Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > HTC > HTC Android based
HTC Android based General HTC Android phones discussion, firmwares, solution, root, help
Old 07-30-2018, 11:04   #151 (permalink)
Member: 2360038
Thanks Meter: 3
Originally Posted by gsmforumfriend View Post
Hi friends i need a firmware for this Htc m9 because inside is missing italian language. i used a custom rom ice-4.0.8_HIMA_UHL_MM60_SENSE70_HTC_WWE_3.35.401.12.zi p but after flashed i lost imei and play service always error so i put back and reflashed whit this version
0PJAIMG_HIMA_UHL_N70_SENSE80_MR_HTC_Europe_4.28.40 1.3_Radio_01.01_U114401011_117.00.61117G_2_F_relea se_498151_signed_2_4.zip
but inside is missing italian.
[IMG] [/IMG]
Ok friends i find bymyself the right firmware so i flashed and now have inside almost language.
Tanks the same
Old 08-04-2018, 08:01   #152 (permalink)
Member: 2378338
Thanks Meter: 3
htc m9 flash file need
C:\Program Files\Minimal ADB and Fastboot>fastboot getvar all
(bootloader) version:0.5
(bootloader) variant:MTP eMMC
(bootloader) secure:yes
(bootloader) version-baseband:
(bootloader) version-bootloader:
(bootloader) max-download-size: 0x20000000
(bootloader) partition-type:cache:ext4
(bootloader) partition-size:cache: 0x14000000
(bootloader) partition-type:userdata:ext4
(bootloader) partition-size:userdata: 0x5e0000000
(bootloader) partition-type:system:ext4
(bootloader) partition-size:system: 0x118000000
(bootloader) serialno:FA62GYJ00338
all:
finished. total time: 0.141s
Old 08-09-2018, 12:23   #153 (permalink)
Member: 2669864
Thanks Meter: 42
C:\Users\RYDER\Desktop\ADB_FRP>fastboot getvar all
(bootloader) version: 0.5
(bootloader) partition-type:cache: ext4
(bootloader) partition-type:userdata: ext4
(bootloader) partition-type:system: ext4
(bootloader) serialno: HT53NSV01308
all:
finished. total time: 0.109s
Old 08-19-2018, 15:25   #154 (permalink)
Member: 1240648
I NEED FIRMWARE
C:\Users\user\Desktop\platform-tools>fastboot getvar all
(bootloader) kernel: lk
(bootloader) product: htc_himaulatt
(bootloader) version: 1.0
(bootloader) imei: 357226068872xxx
(bootloader) version-main: 3.35.401.12
(bootloader) boot-mode: download
(bootloader) version-baseband: 01.01_U11440792_97.00.51203G_F
(bootloader) version-bootloader: 1.0.0.0000
(bootloader) mid: 0PJA11000
(bootloader) cid: BS_US001
all:
Finished. Total time: 0.014s
Old 08-19-2018, 16:19   #155 (permalink)
Moderator
...:::SHAMIM:::...'s Avatar
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,713
Originally Posted by peterneuman View Post
I NEED FIRMWARE
all:
0PJAIMG_HIMA_UHL_M60_SENSE70_HTC_Europe_3.35.401.1 2_Radio01.01_U11440792_97.00.51203G_F_release_sign ed.zip
__________________
__________________
Rules are for the obedience of fools and the guidance of wise men.
Best Regards,
Shamim
Old 08-19-2018, 17:32   #156 (permalink)
Member: 1240648
thank you shamim to answer my post
i have already download this firmware and installed in my SD card he give me this error
10 RU_MODELID_FAIL
i will try to download firmware for asian not for eurobe nr 2 from the list and i will see what haben. i will let you know
have any i DEA what this error 10 RU_MODELID_FAIL mean
thank you
Old 08-19-2018, 17:46   #157 (permalink)
Member: 1240648
i search in anther form somebody tell me to change the cid from the phone with this comand
fastboot oem writecid 11111111 is that good
Old 08-19-2018, 19:03   #158 (permalink)
Moderator
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,713
10 RU_MODELID_FAIL
thank you
Your Product id was Not correct with main version info.
Try with this firmware
0PJAIMG_HIMA_UL_M60_SENSE70_ATT_MR_NA_Gen_Unlock_3 .35.617.31.zip
__________________
__________________
Best Regards,
Shamim
Old 08-19-2018, 22:30   #159 (permalink)
Member: 1240648
thanks again
error 12 RU_MODELID_FAIL
i changed cid to BS_US002 becouse i found this in page nr 8 (KLINIK PHONE 70)
now flash is complete but firmware only for developer it write this before start
Old 08-19-2018, 22:48   #160 (permalink)
Member: 1240648
i have upgraded ota and change cid to bs_us001
now look like this
(bootloader) serialno: FA6AEYJ0035x
(bootloader) current-slot:
(bootloader) version-main: 4.14.617.6
(bootloader) version-baseband: 01.01_U11440971_103.00.61018G_F
can tell me where i found firmware for it but please not for devoleper
thanks
Old 08-24-2018, 21:45   #161 (permalink)
Member: 2860427
Hi Guys this is my Getvar:
(bootloader) product: htc_himauhl
(bootloader) serialno: ***************
(bootloader) imei: *******************
(bootloader) version-main: 4.28.401.3
(bootloader) version-baseband: 01.01_U114401011_117.00.61117G_2_F
(bootloader) mid: 0PJA10000
(bootloader) cid: 11111111
I am in UK and on O2
I tried using the O2 RUU you have posted here but I get Error 12 whilst trying to install.
I have changed mid from 0PJA11000 to 0PJA10000 and am using the Intenational WWE RUU.
I need to change the Radio as it does not work well in UK
Any help would be appreciated.
Thanks
Old 08-25-2018, 07:25   #162 (permalink)
Moderator
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,713
Thanks
Relock Bootloader if it already Unlocked.
Make S-off and Reprocess O2 Ruu.
__________________
__________________
Best Regards,
Shamim
The Following User Says Thank You to ...:::SHAMIM:::... For This Useful Post:
Old 08-26-2018, 16:34   #163 (permalink)
Member: 2860427
I got it working but it wanted to Update but couldn't as it said software was unofficial.
So I changed to WWE RUU but that has the wrong Radio for UK O2 and has very bad signal. I don't suppose you could extract the Radio from the above O2 RUU and make it a Zip for me to apply in Recovery please!!!
Old 08-26-2018, 18:46   #164 (permalink)
Moderator
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,713
Try to install on phone custom rom!
Unlock Botloader
Flash Custom twrp recovery
Flash Custom Venom Rom
__________________
__________________
Best Regards,
Shamim
Old 09-04-2018, 09:48   #165 (permalink)
Member: 2478653
Sonork: 100.1678019
Thanks Meter: 152
Need HTC M9 OPJA110 Firmware
Page generated in 0.29835 seconds with 10 queries
