Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > HTC > HTC Android based
HTC Android based General HTC Android phones discussion, firmwares, solution, root, help
Old 07-08-2018, 17:41   #1 (permalink)
Member: 2849645
HTC One M9 won't boot, "Software status: Modified"
Hi,
I've been given a HTC One M9 that doesn't want to boot. The phone itself was used by a girl and then put into the box - software is 100% official.
However, the device shows something like that after booting:
*** Software status: Modified ***
*** LOCKED ***
*** S-ON***
Below that you've got some options to pick: reboot, 1)reboot to bootloader, 2)boot to download mode, 3)boot to recovery mode, power down.
1) Does nothing, reboots to the menu mentioned above
3) Shows HTC Logo, then a phone with red triangle with exclamation mark in it, then reboots.
2) Download mode shows that:
htc download mode
*** LOCKED ***
htc_himauhl PVT S-ON
LK-1.0.0.0000
RADIO-01.01_U11440792_95.00.51130G_F
OpenDSP-15.6.1.00522.8994_1016
OS-3.35.69.14
Jan 15 2016,22:33:12(670363)
Can you tell me what to do to make this phone usable again? Hope you'll help me
Old 07-10-2018, 14:21   #2 (permalink)
Moderator
...:::SHAMIM:::...'s Avatar
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,164
Originally Posted by Nadesrau View Post
Hi,
*** LOCKED ***
*** S-ON***
htc download mode
*** LOCKED ***
LK-1.0.0.0000
OS-3.35.69.14
Flash 1st Phone with Hboot
0PJAIMG_HIMA_UHL_N70_SENSE80_MR_HTC_Europe__partia l_2_4_2.zip
When You Updated Hboot Then Flash phone with Stock Ruu.
0PJAIMG_HIMA_UHL_N70_SENSE80_MR_Orange_PL_4.23.69. 1_Radio_01.01_U114401011_117.00.61117G_2_F_release _495710_signed_2_4.zip
__________________
__________________
Rules are for the obedience of fools and the guidance of wise men.
Best Regards,
Shamim
The Following User Says Thank You to ...:::SHAMIM:::... For This Useful Post:
Old 07-10-2018, 16:51   #3 (permalink)
Member: 2849645
Is there any guide on how to do both of those things?
Old 07-10-2018, 19:54   #4 (permalink)
Member: 478535
Thanks Meter: 367
download this:
https://www.htcdev.com/process/legal_fastboot_win
Extract this on c:\ADB
Put the zip files given by ...:::SHAMIM:::... in same folder
Put phone in download mode (number two 2 in your description)
Open command line in folder c:\adb (same with all the files you download you press shift and right click on folder and choose (open command window here)
With phone already connected to pc and driver installed, you do this commands on command window:
fastboot flash zip 0Pxxxx.zip - where 0Pxxxx.zip are the complete name of the files given by SHAMIN
example:
fastboot flash zip 0PJAIMG_HIMA_UHL_N70_SENSE80_MR_HTC_Europe__partia l_2_4_2.zip
fastboot flash zip 0PJAIMG_HIMA_UHL_N70_SENSE80_MR_Orange_PL_4.23.69. 1_Radio_01.01_U114401011_117.00.61117G_2_F_release _495710_signed_2_4.zip
Files cannot have spaces in names!
Old 07-11-2018, 07:02   #5 (permalink)
Moderator
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,164
Hello Friend,
You May Follow bellow That Thread:-
[Noob Guide] Htc zip format file flashing & Via SdCard flashing Guide!!!
__________________
__________________
Best Regards,
Shamim
Old 07-11-2018, 16:35   #6 (permalink)
Member: 2849645
Okey, I've tried flashing those but I'm getting errors on hboot part:
writing 'zip'...
(bootloader) HOSD CL#670363
(bootloader) ERR CID not matched
(bootloader) ERR [SD_UPDATE_ERR] CID NOT ALLOWED
(bootloader) ERR [SD_UPDATE_ERR] sddownload failed: 7
(bootloader) ERR Update zip file failed.
(bootloader) ERR ZIP ERROR, exit read zip loop
(bootloader) ERR ZIP signature checking failed...
(bootloader) Update zip file OK
(bootloader) ERR ZIP ERROR CODE, 7
(bootloader) end(at)Done
FAILED (remote: 7 RU_CID_FAIL cid in android-info mismatched )
finished. total time: 12.905s
What should I do ?
Old 07-12-2018, 10:25   #7 (permalink)
Moderator
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,164
writing 'zip'...
What should I do ?
0PJAIMG_HIMA_UHL_M60_SENSE70_MR_Orange_PL_3.35.69. 14_Radio_01.01_U11440792_95.00.51130G_F_release_46 7411_signed_2_4.zip
Download This Firmware and Rename it to 0PJAIMG.zip
Put the Firmware in the Sd Card
Enter Phone in Bootloader Mode and Follow to the instruction.
It would be work with you
__________________
__________________
Best Regards,
Shamim
Old 07-12-2018, 17:41   #8 (permalink)
Member: 2849645
The process is not starting automatically on my phone, bootloader option just boots it into the menu mentioned in the 1st post...
Old 07-12-2018, 17:55   #9 (permalink)
Moderator
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,164
Follow to the Video Tutorial.
http://www.youtube.com/watch?v=-Su9jj-MjIo
__________________
__________________
Best Regards,
Shamim
Page generated in 0.34080 seconds with 7 queries
