Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > HTC > HTC Android based
HTC Android based General HTC Android phones discussion, firmwares, solution, root, help
Old 02-07-2014, 20:00   #16 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
after searching for more ,
i got this
HTC One X APX Driver | Nvflash tool
For those of you that are in APX Mode or want to mess with APX here is the modified driver for the One X.
Now you have acces to the device again through USB.
Todo:
- Plug the usb cable in hox
- Goto device manager
- Search for APX or Unknown device or whatever it is listed
- Choose update driver
- Choose manually select driver
- Select the folder where you extracted the zip file
- Install drivers
Use nvflash to gain acces to the device again.
Download:
http://bindroidfiles.dannyvandijk.co...APX-Driver.zip
Nvflash:
- Use nvflash binary to gain acces to the device
- Including flash.cfg for endeavoru to use with nvflash.exe
- Including a bct file
http://bindroidfiles.dannyvandijk.co...id_nvflash.zip
what is this has anyone tried this ?
can it recover and htc one x ?
any other solution ?
Old 02-15-2014, 15:33   #17 (permalink)
Member: 2127920
I once repaired a fully dead one x, but mine did require some soldering as it had a hardware fault aswell
Do you get the red charging led?
Old 03-13-2014, 13:57   #18 (permalink)
amit.alag's Avatar
Member: 373527
Thanks Meter: 68
i have done it, get out to APX mode and set is working normally hurray!!
Old 03-13-2014, 14:25   #19 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
can u help how to do that ?
Old 04-23-2014, 20:17   #20 (permalink)
Member: 2173661
My HOX doesn't boot, doesn't charge and there is not even a charging LED when plugged in.
How to find out which part in the HTC One X is the broken one? I'm desperately trying to gain access to the data stored in the internal memory. Is there any hope?
Old 06-24-2014, 09:00   #21 (permalink)
sm-shahzada's Avatar
Member: 2130293
Sonork: 100.1637594
Thanks Meter: 68
Question
i got this
Todo:
- Install drivers
Download:
Nvflash:
link not work please check
Old 06-26-2014, 23:44   #22 (permalink)
Member: 667857
Thanks Meter: 34
Old 06-30-2014, 14:12   #23 (permalink)
Member: 1026830
Originally Posted by DIN231080 View Post
no hardware 100% software
i know need to boot repair
this mobile
dead after hang in application
I Have Htc One X (PJ46100).Phine Is On But Disply Is Not Coming...Pls help Me
Old 07-24-2014, 11:57   #24 (permalink)
Member: 761963
Sonork: 23235
Thanks Meter: 4
please give 4shared link...
Old 07-25-2014, 18:26   #25 (permalink)
nicnec's Avatar
Member: 50585
Thanks Meter: 63
Hi,
Here is NVFlash package to repair HTC One X PJ4610000 with dead boot.
RD_release(with_sbk)without sis.rar
Old 07-26-2014, 21:32   #26 (permalink)
mike_shinoda's Avatar
Member: 2136780
Thanks Meter: 68
For unbrick onex u should rehot or reball cpu 100% test
Old 02-13-2015, 16:40   #27 (permalink)
Member: 282785
Thanks Meter: 13
error write system.img not found, somebody can help with this file?
Old 03-14-2015, 03:07   #28 (permalink)
Member: 1442875
Thanks Meter: 2
tripndroid-hox-apx-driver - Download - 4shared
Old 10-05-2016, 15:03   #29 (permalink)
Member: 2396179
HELP HTC ONE X DEAD AND SHOWN IN DEVICES MANAGER qUALLCOM HS USB QLOADER 9008 COM 13
Old 11-20-2018, 08:52   #30 (permalink)
Member: 2824479
Thanks Meter: 39
The phone is defined in the task manager as APX. Somebody help. Share the link to the files from this post for nvflash firmware, none of them works! Nowhere I find a solution.
Page generated in 0.22717 seconds with 8 queries
