Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > HTC > HTC Android based
HTC Android based General HTC Android phones discussion, firmwares, solution, root, help
Old 02-21-2018, 12:20   #1 (permalink)
Member: 2746416
Thanks Meter: 4
HTC One M9 - Error 155 in RUU EXE and RUU_ZIP_ERROR in fastboot
Hello. I have HTC One M9 0PJA100 with damaged firmware. After power on, it displays white screen with HTC green logo, and it stuck at this. I tried to flash a few RUU EXE firmware's found at TheAndroidSoul, but each firmware quickly after starting upgrade ends with error 155. I tried also flashing RUU ZIP firmware via fastboot, but I get error FAIL12 RU_ZIP_ERROR. Any ideas to fix this phone? Thanks.
RUU EXE which I tried:
1) RUU_HIMA_UL_M60_SENSE70_ATT_MR_NA_Gen_Unlock_3.35. 617.12.exe
2) RUU_HIMA_UL_M60_SENSE70_TMUS_MR_TMOUS_3.39.531.31. exe
3) RUU_HIMA_UL_N70_SENSE80_ATT_MR_NA_Gen_Unlock_4.23. 617.1.exe
All from https://www.theandroidsoul.com/htc-o...om-collection/
Fastboot history after trying to flash 0PJAIMG_Sprint_HTC_One_M9_4.27.651.4_RUU.zip
Microsoft Windows [Wersja 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. Wszelkie prawa zastrzeżone.
C:\Users\user\Downloads\ADB_new_HTC_One_M9>htc_fastboot oem rebootRUU
... OKAY
Execution time is 10(ms)
C:\Users\user\Downloads\ADB_new_HTC_One_M9>htc_fastboot flash zip ruu.zip
sending 'zip'... (103623 KB) OKAY
sending time = 7.896 secs
writing 'zip'... (bootloader) HOSD CL#671758
(bootloader) ERR check AES encrypted magic string failed.
(bootloader) end@Done
FAIL12 RU_ZIP_ERROR
FAILED (remote: 12 RU_ZIP_ERROR )
Execution time is 10(s)
Old 02-21-2018, 12:56   #2 (permalink)
Member: 2746416
Thanks Meter: 4
And after trying flash 0PJAIMG_HIMA_UHL_L50_SENSE70_hTC_Asia_HK_1.32.708. 15_R1_Radio_01.01_U11440261_56.02.50306G_2_F_relea se_426879_signed.zip with fastboot there were some other errors:
C:\Users\user\Downloads\ADB_new_HTC_One_M9>htc_fastboot devices
FA5B7YJ01777    fastboot
... OKAY
Execution time is 64(ms)
C:\Users\user\Downloads\ADB_new_HTC_One_M9>htc_fastboot flash zip rom.zip
sending 'zip'... (199294 KB) OKAY
sending time = 13.355 secs
(bootloader) ERR CID not matched
(bootloader) ERR [SD_UPDATE_ERR] CID NOT ALLOWED
(bootloader) ERR [SD_UPDATE_ERR] sddownload failed: 7
(bootloader) ERR Update zip file failed.
(bootloader) ERR ZIP ERROR, exit read zip loop
(bootloader) ERR ZIP signature checking failed...
(bootloader) Update zip file OK
(bootloader) ERR ZIP ERROR CODE, 7
FAIL7 RU_CID_FAIL cid in android-info mismatched
FAILED (remote: 7 RU_CID_FAIL cid in android-info mismatched )
Execution time is 20(s)
Old 02-21-2018, 13:59   #3 (permalink)
Member: 2746416
Thanks Meter: 4
And I forgot add that phone is secured - S-ON - so only ROMs signed by HTC will be accepted.
Old 02-21-2018, 14:18   #4 (permalink)
Member: 2188828
Sonork: WOW
Thanks Meter: 66
read getwar all and post here. I can help you!
Old 02-21-2018, 15:01   #5 (permalink)
Member: 2746416
Thanks Meter: 4
Here are result:
C:\Users\user\Downloads\ADB_new_HTC_One_M9>htc_fastboot getvar all
(bootloader) kernel: lk
(bootloader) product: htc_himauhl
(bootloader) version: 1.0
(bootloader) imei: (cut)
(bootloader) version-main: 3.35.401.32
(bootloader) boot-mode: download
(bootloader) version-baseband: 01.01_U11440792_97.00.51203G_F
(bootloader) version-bootloader: 1.0.0.0000
(bootloader) mid: 0PJA10000
(bootloader) cid: HTC__102
all:
Execution time is 14(ms)
Old 02-21-2018, 15:35   #6 (permalink)
Moderator
...:::SHAMIM:::...'s Avatar
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,713
Here are result:
all:
Try with This,
0PJAIMG_HIMA_UHL_N70_SENSE80_MR_HTC_Europe_4.14.40 1.7_Radio_01.01_U114401011_117.00.61117G_2_F_relea se_490768_signed_2_4.zip
__________________
__________________
Rules are for the obedience of fools and the guidance of wise men.
Best Regards,
Shamim
Old 02-21-2018, 16:18   #7 (permalink)
Member: 2746416
Thanks Meter: 4
Still ERROR with this soft you posted SHAMIM:
... OKAY
Execution time is 67(ms)
sending 'zip'... (134523 KB) OKAY
sending time = 9.838 secs
FAIL12 RU_ZIP_ERROR
Execution time is 12(s)
Old 02-22-2018, 07:40   #8 (permalink)
Moderator
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,713
... OKAY
FAIL12 RU_ZIP_ERROR
Put the firmware in Sd Card and Flash it via Bootloader!
__________________
__________________
Best Regards,
Shamim
Old 02-22-2018, 15:19   #9 (permalink)
Member: 2746416
Thanks Meter: 4
Unfortunately, still errors.
FILE /mnt/media_rw/ext_sd/0PJAIMG.zip
press VolUp to start flash
press VolDown to cancel
12 RU_ZIP_ERROR
12 RU_ZIP_ERROR
FAIL12 RU_ZIP_ERROR
press power to continue
Old 02-23-2018, 14:30   #10 (permalink)
Moderator
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,713
12 RU_ZIP_ERROR
12 RU_ZIP_ERROR
FAIL12 RU_ZIP_ERROR
Flash 1st Hosd File to Upgrade Hboot
hima_uhl_n70_hosd_signed.img
After Update phone by Ruu.
__________________
__________________
Best Regards,
Shamim
The Following User Says Thank You to ...:::SHAMIM:::... For This Useful Post:
Old 08-15-2018, 10:14   #11 (permalink)
ali ghasemi's Avatar
Member: 1779669
Sonork: 100.1622249
Thanks Meter: 158
hi afte flash file hima_uhl_n70_hosd_signed.img
no hboot - no ruu mode !
just download mode
please help me !
s-on
bootloader unlock
Old 08-15-2018, 20:15   #12 (permalink)
Moderator
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,713
just download mode
please help me !
s-on
bootloader unlock
Bootloader Should be Lock and Reprocess Hboot and Ruu flash!
__________________
__________________
Best Regards,
Shamim
Page generated in 0.25817 seconds with 8 queries
