357871053407568 (bootloader) imei2: Not Support (bootloader) meid: 00000000000000 (bootloader) product: m8_ul (bootloader) platform: hTCBmsm8974 (bootloader) modelid: 0P6B10000 (bootloader) cidnum: HTC__102 (bootloader) battery-status: good (bootloader) battery-voltage: 0mV (bootloader) partition-layout: Generic (bootloader) security: on (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: 5e4b24e4 (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 all: Done! finished. total time: 0.013s So... what do I do now? Do I need to give up on my phone? Help would be much appreciated. |
10-17-2017, 07:07 | #127 (permalink) |
Member: 1676524 Status: Offline Sonork: 100.1608473 Thanks Meter: 2,713 | @Ricktastic If Phone is Bootloader Locked Then Try This Ruu:- 0P6BIMG_M8_UL_M60_SENSE70_MR_HTC_Europe_6.12.401.4 _Radio_1.29.214500021.12G_20.72.4196t.01_release_4 64360_signed.zip
10-18-2017, 06:17 | #129 (permalink) | |
Check Sticky Thread, Tutorial are Available There!
10-18-2017, 15:13 | #130 (permalink) |
Member: 2768759 Status: Offline Thanks Meter: 0 | I tried that too. But I can't move the file to the sd card, neither with adb nor via usb cable using another phone. I think the file is the problem. I can't unzip it or even open it to look at the content. It says it's not recognized as 'achive file' |
10-18-2017, 17:49 | #131 (permalink) | |
Don't Try to Extract it, They are Encrypted! From PC Send File to Memory Card via Reader. Put The Phone in Bootloader Mode and Press Power for Update.
10-19-2017, 09:46 | #132 (permalink) |
Member: 2769627 Status: Offline Thanks Meter: 0 | (bootloader) version: 0.5 (bootloader) version-bootloader: 3.19.0.0000 (bootloader) version-baseband: 1.25.214500021.06G (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 4.16.401.10 (bootloader) version-misc: PVT SHIP S-OFF (bootloader) imei2: Not Support (bootloader) meid: 00000000000000 (bootloader) product: m8_ul (bootloader) platform: hTCBmsm8974 (bootloader) modelid: 0P6B13000 (bootloader) cidnum: 11111111 (bootloader) battery-status: good (bootloader) battery-voltage: 0mV (bootloader) partition-layout: Generic (bootloader) security: off (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: 3aa067db (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 all: Done! finished. total time: 0.090s Need firmware, please. Thank you. |
10-19-2017, 15:59 | #133 (permalink) | |
10-21-2017, 13:11 | #134 (permalink) | ||
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Quote:
Quote: | ||
10-21-2017, 13:16 | #135 (permalink) | |
Yu can not unzip this file frnd 1st yu need to pun in fastboot then reboot to ruu mode by cmmd Then send file via fastboot. But givn file yu can not flash yu re on old bootloader so newer version files wont accept yur bootloader | |
