HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
11-23-2014, 08:59 | #1 (permalink) |
Freak Poster Join Date: Aug 2008 Location: india/kolkata Age: 37
Member: 845623 Status: Offline Sonork: 100.1606036 Thanks Meter: 125 | htc one sv hung on logo how to solev k2_ul pvt ship s-off rl cid-11111111 hboot-1.01.0000 radio-0.12.40.00.14_2 opendsp-v7.2.0221.1123 emmc-boot dec 7 2012;03;10;20;-1 flash with ruu_k2_ul_ics_40_htc_europe ruu fail ERROR [130]: MODEL ID ERROR plz help me |
11-23-2014, 09:04 | #2 (permalink) |
No Life Poster Join Date: Oct 2010 Location: India Age: 31
Member: 1713856 Status: Offline Sonork: Uninstalled Thanks Meter: 4,500 | Can you read boot info with htx and post here,this error mean you are trying wrong carrier rom. |
The Following User Says Thank You to Rahul_Bhutani For This Useful Post: |
11-23-2014, 10:25 | #3 (permalink) |
Member: 845623 Status: Offline Sonork: 100.1606036 Thanks Meter: 125 | model;k2_ul imei:352803055421136 build:1.17.401.5 cid:11111111 hboot:1.01.0000 mid-pl80***** security-off region:super_cid |
11-23-2014, 12:00 | #4 (permalink) |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Yu re on s-off nd super cid nd yur model id also seems lik ok can yu post the ful model id mid-pl80***** Or do lik this Extract the rom.zip from RUU Extract the rom.zip nd opn android-info-txt There yu can se model id check tat model id vit yur device model id if not same simply change the model id using fastboot. For Example if yu hav Modelid PL80000 n tat rom.zip Run command lik given dwn fastboot oem writemid PL80000 Check boot info again yur mid must be changed Try RUU again Br james Last edited by jamesjerss; 11-23-2014 at 13:20. |
The Following User Says Thank You to jamesjerss For This Useful Post: |
11-23-2014, 13:38 | #6 (permalink) | |
Member: 1713856 Status: Offline Sonork: Uninstalled Thanks Meter: 4,500 | Normally htx show MID but in some case like if phone has cleaned s58 data with java card make mid universal. Now goto adb folder in htx tool and open folder in cmd,and try the command below. "fastboot oem writemid "XXXXXXX" without quote,and where xxxx is your model id,you will find somewhere printed in phone,mostly downside battery in not fixed battery. And they retry flashing rom... Quote:
Btw congrats for become mod | |
