Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > HTC > HTC Android based
HTC Android based General HTC Android phones discussion, firmwares, solution, root, help
Old 11-21-2014, 14:12   #1 (permalink)
san9090's Avatar
Member: 697664
Sonork: 100.1602716
Thanks Meter: 267
Smile Htc one x restart with logo
I have htc one x pj46100
its already super cid
cid-11111111
hboot-1.36.0000
cpld-none
microp-none
radi05.1204.162.29
plz guide me o retrieve
this set
i have try to update with with stock ruu but unable to success
plz guide how to alive this set
Old 11-21-2014, 14:30   #2 (permalink)
sm-shahzada's Avatar
Member: 2130293
Sonork: 100.1637594
Thanks Meter: 68
Thumbs down
cid-11111111
hboot-1.36.0000
cpld-none
microp-none
radi05.1204.162.29
this set
download xl multi tool read info and send me
Old 11-21-2014, 15:19   #3 (permalink)
san9090's Avatar
Member: 697664
Sonork: 100.1602716
Thanks Meter: 267
Smile brother can u give me valid link for XLMultiTool.v2.1.zip
i have searched all link for XLMultiTool.v2.1.zip but all expire
plz share
Old 11-21-2014, 15:33   #4 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
cid-11111111
hboot-1.36.0000
cpld-none
microp-none
radi05.1204.162.29
this set
Yur file
RUU_ENDEAVOR_U_JB_45_S_HTC_Europe_3.14.401.31_R_Ra dio_5.1204.162.29
Before Run ruu check yur BOOTLOADER Unlocked or locked
If unlocked relock yur bootloader 1st den run the ruu run below givn cmmd to lock yur bootloader
fastboot oem lock
james
The Following User Says Thank You to jamesjerss For This Useful Post:
Old 11-21-2014, 15:37   #5 (permalink)
san9090's Avatar
Member: 697664
Sonork: 100.1602716
Thanks Meter: 267
Smile here is info with htx multitool
i have htx multitool
here is info with this tool in fastbootmode
Model : ENDEAVORU
IMEI : 35399505028xxxx
Build : 2.17.707.3
CID : 11111111
HBoot : 1.12.0000
MID : PJ461****
Security : OFF
Region : Super_CID
Old 11-21-2014, 15:45   #6 (permalink)
san9090's Avatar
Member: 697664
Sonork: 100.1602716
Thanks Meter: 267
Smile low main battery power while i charged it full
fastboot oem lock
james
brother giving me error low battery power while i already charged it full
bootloader is locked
Old 11-21-2014, 16:30   #7 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Try this http://forum.gsmhosting.com/vbb/f485...blems-1873680/
james
Old 11-22-2014, 12:55   #8 (permalink)
Member: 2130293
Sonork: 100.1637594
Thanks Meter: 68
Wink
RBSoft - Download - 4shared here download
Old 11-22-2014, 15:10   #9 (permalink)
san9090's Avatar
Member: 697664
Sonork: 100.1602716
Thanks Meter: 267
Smile all steps i did now its hang on logo
all steps i followed as u gave me in link
sucessfully install rom from adb sideload
after update now set is hang on htc one logo
now what to do plz guide
Old 11-22-2014, 15:57   #10 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Goto recovery reset yur device nd wipe delvik cache (dnt wipe system)
Extract boot.img from rom flash via fastboot
fastboot flash boot boot.img
Old 11-22-2014, 16:18   #11 (permalink)
san9090's Avatar
Member: 697664
Sonork: 100.1602716
Thanks Meter: 267
Smile i did
i did as u told me
extract boot.img from rom
and flashed it in fast boot
after that still same hang in htc one logo
C:\adb>fastboot flash unlocktoken Unlock_code.bin
sending 'unlocktoken' (0 KB)... OKAY [ 0.128s]
writing 'unlocktoken'... INFOunlock token check successfully
FAILED (status read failed (Too many links))
finished. total time: 15.738s
C:\adb>fastboot flash boot boot.img
sending 'boot' (4862 KB)... OKAY [ 0.639s]
writing 'boot'... INFOFormat partition LNX done
OKAY [ 0.519s]
finished. total time: 1.158s
C:\adb>
Old 11-24-2014, 08:13   #12 (permalink)
Member: 2093017
Sonork: 100.1650959
Thanks Meter: 117
Flashed it with only Ruu,Sideload or twrp method not work properly it,s give you error in the end but also said succesfully flashed.
1:Charge Battery Fully.
2ownload the ruu given above By James.
3:Check Bootloader locked or relocked.
4:install All Drivers good to try on win 7 because win 7 is good in performing htc ruu flashing Teset 3 Htc One Set not working on Xp.
5:Flashed it and wait for sometime your problem 100% Solved.
Old 11-25-2014, 17:30   #13 (permalink)
san9090's Avatar
Member: 697664
Sonork: 100.1602716
Thanks Meter: 267
Smile in ruu method always power low
i got error always in insttalling ruu
battey power low in ruu
Old 11-25-2014, 18:33   #14 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Try this
Download this firmware.zip nd flash via fastboot
fastboot flash zip firmware.zip
or
Download this OTA Zip Rename it as update (dnt change extension)
Put yur mob into recovery mode there select update via adb
copy the rom into adb folder nd run below cmmd to flash
adb sideload update.zip
james
Old 11-27-2014, 19:25   #15 (permalink)
san9090's Avatar
Member: 697664
Sonork: 100.1602716
Thanks Meter: 267
Cool still getting error
Try this
or
james
C:\adb>fastboot flash zip firmware.zip
sending 'zip' (12936 KB)... OKAY [ 1.878s]
writing 'zip'... FAILED (remote: not allowed)
finished. total time: 2.084s
C:\adb>fastboot oem lock
... INFOLock successfully...
OKAY [ 0.240s]
finished. total time: 0.241s
sending 'zip' (12936 KB)... OKAY [ 1.762s]
writing 'zip'... FAILED (remote: battery low)
finished. total time: 1.966s
C:\adb>
Page generated in 0.29165 seconds with 8 queries
