Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > HTC > HTC android based
HTC android based General HTC Android phones discussion, firmwares, solution, root, help
Old 08-03-2012, 09:24   #1 (permalink)
Member: 1670865
HTC One X LCD Backlight Problem
Hi all.
I've got HTC One X after LCD replacement. Now there is no backlight - new LCD checked and it's ok, also I've checked few others so definitly not an lcd issue. Probably LCD connector's problem - little dent on it. Can somebody help me with this? Probably needs a jumper, but I don't know from where to where. I add also a picture of main borad, connector is in right top corner http://i.techrepublic.com.com/galler...97-620-410.jpg. If somebody could draw a pictrure with a jumeper I'd appreciate.
BR.
Old 08-03-2012, 09:39   #2 (permalink)
Member: 1670865
LCD Connector is on TOP LEFT CORNER! My mistake.
Old 08-03-2012, 17:42   #3 (permalink)
Member: 1788854
when the phone turns on, do you feel that the light hand side get hot? it may be the inductor problem. replace it and problem solve.
JUST FIX ONE WITH SIMILAR PROBLEM 2 DAYS BEFORE.
Old 08-11-2012, 05:08   #4 (permalink)
Member: 744574
I once met a same problem to once change an electricity light to control as well similar will not like to have can solve without the other methods
Old 08-18-2012, 09:24   #5 (permalink)
Member: 1189191
can any one please help me with htc one x lcd light problem. can u plz tell me where inductor if of this phone..thanks in advance
Old 08-20-2012, 07:26   #6 (permalink)
Member: 262820
inductor position
Where is inductor position on pcb board?
Old 09-26-2012, 06:53   #7 (permalink)
desmond2727's Avatar
Member: 58704
Sonork: 100.1618753
hi mate can u explain more clear which part u change soivle ur problem
Thanks
Old 10-10-2012, 01:13   #8 (permalink)
carlos barrera's Avatar
Member: 693375
I have a same problem lcd light not work , i check a lcd and this is ok maybe board is bad some one can help me
Old 10-10-2012, 16:16   #9 (permalink)
Member: 1788854
Please do one by one! Your problem will be solved.
P.S. the mother board of One X is different with One XL. This Solution is for HTC ONE X ONLY!
The Following 2 Users Say Thank You to Mobile Fix Simple For This Useful Post:
Old 10-11-2012, 07:11   #10 (permalink)
Member: 58704
Sonork: 100.1618753
hi mate
i can find the ic for replace
The Following User Says Thank You to desmond2727 For This Useful Post:
Old 10-24-2012, 13:25   #11 (permalink)
Member: 648760
At display replacement at me the smoke from the coil with an inscription 220 went and illumination was gone! The coil approached from SE W880 with an inscription 220! Phone works!
The Following User Says Thank You to Li Hoy For This Useful Post:
Old 10-25-2012, 18:53   #12 (permalink)
Member: 484639
i have the same problem, but my screen has no backlight and it's flickering. i hope this solution will help. thanks
Old 11-06-2012, 08:21   #13 (permalink)
Member: 1835673
Where to buy parts?
Hi
Can anyone please tell me where I can buy the parts mentioned in this post?
Thanks very much!
Old 11-06-2012, 21:25   #14 (permalink)
Member: 852006
Sonork: 115693
lcd issue
hi i got an issue,i have one x and lcd was flickering i thaught its lcd,i baught another one and tested it workd fine but the bottom side sensor was not working so i thaught let me order oter lcds and i got another stock after one weak i have tried 2-3 lcd including the privious one which was displaying before but no luck there was no display on phone on any of them,its a strange thing,has anybody solved this issue
Old 11-06-2012, 22:59   #15 (permalink)
unlock.mk's Avatar
Member: 1671934
Sonork: 1612800
Originally Posted by desmond2727 View Post
hi mate
Just take coil from any iphone board, it will work, i have managed to solve light problem changing that coil with iphone coil, i think was r2r os something.
Just replace it.
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 7 07-18-2012 07:57
Sim card sleep mode problem with 6130 ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 05-22-2012 11:13
GId1 problem old_man Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 10-18-2006 15:21
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 07-16-1999 00:44
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 06-10-1999 22:36
Page generated in 0.36801 seconds with 12 queries
