HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
10-28-2014, 23:28 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,374 | Htc One X endeavorU Softunbrick+Guide to Recover from Bootloop problems Htc OneXendeavorU Softunbrick+Guide to Recover from Bootloop problems Note:No need S-off or super Cid Unlock yur Bootloader 1st manual wayTutorial here Or Use Below given Tool [Tool] HTX Multi Tool V1.0 Beta Tool Released! Credits Rahul_Bhutani Download Twrp Recovery Latest Here Rename the Downloaded Twrp Recovery as recovery nd run below cmmd to flash Cnnt yur mob n fastboot mode fastboot flash recovery recovery.img Download Tested Custom Rom Here Rom credit mike1986. Download boot.img * Put yur mobile into fastboot mode * Extract the Bootimg.zip nd run the bat file to flash boot.img * After flash boot.img boot into recovery mode * Full wipe Data, Cache, System & Delvik Cache * In recovery goto adavance enable adb sideload * Copy the rom to adb folder * Run command * adb sideload romname.zip * after load 100% flash the rom using twrp recovery *Reboot For Htc m7 All models Here Last edited by jamesjerss; 06-21-2015 at 14:59. |
The Following 3 Users Say Thank You to jamesjerss For This Useful Post: |
04-24-2015, 07:46 | #4 (permalink) | |
No Life Poster Join Date: Oct 2008 Location: in your Heart
Member: 888557 Status: Offline Sonork: 100.1608317 Thanks Meter: 34 | Quote:
Fastboot : Fastboot is a special diagnostic and engineering protocol. You can boot your HTC Android Devices into fastboot mode. While in fastboot, you can modify the file system images from a computer like you can flash kernel as well as other partitions. ADB : ADB stands for Android Debug Bridge. Its a tool to send commands to Android Phones from Computer Command Line. Download Fastboot & ADB tool and driver from Dev-Host - Fastboot+ADB(20926).zip - The Ultimate Free File Hosting / File Sharing Service make adb folder in c:\ copy downloaded fastboot and adb tool into c:\adb copy rom file on c:\adb | |
12-09-2015, 09:27 | #5 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Bangladesh Age: 42
Member: 180833 Status: Offline Sonork: 100.1578281 Thanks Meter: 217 | [QUOTE=jamesjerss;10644050] thanks for this share .. i try with this method but after completing all thing phone not run stuck on logo. my previous problem was that. ( my customer told me he just try to install a font from play store and after that phone goes to stuck mode. ) my phone info is here Code: (bootloader) version: 0.5a (bootloader) version-bootloader: 1.12.0000 (bootloader) version-baseband: 2.1204.135.20 (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 2.17.401.2 (bootloader) serialno: SH24MW103923 (bootloader) imei: 353043055804184 (bootloader) product: endeavoru (bootloader) platform: HBOOT-T30S (bootloader) modelid: PJ4610000 (bootloader) cidnum: HTC__001 (bootloader) battery-status: good (bootloader) battery-voltage: 3836mV (bootloader) devpower: 54 (bootloader) partition-layout: None (bootloader) security: on (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: None (bootloader) hbootpreupdate: 2 (bootloader) gencheckpt: 0 all: Done! suggest me what should i do to recover this phone. |
12-09-2015, 12:06 | #6 (permalink) | |
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,374 | [QUOTE=sanjoychy;11464580] Quote:
fastboot oem lock flash stock RUU_ENDEAVOR_U_ICS_40_S_HTC_Europe_2.17.401.2_Radi o_2.1204.135.20_release_274900_signed.exe | |
12-09-2015, 14:35 | #7 (permalink) | |
Member: 180833 Status: Offline Sonork: 100.1578281 Thanks Meter: 217 | [QUOTE=jamesjerss;11464982] Quote:
Firmware update done successfully but now the problem is phone totaly open and show the desktop wallpaper and after then phone will be off. | |
12-09-2015, 19:08 | #8 (permalink) | |
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,374 | [QUOTE=sanjoychy;11465304] Quote:
RUU_ENDEAVOR_U_JB_45_S_HTC_Europe_3.14.401.31_R_Ra dio_5.1204.162.29_release_302015_signed.exe | |
12-17-2015, 08:34 | #11 (permalink) | |
No Life Poster Join Date: Jan 2014 Location: GM7
Member: 2102992 Status: Offline Sonork: 100.1626305 Thanks Meter: 2,763 | Quote:
PJ46IMG_ENDEAVOR_U_JB_50_S_hTC_Asia_India_4.19.720 .1_Radio_5.1204.167.31_release_333146_signed.zip by Rahul_Bhutani Don't forget to press Thanks Button Read The Rules Careful HERE Br M@SUD | |
12-17-2015, 08:56 | #13 (permalink) | |
http://forum.gsmhosting.com/vbb/f485...guide-1952646/ Note : U S Htc special fastboot Driver Don't forget to press Thanks Button Read The Rules Careful HERE Br M@SUD | |
12-18-2015, 07:43 | #14 (permalink) |
Freak Poster Join Date: Jan 2007 Location: @ planet EARTH
Member: 433173 Status: Offline Sonork: 100.1590587 Thanks Meter: 31 | this is the error what i am getting Code: C:\adb>fastboot devices FA28LW105046 fastboot C:\adb>fastboot oem rebootRUU ... (bootloader) Save data from original MSC... (bootloader) Save data from SIF... (bootloader) Update partition data to SIF partition (bootloader) Update partition data from original MSC... (bootloader) [MSG] OKAY OKAY [ 0.212s] finished. total time: 0.214s C:\adb>fastboot flash zip PJ46IMG.zip sending 'zip' (719329 KB)... OKAY [ 91.614s] writing 'zip'... (bootloader) shift signature_size for header checking... FAILED (remote: 32 header error) finished. total time: 91.892s C:\adb> |
12-18-2015, 14:04 | #15 (permalink) | |
Member: 2102992 Status: Offline Sonork: 100.1626305 Thanks Meter: 2,763 | @recallrules relock bootloader then try flash Fastboot command: Quote:
