-   HTC Android based (http://forum.gsmhosting.com/vbb/f485/)
-   -   HTC sensation safe-free and noob method for unlocking (http://forum.gsmhosting.com/vbb/f485/htc-sensation-safe-free-noob-method-unlocking-1336392/)
gurinder 08-27-2011 11:29
1 Attachment(s)
1. MAKE A NANDROID BACKUP USING RECOVERY - (Completely switch off your phone, Press Volume down + Power button to get into bootloader, Volume down to recovery then press power button to get into Recovery. Volume down to "Backup and Restore" in recovery. Press Power to backup and your done!
(Make a backup in Titanium backup if you don't want to or can't nandroid backup. Menu > BAtch >Backup systems data + Apps with data)
2. Download PG58DIAG for the Sensation in the attachement.
3. Copy the PG58DIAG file into the Root folder of your SD card (The main Folder of your Memory Card)
4. Turn off your phone Fully and reboot into the Bootloader/HBOOT screen (see post 2 on how to get to bootloader screen)
5. Press Volume Down to Enter DIAG - Place the phone horizontally when it asks you too. (Flat)
6. Press power button to select "Clean S58 Data
7. Press power again to "clean S58 Data".
8. POW - your unlocked! Try a SIM card from a different provider!
9. Delete the file from your SD Card (Delete PG58DIAG) and REBOOT!!
Your phone Will set up for the first time, go through it all till you get to your home screen
10. Go back into recovery and restore nandroid backup. same method as step 1 above. but instead of backup, you use restore feature
(Use Titanium Backup to restore if you used it to backup instead of Nandroid backup)(Menu > Batch > Restore System Data + Apps with user data)
Now you’re free to go! Bear in mind, though, in certain circumstances you will lose your data connectivity or network signal. You’ll just need to check your APN, network type etc. and re-enter them; Just run the nandroid restore to get everything back
note : extract the file from rar and put it in root of the memory card.
Root & recovery
Revolutionary: S-OFF & Recovery Tool is your best friend when it comes to unlocking the bootloader (S-OFF) and recovery of your device. Once installed on your phone, it will allow you to root it easily, explore various ROMs, and freely install custom kernels. Follow the steps below to enable S-OFF on your HTC Sensation.
You may need to temporarily deactivate your antivirus and/or firewall software, as some security programs (e.g., Norton Antivirus) flag the Revolutionary: S-OFF & Recovery Tool as malware, even if it actually isn’t.
Take note of your device’s serial number. Pull out your phone’s battery and take a look at the label inside the battery compartment. Your handset’s serial number should be printed there, usually beside the label “S/N”.
Find out the HBOOT version on your handset. With your phone turned off, press the Volume Down and Power buttons simultaneously for a few seconds. The device will boot to a white screen showing device information, including the HBOOT version. Take note of the HBOOT version number and reboot your phone after doing so.
Go to the Revolutionary: S-OFF & Recovery Tool website and download the appropriate package for your platform (i.e., Linux or Windows). As soon as the package starts downloading, you will be redirected to a “Beta Key” form. Fill in the form with your device’s serial number and HBOOT version number. Press the “Generate Key” button to get your beta key. Take note of this beta key. You will be needing it when you run the Revolutionary tool.
http://www.androidauthority.com/wp-c.../Untitled1.jpg
By this time, the package file for the Revolutionary tool should have finished downloading. Extract the files into one folder on your computer’s hard drive.
Enable “USB Debugging” from the Settings Applications Development screen on your handset.
Connect the HTC Sensation to your computer via USB cable. When asked for a connection type, choose “HTC Sync” and just ignore warning messages saying your phone could not find HTC Sync.
Launch the Revolutionary tool (revolutionary.exe). A command prompt window will open and will ask you for the beta key.
Type or copy-and-paste the beta key for Revolutionary into the command prompt window. The beta key is case-sensitive. Press Enter to allow the tool to proceed.
Wait a little bit for Revolutionary to enable S-OFF and unlock the rewritable NAND on your handset.
site for downloading revolutionary tool is :Revolutionary
all crdts goes to guy sieempi at xda develeopers
gurinder
::gsmcoder:: 08-27-2011 11:38
And you think the sensation comes with recovery image from factory? how to root and flash recovery include in your tutorial
gurinder 08-27-2011 12:03
See Post #1 For Rooting & Recovery Method
mslion7 08-29-2011 16:06
Recovery dont work by me but
suprise i do first step rooting and become error with communicate,
then copy DIAG to SD card and start phone holding volume down and .....
after this steps
VOILAAA
my HTC is SIMFree ---- unlocked
Thx again and Best Regards
mobiplusgsm 08-29-2011 19:04
VOILAAA
'clean s58 data' is from xtc clip.
are you sure about your phone that is htc sensation?
debeliamark 09-01-2011 05:58
Tested with 2 pcs ( US market ) ... one was BL 17.0008 second one 18.0000 - both are unlocked OK, but 18.0000 want S-off before to accept PG58DIAG flashing, so from my point of view - on 18.0000 using first revolutionary is mandatory ...
Anyway - a big TNX to gurinder for shared solution and to AlphaRev and unrevoked teams for S-Off tool.
WBR, DebeliaMark, BG
sunshine4u 09-02-2011 10:38
great effort done by The AplaREv & unrevoked Team & thanks to gurinder for uploading such a useful stuff Unlocking of Sensation is still not available on XTC Clip and i have unlocked 1 Sensation with this method ..Thanks Gurinder & keep posting such useful unlocking stuff.
MYUNLOCKING 09-03-2011 16:30
when i enter beta gey it gives invalid and then shut down
how to copy paste on it because when i try to copy with ctrl+v it doesnt work
any solution
MYUNLOCKING 09-03-2011 17:08
Ok i got solution :)
sunshine4u 09-03-2011 19:05
what solution u got ?? share here so that other users get benefit from your solution
gemini16 09-05-2011 11:25
Oh, i really thanks you guy. I have done 11pcs HTC sensation with this menthod.
MYUNLOCKING 09-05-2011 20:16
HOW TO COPY BETA KEY TO REVOLUTIONARY?
BECAUSE key is very long and every time gives invalid key error
and when i press control v then no success :(
how to copy paste key ??
y3kt 09-05-2011 20:42
Just right click on dos windows and select paste, if not work then right click in dos icon (upper left corner of window) and select edit then paste, thats it, luck
Sonu Jawed 09-05-2011 20:45
ctrl+v For Paste
ctrl+c For Copy .... lol
B.r.,
Sonu
any solution
buy_new 09-05-2011 22:14
S-off problem any idea
| Revolutionary S-OFF & Recovery Tool 0.4pre4 |
Brought to you by AlphaRev & unrEVOked.
Waiting for device...
Found your device: HTC Sensation Z710e (pyramid-1.17.0008, Android: 2.3.3, ROM version: 1.27.163.
This is a beta release and requires a beta release key.
Please visit: Revolutionary for more information.
Enter beta key [ serial: HT15JV800670 ]: Ln4FJoa1rL1OrSNe
Beta key accepted - thank you for participating!
Zerging Root... this might take a minute or so.. Root acquired!
Sending in Caroline...
Cleaning up...
Rebooting to fastboot...
When life gives you lemons, don't make lemonade. Make life take the lemons back!
Waiting for fastboot...
Rebooting to fastboot (again)...
Communications with phone unexpectedly interrupted. Try again.
Press (almost) any key to exit.
Page generated in 0.35864 seconds with 5 queries
