HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
04-20-2014, 16:47 | #2 (permalink) | |
No Life Poster Join Date: May 2008 Location: P@Ki$t@n
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | Quote:
You Need To Do That Just Unlock Ur Bootloader Flash Custom Recovery Download HTC One *STOCK* ROM | 4.19.401.11 | KitKat 4.4.2 | HTC Sense 5.5 Now Extract boot.img From Downloaded zip and copy into Ur fastboot folder connect handset in fastboot mode and flash boot.img with command '' fastboot flash boot boot.img '' now copy downloaded zip into Ur internal SD Card & Go Into Recovery Format User Data Format cache Then Flash Zip From SD Card Choose zip From SD Card Then Select Rom Witch You Copy & Flash It After Flash Reboot Handset To Fastboot USB again and Flash Official Recovery connect handset with fastboot usb extract downloaded recovery Run Install recovery bat And Simple reboot now into system You Are Done ROM 4.19.401.11 | KitKat 4.4.2 | HTC Sense 5.5 | |
