HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
09-27-2014, 14:03 | #1 (permalink) |
No Life Poster Join Date: Oct 2008 Location: PAKISTAN
Member: 882981 Status: Offline Sonork: 161363 Thanks Meter: 306 | Htc One S ruu rom needed (bootloader) version: 0.5 (bootloader) version-bootloader: 2.15.0000 (bootloader) version-baseband: 1.13.50.05.31 (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 1.00.000.0 (bootloader) version-misc: PVT SHIP S-ON (bootloader) serialno: SH23LW400304 (bootloader) product: vle (bootloader) platform: HBOOT-8960 (bootloader) modelid: PJ4010000 (bootloader) cidnum: 11111111 (bootloader) battery-status: good (bootloader) battery-voltage: 3746mV (bootloader) partition-layout: Generic (bootloader) security: on (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: dirty-64bedd38 (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 all: Done! finished. total time: 0.359s i need RUU file |
09-27-2014, 23:41 | #4 (permalink) | |
Member: 882981 Status: Offline Sonork: 161363 Thanks Meter: 306 | Quote: 10 time flash diffrent ruu exe some time unkown error or some time image error not ander stand repair imei with jtag after restarting problam | |
09-27-2014, 23:44 | #5 (permalink) |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Den unlock bootloader flash custom recovery lik twrp recovery or clockworkmod recovery flash any custom rom nd check Download recovery from here Rename the recovery file as recovery to flash the recovery use tis commnd: fastboot flash recovery recovery.img Custom rom here Last edited by jamesjerss; 09-27-2014 at 23:53. |
The Following User Says Thank You to jamesjerss For This Useful Post: |
09-28-2014, 17:21 | #8 (permalink) |
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Did yu unlock yur bootloader nd did yu flash the recovery if yes copy the rom into sdcard boot yur mob into recovery mode flash rom using twrp recovery . or contact me via yahoo |
09-29-2014, 06:11 | #11 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Did You Tried this File RUU_Ville_U_JB_45_S_HTC_Europe_3.16.401.8_Radio_1. 11.50.05.28_10.27.50.08L_relea se_301814_signed_2_4 Shipped ROMs Also try This One http://www.androidruu.com/getdownloa...gned_ICS_2.exe |
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post: |
10-21-2014, 18:15 | #14 (permalink) | |
Member: 882981 Status: Offline Sonork: 161363 Thanks Meter: 306 | Quote: C:\adb>fastboot flash PJ4010000-OneS unknown partition 'PJ4010000-OneS' error: cannot determine image filename for 'PJ4010000-OneS' C:\adb>fastboot flash zip PJ4010000-OneS.zip sending 'zip' (35551 KB)... OKAY [ 2.656s] writing 'zip'... (bootloader) adopting the signature contained in this image... FAILED (remote: 92 supercid! please flush image again immediately) finished. total time: 2.797s C:\adb>fastboot oem boot < waiting for device > ... (bootloader) Boot/Recovery signature checking... (bootloader) Boot/Recovery signature checking... (bootloader) setup_tag addr=0x80400100 cmdline add=0xC02F55A4 (bootloader) TAG:Ramdisk OK (bootloader) TAG:skuid 0x2ED00 (bootloader) TAG:hero panel = 0x2940043 (bootloader) TAG:engineerid = 0x0 (bootloader) TAG: PS ID = 0x0 (bootloader) TAG: Gyro ID = 0x0 (bootloader) Device CID is super CID (bootloader) CID is super CID (bootloader) Backup CID is empty (bootloader) setting->cid::11111111 (bootloader) serial number: SH23LW400304 (bootloader) setting_ddr_vendor_get_mid DDR vendor not init! (bootloader) commandline from head: console=ttyHSL0,115200,n8 (bootloader) command line length =745 (bootloader) active commandline: poweron_status=1 reset_status=0 board_vi (bootloader) lle.disable_uart3=0 diag.enabled=0 board_ville.debug_uart=0 (bootloader) userdata_sel=0 androidboot.emmc=true androidboot.pagesize=20 (bootloader) 48 skuid=0 ddt=20 ats=0 androidboot.lb=1 uif=?000 td.sf=1 t (bootloader) d.td=1 td.ofs=328 td.prd=1 td.dly=0 td.tmo=300 hlog.ofs=628 (bootloader) un.ofs=694 imc_online_log=0 androidboot.efuse_info=FFSL and (bootloader) roidboot.baseband=1.13.50.05.31 androidboot.cid=11111111 and (bootloader) roidboot.devicerev=3 androidboot.batt_poweron=good_battery a (bootloader) ndroidboot.carrier=A (bootloader) aARM_Partion[0].name=misc (bootloader) aARM_Partion[1].name=recovery (bootloader) aARM_Partion[2].name=boot (bootloader) aARM_Partion[3].name=system (bootloader) aARM_Partion[4].name=local (bootloader) aARM_Partion[5].name=cache (bootloader) aARM_Partion[6].name=userdata (bootloader) aARM_Partion[7].name=devlog (bootloader) aARM_Partion[8].name=pdata (bootloader) aARM_Partion[9].name=fat (bootloader) aARM_Partion[A].name=extra (bootloader) aARM_Partion[B].name=reserve (bootloader) aARM_Partion[C].name=radio (bootloader) aARM_Partion[D].name=adsp (bootloader) aARM_Partion[E].name=dsps (bootloader) aARM_Partion[F].name=wcnss (bootloader) aARM_Partion[10].name=radio_config (bootloader) aARM_Partion[11].name=modem_st1 (bootloader) aARM_Partion[12].name=modem_st2 (bootloader) aARM_Partion[13].name=reserve (bootloader) partition number=20 (bootloader) Valid partition num=20 (bootloader) setting_get_bootmode() = 9 (bootloader) ram size = 0 (bootloader) TZ_HTC_SVC_SET_DDR_MPU ret = 0 (bootloader) smem 90005000 (phy 90005000): TZ_HTC_SVC_UPDATE_SMEM ret = 0 (bootloader) TZ_HTC_SVC_LOG_OPERATOR ret = 0 (bootloader) TZ_HTC_SVC_ENC ret = 0 (bootloader) TZ_HTC_SVC_DISABLE ret = 474079232 (0x1C41E000) (bootloader) Start Verify: 3 (bootloader) jump_to_kernel: machine_id(3751), tags_addr(0x80400100), ker (bootloader) nel_addr(0x80408000) (bootloader) -------------------hboot boot time:9535 msec FAILED (status read failed (Too many links)) finished. total time: 6.969s | |
10-21-2014, 19:36 | #15 (permalink) |
Freak Poster Join Date: Apr 2013 Location: PAP-Haiti Age: 36
Member: 1914596 Status: Offline Sonork: 100.1619364 Thanks Meter: 59 | hi you are already unlock bootloader? You need to unlock your bootloader flash with a custom recovery and a custom rom Last edited by technisoft; 10-21-2014 at 19:45. |
